  1. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,747
    377
    Colonial Heights, Va
    My big fat
    EPIC fail of the day! lol
    Unless your good enough to cover everything good enough in 1 coat your good... I did small mist coats then thicker coats and didn't even thinking about the pasti pulling SD I slowly pulled the tape off! lol oh well this will be gone before I leave for work haha
    ckam1989 likes this.
  2. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    Props for trying something different though. Best thing about that plastidip though, it peels right off!
    PlusIV
  3. Accordlayingkit
    1,618
    1,747
    377
    Yup... thanks, I guess u gotta hurry up and cover it thick with 1 coat then peel the paint off!
  4. ckam1989
    ckam1989 Active Member
    185
    358
    Irvine, CA
    2014 Prius Plug-in
    :) I was going to try plastidipping stripes. Or stars. Maybe not so much anymore.
    Made my day seeing your post :) good luck removing it.
  5. Accordlayingkit
    1,618
    1,747
    377
    already gone... me and little boy did it real quick.. not a problem
  6. rcs3434
    rcs3434 Member
    56
    163
    Danbury, ct
    You can do the 4-6coats like you normally do for any plasti dip project, but your last coat has to be thicker and make sure your edges are wet where the tape is and peel the tape right away and at a angle. Another tip is to tape around where u are gonna put your edge and tape the actual edge last so your only pulling one strip of tape(quickly) I did something similar before I dipped my whole car....hope this helps
  7. Accordlayingkit
    1,618
    1,747
    377
    Ok cool...thanks! U got another pic of your front end other besides your profile pic? Looks good on your profile pic! Well I guess before u did your car blue right?
  8. rcs3434
    rcs3434 Member
    56
    163
    Danbury, ct
    No prob...Yea my car is blue now, soon to be another color once I order it. (y)
    I have these pics
    The only issue was I had old painters tape and in two spots it didn't stick well and some dip went under it
    Accordlayingkit likes this.
  9. Accordlayingkit
    1,618
    1,747
    377
    Damn that looked pretty sweet man...nice job
    rcs3434 likes this.
  10. xcuter
    xcuter Active Member
    303
    182
    Replaced all broken tabs and testing JDM LEDs. Hope to have them installed soon. [​IMG]
  11. Accordlayingkit
    1,618
    1,747
    377
    Im jelious! lol how hard was it to replace tabs?
    Bullet Salvador likes this.
  12. xcuter
    303
    182
    Very easy just got to fully break off the old tabs then screw in the new tabs.
  13. Accordlayingkit
    1,618
    1,747
    377
    great job man! So where do u get the HID bulbs for them..u had to order them as well?
  14. xcuter
    303
    182
    The bulbs are built into the headlight assembly. I had to purchase the ballasts though. I got them locally from a wrecking yard.
  15. Kanslisti
    Kanslisti Junior Member
    Espoo, Finland
    Thule Rear Mount Connector installed. :)
  16. Jcgnic3man
    Jcgnic3man Junior Member
    31
    Charleston, SC
    Finally had the TRD Springs and Rear sway bars installed, new lugnuts, tinted the tail lights.Finally had the TRD Springs and Rear sway bars installed, new lugnuts, tinted the tail lights.
  17. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
  18. xcuter
    303
    182
    LED headlights installed.
    Thanks accordlayingkit for the lights. I owe you one.
    sfv41901, Burna J and Accordlayingkit like this.
  19. Delta Flyer II
    547
    248
    69
    Noticed a couple days ago that my clear plate cover was weatherworn, so replaced it with a new and improved version, this one is much thinner and much clearer lol
  20. Accordlayingkit
    1,618
    1,747
    377
    No problem dude.... dang still jelious though lol
