Other techniques besides P&G?
Discussion in 'Gen 3 Prius Fuel Economy' started by Starship_Enterprius, Sep 5, 2014.
  1. Starship_Enterprius
    Starship_Enterprius Active Member
    331
    163
    Ottawa, Ontario
    2018 Prius Prime
    There's another thread on P&G and while this is related i did not want to hijack the thread.
    Disclaimer: noob alert here, so bear with me lol.
    So all this week i tried Pulse and Glide and was only able to improve my displayed fuel consumption from 3.7l/100km (63.7mpg) down to only 3.6l/100km(65mpg). Not even worth the aggravation specially since my 3.7 was achieved with the total comfort of the CC. But like I said I'm a noob, so i probably am not getting it right yet.
    Anyway, today's Friday so i gave myself a break from P&G and on my way to work i just feathered the pedals like i did with my prior non hybrid clunker. Well that... plus last week I happen to read one of the threads here on SHM and IGN etc and realized that was probably what i was seeing in CC when at brief times i was getting 2.4L/100km (98mpg) readouts. Since I didn't have a scan gauge or any other gauge, so i just decided to try it by guesstimate.
    So basically i'd pulse to speed, hold it steady there until it settles, then carefully back off the pedal until it reaches a point where it can barely maintain momentum.
    By carefully feathering the pedals, i could actually hold it for longer periods in 2.5l/100km(94mpg) than what CC did. When it slowed i'd up the instant consumption readout by one bar and wait for it to slowly speed up and when it went too fast i'd go low to 2.4k/100km(98mpg) to slow it down, all the time keeping the ICE running even when the HSI was well within the EV range. Only when i overshot or the road descended did i let the ICE stop and glide closer to the car in front until it'd slow down. Then I'd bring it up the HSI bar slowly up disregarding whether i was in electric or ICE until i was up to speed or the ICE kicked in then feather it back to 2.5kl/100km (94mpg). I was concerned in keeping my instant readout as near and as long around that magic mark.
    So on the road i was getting at least 3.4l/100km (69mpg) until i hit road construction stop and go and my battery went down from 6 bars to 2 causing the engine to start up every time i had to creep a few feet. That ruined my mpg. But by the time i got to work i got it back down to 3.5k/100km(67mpg). That was my 1st try, and without resetting my trip. So my gut tells me i'd get better numbers next time.
    In reviewing this morning, I found it a lot easier to execute than P&G, felt more pleasant and natural, definitely less aggravating to those behind me, and got better mpg. This made me realize I may have jumped too early on P&G and may be missing other easier options.
    So how often do you guys use P&G versus other techniques (ie pedal feathering, SHM, etc)? I guess I'm trying to decide if i can give up on P&G for now and invest more time on other lower hanging fruits. Of course i know in the right situation it should be used. But rather than forcing P&G every time and making it my primary tool, perhaps there are other things i can do first.
    Thanks!
    #1 Starship_Enterprius, Sep 5, 2014
    51,896
    have you pumped up your tyres?
  3. bwilson4web
    16,204
    When I need to coast, I shift into "N". Otherwise, I drive on cruse control using the lowest speed of the vehicle I'm following . . . and I look for slow vehicles to follow.
  4. bisco
    51,896
    and he has a large 'magnet'.:cool:
  5. Starship_Enterprius
    331
    163
    Ottawa, Ontario
    2018 Prius Prime
    yup. 44psi all around, the max on my tires. (i don't really care making the rear 2 psi lower, every little thing counts).
    Tried that once last week and put it into reverse by mistake. Good thing i was still crawling around our neighborhood streets. I will have to practice it several times to get confident using it as this Joystick shifter just feels thoroughly strange. But i will definitely try that again next month when we drive from our city Ottawa to NJ via the Catskills mountain. I do regularly shift to N with our Toyota Sienna going downhills in those areas.
    funny i almost put that in "other" techniques when i started the thread.
    another option might be to have a pumpable/deflatable boat tail rubberized backpack strapped to the hatch, and an autoinflator at highway speeds. At slow speeds and city driving its deflated, but automatically inflates in highways into a boat tail. Now you see it, now you don't lol.
    #5 Starship_Enterprius, Sep 5, 2014
  6. Starship_Enterprius
    331
    163
    Ottawa, Ontario
    2018 Prius Prime
    How about SHM, is it possible to approximate without gauges? Anybody has it down so perfectly they can do it without looking at the gauges?
  7. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    When you are doing P&G, the secret to it is this. When you pulse, use the maximum amount of the HSI Indicator without entering the Power Zone. Make sure you glide a LONG time over a LONG distance. Only then will begin to see the big numbers. In order to do that you have to be on a road where there is little traffic. Best habit is to go with the flow, and only P&G when no one is behind you. Depending on your route, your technique will vary as you make your trips along with traffic at that time. Here in Texas we use the MPH system unlike where you are. So you would have to convert the numbers I will throw at you.
