Adding extra battery to 2014 PiP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by YL Yedi, Aug 27, 2014.
  1. hill
    8,884
    No - did he upgraded his suspension? .. or does he just bottom out all the time.
    #21 hill, Aug 27, 2014
    52,227
    new springs, but he said it's only 160 lbs. pretty sharp guy.
  3. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    I'd wait on adding batteries. The trade-in value plus you're getting the time to save your money until the 2017 PiP (or Volt or cheaper BMW i3 REX) comes in to see how much range (and better battery chemistry) has increased. Also Leaf 2nd Gen will also be out as might the Tesla 3. Who knows, maybe even Entunes will be usable by then.
  4. GregP507
    GregP507 Senior Member
    3,002
    481
    Sixteen lead-acid car batteries in the back would also work.
  5. hill
    8,884
    What's a little off gassing hydrochloric acid, as long you're range increases .... just don't light up unless you are 20 feet away.
    drash likes this.
  6. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    And now the PiP will be hydrogen powered as well!
  7. GregP507
    3,002
    481
    These reasons were once touted as the "proof" of why electric cars will never be practical.
  8. Mwoo30
    Mwoo30 Junior Member
    La
  9. bisco
    52,227
    well said!(y) and welcome to priuschat.:cool:
    -Rozi- and Tracksyde like this.
  10. hill
    8,884
    Hard to disagree with that - for sure
  11. GregP507
    3,002
    481
    Just wondering what was said. I see only a blank post.
  12. Barbara R
    Barbara R Junior Member
    44
    2014 Prius Plug-in
    Lucky you to get an Advanced. I wanted one and there were none available.
    Anyway, I think the whole EV range discussion is really almost moot WRT PIP. I think it's better to think of the PIP as having a really big battery that leads to better fuel economy -- how much better simply depends on your driving habits. I drove 55 miles mostly hwy yesterday on a full battery and got 67 MPG. Coming back without recharge I got 53 MPG. My 2005 Prius averaged 47 MPG. So overall I'm happy. Obviously, in-town driving where I can recharge more often gets me much higher mileage.
    When I was researching PIP vs. Volt, the review comment that most struck me was "The Prius is a better vehicle. The Volt is a better ELECTRIC vehicle."
    Whether you bought the right car for your needs is something only you can decide.
    -- Barbara
    -Rozi-, bedrock8x and drash like this.
  13. GregP507
    3,002
    481
    I've always had a bit of a problem with mixing plug-in power and gasoline power. They are two different power sources, therefore MPGe is a bit of a meaningless term in my opinion.
    When you say "99MPGe," it gives the impression that you are getting 99 miles out of a gallon of gasoline, when in fact, you are fudging it with an additional power source, which is conceptually the same as roping your car to a truck on the freeway.
  14. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Wait a minute, wasn't there a guy rebuilding a PiP with parts from a junked HS250h. I believe it was Bill the Engineer and he was going to mate the HS250h drive motor to the PiP.
    Wonder how far along he is?
  15. mrbigh
    3,686
    699
    Long Island, NY
    Interesting, could you find a link to this "adaptation"....?
  16. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Exactly! You get improved MPG from plugging in.
    That's why it is promoted as a PLUG-IN HYBRID, rather than having any type of "electric" label.
  17. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Actually it is ,,,, wait for it, The BMW i3! Oh and I forgot you will still need your Prius for long vacation trips.
  18. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    No they would not, what a mess you really mean that? I surely hope you are joking!!!
  19. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    I hate to wake you up , but plug in hybrid is a electric label in it's own right!
  20. GregP507
    3,002
    481
    OK, I'm going to get some flack for saying this, but plugging in does not increase MPG; specifically "miles per gallon." If anything, the miles traveled from gasoline will decrease slightly from the added weight.
    The actual miles you get from a gallon of gasoline doesn't increase, however you will get extra miles as a result of the energy stored in the battery.
    Two separate things.
    Rant over.
