Tale of 4 mechanics
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fifine, Sep 7, 2014.
  1. Fifine
    Fifine Member
    108
    So Cal
    As with computers and anti-virus programs, it seems like one would need several mechanics to really get the full picture and diagnosis.
    In the last 5 weeks, I've been to 4 auto shops/mechanics from the pre-purchase inspection, the dealer service dept. to 2 indie Tech's. Each place performed some service on the car (133k miles) and had its own 50 or 100 or whatever items check-list that it went over. One shop found leaking rear struts that none of the others mentioned.
    Here is where I lose faith. Pre-purchase shop said nothing about the ICE water pump. Dealership did the recall work, gave me a deal on installing the serpentine belt and said all is well with the car.
    3rd shop did the ICE coolant and Transmission fluid changes since I have neither the equipment nor space to do myself. Mechanic even mentioned that the ICE water pump looked new, so no worry on that front.
    Same afternoon, I stopped by an indie hybrid specialist to swap out the brake fluid (since it is a more complicated process from what I learned here). During his inspection he spotted a pink pimple in the belt area and showed it to me!!!!!
    (He also checked out the suspension and said nothing about the rear struts)
    I didn't want to believe my eyes and was hoping some of the coolant from the ICE coolant change dripped and dried there.... Besides how could at least 3 other sets of trained eyes have missed this tell-tale sign?????
    I rinsed off that pink pest and looked over the area for several days Nothing.
    Until today - no longer a mere dot. I guess the pump spat out maybe 1/2 in. of pink.
    From the 1st mechanic to the 4th one, about 300 miles were driven. Maybe the water pump began its leak 295 miles after the pre sale inspection? (yeah right...) :whistle:
    I'm just astounded the dealership Tech saw nothing as he was installing the belt. That dept. is perennially ravenous.
    Should I go see 2 or 3 more doctors? perhaps I am not as healthy as I think :ROFLMAO:
  2. Patrick Wong
    18,200
    6,500
    1. How about providing a good photo of the coolant pump showing the leak.
    2. I'm not sure what is the point of seeing so many mechanics. When you decide that the leak is more than trivial, have the engine coolant pump replaced.
  3. Fifine
    Fifine Member
    108
    So Cal
    Good morning Patrick,
    Very silly in hindsight but there was no design to have so many mechanics.
    #1 was due to geography: a reputable shop near the seller who was not close to me;
    #2 the dealer for recall work
    #4 only because of the advice I read on PC re: brake fluid change
    Due to the extensive maintenance work required on this car (it probably had 2 oil changes, 1 set of new tires & 1 bulb in its 133k miles), it was a scramble of what to do when within the budget available, and still have safe usage.
    I'm just surprised so many eyes did not catch the leak.
  4. Fifine
    Fifine Member
    108
    So Cal
    In a couple days when I see the car again. Thank you for caring.
  5. dpeverhart
    dpeverhart Member
    126
    I
    I'm certainly no expert but it sounds like it's possible that the coolant change allowed the leak to manifest. Possibly the old coolant had crusted the weep hole and when it was changed that broke free. Either way, the ICE water pump is an inexpensive repair. I had my indie do mine and if I remember correctly the part was around $50 and labor was an hour.
  6. Patrick Wong
    18,200
    6,500
    Depends upon where you go, regarding repair price. For example, my daughter with the 2007 (72K miles) had her engine oil/oil filter changed yesterday, the Toyota Rancho Santa Margarita (south OC, CA) dealer service writer pointed out that the engine coolant pump was leaking, and quoted $600 for the replacement. I asked her for photographic evidence of the leak.
    She sent back a couple of photos showing pinkish spray all over the hood sound insulating pad. This was not a tiny amount of spray, it covered around 1/3 of the pad. It was also evident that there was substantial pinkish residue in the inside of the pump pulley.
    So I told her to buy a gallon of Toyota SLLC and keep an eye on the coolant level. I'll make arrangements to swap cars with her and replace the engine coolant pump/serpentine drive belt in the next month or two.
    The price for the engine coolant pump is currently $56.57 while the serpentine drive belt is $14.02 at Autonation Toyota Gulf Freeway, Houston, TX via web order. I know this because I just placed an order yesterday for those items...
    #6 Patrick Wong, Sep 7, 2014
  7. JC91006
    JC91006 Senior Member
    16,759
    8,562
    Why swap and leave her with a 2004 that's past its prime? Is only a 1 or 2 hour job. Do it while she waits and be done with it.
  8. writes123
    writes123 Junior Member
    92
    Riverside, CA
    I know an experienced independent Toyota mechanic in the Orange County area. He used to work for South Coast Toyota until he opened his own shop many years ago. He is equipped with Techstream and performs an overall vehicle inspection with oil changes, upon request. I trust him with my Lexus LS430 and would trust him with my prius when I need his expertise.
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Crazy repair cost, but I have seen mark-ups for simple maintenance like this before: 10x the cost of DIY.
    Does the daughter of Patrick Wong not have her own toolbox ? Just send her a link to one of your tutorials :)
    #9 SageBrush, Sep 7, 2014
  10. JC91006
    16,759
    8,562
    Some of the regular guys here only diy. Who is this mechanic in oc?
    SPH-D710 ?
  11. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Is belt that was replaced over tightened causing the pump to go bad??
    I would be leery as to the struts being bad too. Does rear end bounce as if they were worn ??
  12. Patrick Wong
    18,200
    6,500
    My daughter is the kind of person who get excited about buying a new party dress at Nordstrom and yawns when I attempt to discuss vehicle maintenance with her. I pointed out that she would have been aware of the engine coolant pump problem if she had bothered to open the hood once in a while to check engine compartment fluids.
    I decided that I will need to bring a hydraulic jack, jackstands and tools to work on the coolant pump at her home, rather than go through the trouble of driving 2,000 miles (two round trips between Tucson and south OC).
  13. writes123
    92
    Riverside, CA
    I have a fullsize jack, one medium size jack, 2 pairs of jack stands and a few tools if your interested in borrowing them. I'm located along your drive to the OC in SoCal near the 60 and 215 interchange in Riverside, CA.
    Just offering, in case you didn't want to lug around everything for those extra miles.
    Patrick Wong and SageBrush like this.
  14. writes123
    92
    Riverside, CA
    Vinam Auto Repair in Midway City, CA. He services all cars but specializes in Toyota and Lexus. Don't let the exterior fool you. He know's his stuff. Just don't go expecting coffee and munchies while you wait.
  15. Fifine
    Fifine Member
    108
    So Cal
    FYI -
    Mechanic #4 who found the leak quote $290- to replace the pump. Parts, labor + tax.
    Belt was already installed by dealer a couple weeks ago.
  16. Fifine
    Fifine Member
    108
    So Cal