    Here are examples of speeds I use when doing P&G.
    On a 30 MPH limit road I will pulse very quickly up to the target of 32 MPH, then immediately go into a glide and glide to at least 23 or lower.
    35 MPH road - pulse to 38, then glide to 25 or lower.
    40 MPH road - pulse to 43, then glide to 30 or lower.
    45 MPH to 50 MPH - pulse to two MPH over limit, then feather the pedal until the HSI is just about even with the right side of the ECO logo on the HSI. When I do this the Prius will gradually slow down and the HSI indicator will gradually move to the left side of the middle line. By that time the speed has dropped three or four MPH, then I will quickly accelerate back up to the target and feather again. This technique is pretty much what SHM is all about. I look at the instantaneous read out and usually see somewhere between 75 to 95 MPG when doing the SHM.
    At 55 or higher, depending on my mood I might use CC if the roads are flat. But if it is real hilly I will simply use the foot feed as the CC is too aggressive on steep hills and pushes the HSI into the power area too often wasting fuel.
    Now if I am in stop and go traffic, I then EV without being in EV Mode. I am still doing P&G, but trying to use the least amount of battery possible. If I do need a boost of power, I won't hesitate to use the ICE.
    I am also one who will NOT use the A/C unless it is real hot. If I am by myself, I will run with the windows down until it reaches 94 outside. If I am on the highway, then the A/C comes on and the windows go up. When I use the A/C, I don't use AUTO mode. I set the temp at 76 or 78 and don't run the fan wide open. Even on a 100 degree day, I am comfortable. The windows are tinted with 3M tint, so it does make a difference. Of course during the Winter the temp will be a little lower than 76 or 78...
    Wayne Gerdes is the fore runner when it comes to P&G. There is a link in my signature file below that links to the article. Discusses all the different techniques and also explains how far one must pulse and how far one must glide to get certain MPG out of the Prius. I regularly see 50's, 75's and close to 100 on the five minute graph when P&G on the back roads. Plenty of them to use. The key to it is to not be in a hurry. I don't work any more, so driving is not a daily grind for me. I go to the doctors, grocery stores, and whatever else I need to do that day.
    Sounds like your numbers are pretty good. Trip MPG really does not tell you much. The true tell all is over several tanks. Trip B on my Prius shows 55.7 MPG for just over 1450 miles. Best tank so far as per my fuelly is 56.8.
    Best of luck to you,
    Ron (dorunron)
    #7 dorunron, Sep 5, 2014
    Starship_Enterprius likes this.
  8. Okinawa
    Okinawa Senior Member
    1,333
    320
    Traffic lights, stop and go, are real MPG killers. You can't drive yourself nuts trying to do it but if you can time traffic lights it will help a lot.
    dorunron likes this.
  9. bwilson4web
    16,204
    #9 bwilson4web, Sep 6, 2014
    Starship_Enterprius and dorunron like this.
  10. zebekias
    zebekias Member
    101
    35
    Greece
    My strategy is to avoid running the ICE when it will be inefficient. On uphills if the CC will push the HSI into PWR I slow down until I can keep the HSI in ECO (CC forcing you in PWR is pretty rare.) The more frequent scenario is when the HSI is at or below the midpoint (level or downhill), in these cases I glide or try to use the electric motor. This is producing an indicated 3.5 l/100 km with minimal effort, I'm mostly on CC :)
  11. bp1000
    bp1000 New Member
    This is a bit cliche but I've realised the best way to drive it is normally.
    I actually realised it takes a lot of effort to beat the prius at the mpg game. I can using p&g keeping speed right down and gliding to much slower speeds than the posted mph limits.
    All you need is heightened awareness
    It's only 3 things for me
    1) get up to speed quite quickly, using pwr zone for higher speeds and back off as you reach speed
    2) very very delicate throttle use to maintain speeds. CC if it's dead flat and for hills maybe a squirt of throttle on the flat and maintain a steady load even if speed bleeds off
    3) slowing down by trying to drive without brakes. Read the road, check traffic behind, begin to bleed off 1-2mph before you can even see the junction sometimes, move into a glide when it feels right and switch to regen braking if you need to. I usually have to braking from higher speeds eg 50mph and above.
    All together and I'm exceeding the manufacturer average of 71mpg UK.
    I just did a 110mile motorway commute last night. I achieved an incredible 67.5mpg. I actually just drove normally and was hitting 73-77mph on cruise but 55mph truck drafting helped as traffic built up. Averaged nearly 100mpg over about 8 miles.
    Keep the awareness up, be gentle with throttle and glide to junctions as much as possible. Only other thing I do is don't cheat the ev under 40mph. Don't force battery on. Don't try to exhaust it unless it can't be helped like being stuck in slow traffic.
    Oh and I also allow the car to warm up for 1 min if I'm setting off on faster roads from cold.
