Oil, Yeah...I know.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mongo1958, Aug 31, 2014.
  1. mongo1958
    mongo1958 New Member
    Newnan GA
    I just checked, or tried to check the oil. The oil is so clear and thin, it is not very easy to see it on the dipstick. I had to try several times to get an accurate reading. 0W20??? My Harley takes 20w50 and my truck takes 5W30. When did 0w20 come out? This stuff is supposed to last 5k miles?
    #1 mongo1958, Aug 31, 2014
    51,486
    mongo1958 likes this.
  3. bisco
    51,486
    synthetic.
  4. pmike
    pmike Member
    237
    81
    Central Florida
    It is hard to see when the oil is fresh. Most new vehicles are calling for 0w-20, even full size GM trucks. Modern day engines are built with tighter tolerance and run much cleaner (cleaner oil, longer intervals). At 5k the oil is just light brown. I agree it is water think especially if you change your oil hot but the engineers know what they are doing just follow the prescription.
  5. Mendel Leisk
    40,919
    I think it's a double whammy: the oil is very thin when new, and the Prius engine seems to be really easy on it. Our previous Honda Civic Hybrid uses 0W20 as well, and I've got NO problem reading the dipstick on it, especially when oil change time is approaching. It looks much darker/thicker by then, and has that used oil smell.
    By oil change time the Prius oil still looks like pampered maple syrup, lol. The dipstick I've found tricky to read. What I've learned:
    Ignore the oil running along the edges of the dipstick, well above the top mark. Look for a distinct, full-width break in the oil marking. Flip it over, look at both sides: one side's often easier to read, the other a mess. Repeat several times, have strong light.
    mongo1958, dorunron and Robert Holt like this.
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Well said Mendel!
  7. Okinawa
    Okinawa Senior Member
    1,333
    320
    Not 5,000 miles------10,000 miles. It's in your maintenance manual.
  8. mongo1958
    Newnan GA
    Sorry people, my 2014 Maintenance and warranty guide clearly states "5000 miles" on page 38. Also on page 38 is the 10,000 mile Maintenace interval and it also states to replace oil and filter.
    #8 mongo1958, Aug 31, 2014
  9. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    The oil is good for 10k and that is from Toyota, as long as your using a good brand oil and the right type nobody has proved any extra wear with 10k oil changes. The reason why it is thinner and lighter than your bike is part of the reason why a car that can carry 5 people and cargo also gets better mpg than your bike.
  10. Mendel Leisk
    40,919
    That is from Honda USA. That interval varies, around the world.
  11. PriusInParadise
    180
    91
    Hawaii
    Oil and filter change at 5,000 miles is listed under "Additional Maintenance Items for Special Operating Conditions", "Driving on dirt roads or dusty roads","Driving while towing, using a car-top carrier, or heavy vehicle loading", "Repeated trips of less than five miles in temperatures below 32°F / 0°C:", "Extensive idling and/or low speed driving for a long distance such as police, taxi or door-to-door delivery use".
    If your conditions fall within those descriptions, then your oil & filter change interval will be 5,000 miles.
    If not, then 10,000 miles.
  12. bisco
    51,486
    wait until you take it in at 5,000 and ask for the first free oil change. i'd like to be a fly on the wall.:p
  13. mongo1958
    Newnan GA
    I'm going to proceed by the published schedule in my warranty and Maintenace guide at 5k miles or 6 months because I'm getting 2 years of free service. my guess is that will be how Toyota will want to do it as well.
  14. mongo1958
    Newnan GA
    I'll call or stop by Toyota on the way home from work on Tuesday fo conformation.
    EDIT NOTE:
    Ahhh....now I see what you all are talking about. I missed the part that said special operating conditions. D'Oh!
    Thanks for the education.
    #14 mongo1958, Aug 31, 2014
  15. mongo1958
    Newnan GA
    Thanks, I missed that part about special operating conditions.
  16. bisco
    51,486
    i actually did my first at 5,000. i like to clean out the break in garbage before going too far, then every 10,000 after or once a year. it was a knock down drag out to get the dealer to do it though.:p
  17. mongo1958
    Newnan GA
    I could just do it myself. I have always done the Maintenace on all my vehicals. I also did the first oil changes at 1000 miles. one time I found part of a shop rag in one of the oil screens on my Kawasaki 1500.
    #17 mongo1958, Aug 31, 2014
  18. bisco
    51,486
    i believe it. when you consider that time it takes to go to the dealer and wait, you're proxy ahead of the game paying for oil and filter and knowing it's done right. i have to spend an extra hour every time, siphoning out the extra oil they put in.:mad:
  19. pmike
    pmike Member
    237
    81
    Central Florida
    I am taking my factory fill to 10k miles and having a used oil analysis done. I am at 9,500 miles and will share my report when it comes back.
    The first two oil changes are free but I will be doing them myself. Its not worth my time to go waste half a day at a stealership.
  20. bisco
    51,486
    thanks pmike, that will be useful info for all of us.(y)
