how to close prius hood properly.
Discussion in 'Newbie Forum' started by Granzon, Sep 6, 2014.
  1. Granzon
    Granzon New Member
    I just got white 2015 prius persona.
    How do I properly close the hood. My old car I can drop it from 7 inch height, but the hood on prius is so light that it doesn't close all the way, I have to gently push it down so it snaps in
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    How about dropping the hood from 12 inches? ;)
    SCH-I535
    milkman44, GrumpyCabbie and vskid3 like this.
  3. bisco
    52,136
    put on a pair of white gloves, lower the hood until it meets resistance, then gently push down until it locks. be good to your baby until you get the first scratch, then drop it from 12 inches.(y)
    robertmaria, Okinawa, alekska and 6 others like this.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Lower the hood gently until it rests, then push down gently
  5. JC91006
    JC91006 Senior Member
    16,796
    8,589
    2nd the drop at around 12 inches. No pushing required
    Any discount on the 2015?
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    LOL!
    And if the car gets any more scratches, drop the hood from 2 ft.
    Spare the rod and spoil the child
  7. Granzon
    Granzon New Member
    So whats the proper way, drop or gently pushing it?
  8. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    All due respect Granzon, but just drop it...the hood that is.
    mtbiker53 likes this.
  9. Mendel Leisk
    41,714
    Just had a look in the Owner's Manual, and as far as I can see, it just breezes by, no description on HOW to do that. It does caution to get the support rod out of the way, back in it's clip...: or the hood may bend when you close it, lol.
    What I always do is hold it about 8~10 inch high and let it drop. That said, after a recent trip to the service department, I heard a nasty rattle from the engine. Lifted the hood and the support rod was loose, laying on the engine. Maybe if you drop it from too high it can pop out of the clip.
    Not an issue if the latch is is attached to the body frame, what I'm more used to with other vehicles. Anyway,
    My take would be to drop it, but from not too high, just to avoid paw prints.
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    This is a philosophical argument. Do you slam doors shut, or turn the door handle to shut the door gently and quietly ?
    Personally, I am so noise adverse I teach my family to hold in the latch when they close the microwave door.
    Our cats also appreciate an environment without explosions.
    alekska and bisco like this.
  11. Mendel Leisk
    41,714
    One of my son's friends who works in the automotive industry goes with the rest it on the latch and then push technique. Maybe new tricks time?
  12. JC91006
    16,796
    8,589
    This is not a ferrari but a prius, just close the damn thing.
    Tony D, milkman44 and mtbiker53 like this.
  13. Granzon
    Granzon New Member
    Its fully close now. Hopefully i wont be the one to open and close it until the first service.
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    Personally, I *much* prefer click and not TWACK
    Easier on the mechanism, a nicer sound to my ears, and I imagine a better built mouse-trap.
  15. JC91006
    16,796
    8,589
    The problem with pushing down will eventually develop a wave on the paint finish.
  16. SageBrush
    11,627
    2,533
    Southwest Colorado
    What is a 'wave' ? Do you mean a depression in the paint surface ? I find that *very* hard to believe, since it takes very little pressure to latch the hood, I use two palms, and the hood is opened/closed once or twice a month.
  17. JC91006
    16,796
    8,589
    Pushing down in 1 area will eventually cause a wave, May take 1 year, May take 10 years, but it will happen. It's more evident in those that have trunks or hatches that require more power to close.
    SPH-D710 ?
  18. xliderider
    8,140
    3,277
    Honolulu, HI
    Also, the Prius hood is aluminum, not steel, so it is much softer and easier to deform.
    milkman44 likes this.
  19. Granzon
    Granzon New Member
    So is it better to drop it or gently pushing it close?
  20. SageBrush
    11,627
    2,533
    Southwest Colorado
    I can only imagine what you must go through when you have to choose between pushing the brake or go pedal.
    alekska, milkman44 and mtbiker53 like this.