    Actually the other thing was, keep a steady speed when following traffic, if that means a bigger gap. It's bad to keep slowing down and speeding up. Also don't be tempted to glide when over 50-55mph because wind resistance is so great.
  12. zebekias
    zebekias Member
    101
    35
    Greece
    There is something to be said about just driving the darn thing :)
    When I drove it carelessly from the dealer in Dusseldorf Germany to Brindisi Italy and then to Greece I got around 5.4 l/100km or 43.5 US mpg, but I was flying on avg 120-140 kph, traffic permitting, and absolutely no attention was paid to fuel economy. Considering we left the dealer in Dusseldorf on Tue 4:30pm, stopped to see Germany humiliate Brazil 7-1 (we made more food, beverage and gas stops) and then made it to Brindisi on Wed 6:30pm just in time to get some food and get on the 8pm ferry to Greece, I was pleased to see the still reasonable fuel consumption. That was with 36 psi all around, rain throughout Germany, and cold! When we flew from Greece Tue morning it was 35C... we hit 9C through some sections of Germany/Austria at night! It was strange to have to turn on the heater in the middle of summer.
  13. Mendel Leisk
    41,402
    To the OP, if you're getting around 3.6~3.7 liters per 100 km, I'd call it good. Is this calculated? Either way...
    I'm happy with summertime tanks coming in around 4.3~4.4 (calculated), lol. Our's has the 17" tires, that's a factor I guess.
  14. MattPersman
    MattPersman Member
    110
    33
    Indiana
    I p and g everywhere in my normal daily driving. Now when I leave to go to work in the morning I will jump on a 50 mph road from my subdivision and have to accelerate as much as I want cause the engine is cold and won't get good MPG anyways so I get some heat in the engine so I can get good mpg on the next road I turn on and will start to P and G. Only time I don't is when I have to get on highway or interstate roads, then MPG concerns go out the window and I am driving at whatever speed I feel comfortable with and cruise control on, I would rather get 48-50 mpg at 77 or 78 mph, than go for 60 some mpg at 60 mph on the interstate. I have done both and the cost savings just isn't worth it to me compared to the time savings over many hours of driving. It's like $5-6 diff over a 500 mile trip at approx 3.50 per gallon
  15. dorunron
    3,318
    1,105
    Houston, TX
    Correct me if I am wrong. Aren't your gallons over there across the pond from me larger than over here in the USA? That would help to explain why your numbers are much higher than those of us over here. Sounds like your numbers are great, and IMO your techniques are great too. I too believe in "Driving Without Brakes". Scanning the roadway ahead and making adjustments really does make the numbers go up. What really kills the MPG more than anything is the A/C compressor even if it is electric.
    Ron
  16. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I P&G in two situations: city driving with lots of lights, and rural driving with rolling hills.
    In the city I accelerate to low 40s mph and then glide to the next light;
    In rural driving I use petrol power to get up the hill, and glide down. In this case the speed does not change but the P&G effect is the same.
    So long as my speeds are below 45 mph and the weather is nice I expect fuel economy over 70 MPG_US in our Prius v(agon) if traffic is light. If there is very little to no traffic I manage about 80 - 85 MPG in round trips over 15 miles and one engine warm-up.
  17. bp1000
    bp1000 New Member
    Yes sir, imperial gallons are larger and my averages are equivalent to your 56-59mpg. However my highway mileage is lower, more like 54-55mpg US.
  18. Okinawa
    1,333
    320
    You are doing very good.
    bp1000 and dorunron like this.
  19. Starship_Enterprius
    331
    163
    Ottawa, Ontario
    2018 Prius Prime
    Thanks for all the tips. This will take me a while to digest. I'll try to reply to some but it will take a while so pls forgive if it feels like i missed your post. first off:
    not yet Mendel - It's all trip MPG for now. I filled up my tank 10 days ago after using up the unknown dealers fill up. The tank took only around 37litres and I'm still halfway as of today. The dealer freebie lasted me 3 weeks and this one looks like its going to be the same.
    So even if the trip MPG will be off by 10%, the gas savings looks like it's gonna be good anyway. Previously, I had to fill my previous daily clunker (99 honda civic) almost every week.
    Exactly what i'm beginning to think. Over the weekend it was really warm and i ended up idling in the grocery parking with the AC on. Then wife followed using the Prius when we dropped the old clunker to the crushers, then let her drove back home as she seemed to enjoy the new ride a lot. By the time we got home trip MPG was up to 4.1l/100km (57mpg). So I'm thinking if this is how its going to be, i'd better forget watching the MPG and just be happy with the lower monthly gas bill so i can keep the love at home lol.
  20. Mendel Leisk
    41,402
    Enjoy that sort of behaviour while you can. If you get hooked on the mpg game, that'll become impossible to do. ;)
    You guys are still doing good, especially running AC.
