Now,, what is this about???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lester williams, Sep 8, 2014.
  1. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Looks like there might be a TIS for that code. Maybe Toyota will do a free fix??
  2. JC91006
    JC91006 Senior Member
    16,765
    8,563
    When I got my 2005, the same thing happened, it had 151k miles. Drove from Tennessee to CA and got a P0AA6 code.
    There must be something in the long drives that does the transaxle's in. This car was mostly dealer maintained but never had a transaxle fluid change. Replaced transaxle and now at 160k miles and running perfect.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    False.
    My Prius has done many multi-thousand mile treks with no latency and no issues. Most likely story is something else was also going on. My transaxle fluid has been changed around 80K miles and that has been it.
  4. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yep I'd agree with that. ;)
  5. lester williams
    227
    68
    mississippi
    Might be something to that as the car was bought in Meridian, Ms and driven to Ruston, La--approx. 250 miles. That was on Saturday afternoon, the problem started after G/D took the car to church Sunday and came back home-- at least it waited until she was home to die. I simply hate this as that child was hog-wild crazy about the little car.
  6. bisco
    51,851
    keep searching, you'll find another!(y)
  7. usnavystgc
    3,159
    990
    Tucson, AZ
    Where is the car now? I might want to buy it.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    OP has said Meridian, MS. Population ~ 40k and one Toyota dealership
    Go for it; back up your strong opinions with your own money.
  9. lester williams
    227
    68
    mississippi
    No,, it is not at the Toyota dealer there--- P.M. sent on location....
    usnavystgc likes this.
  10. usnavystgc
    3,159
    990
    Tucson, AZ
    Do you know what package the car is? Is it a package 2 or better?
  11. ericbecky
    ericbecky Hybrid Battery Hero
    4,426
    3,301
    Madison, Wisconsin
    Would be very interested to find out the final verdict on this car's symptoms.
  12. lester williams
    227
    68
    mississippi
    As would I... I am not convinced that the transaxle if fixing to drop out. A P0AA6 points to other things, it looks like.
  13. ericbecky
    4,426
    3,301
    Madison, Wisconsin
    If we were given the VIN we could check later if the repair is done at a dealer.
  14. acarlsa
    acarlsa Junior Member
    When I read about the battery it comes to my mind there must be ground lead somewhere. One from the battery to the body and probably one from the body to the powertrain. Has this been checked? I would guess a problem in these connections could give some false readings of sensors in the car.
  15. lester williams
    227
    68
    mississippi
    In Colorado for sightseeing vacation with G/F Elsie [ member here ] and can post VIN # when I return home, I am really curious about this also.
