Wheels, Lowering, and Spacers. Pics & Specs
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Steven Harvey, Jan 10, 2013.
  1. sidecar
    sidecar Member
    342
    45
    Australia
    RPF1 certainly are a good choice, they used to be around in 19x8 at 18.7lbs
    be careful you avoid RPF1-RC which are slightly heavier
    19" Wheel weights - Mechanical Database
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Enkei RPF1 according http://www.enkei.com/size_chart/RPF1.pdf is 19x8 35ET 5X100 20lbs - Still heavier than OEM but still lighter than my ADR 19s.
    PCUser "madmarc" had 18s - I'd like one size bigger...19s
    #42 Justdidit, Sep 10, 2014
  3. sidecar
    sidecar Member
    342
    45
    Australia
    ow right
    notice different weights per stud pattern
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Daves09prius likes this.
  5. sidecar
    sidecar Member
    342
    45
    Australia
    the one at top has posted here before
    it had a number of detail mods
    if I remember rightly the wheels are Prius Gen III 17"
  6. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    The Silver Prius with the 17" Gen III wheels is my favorite. My goal is to one day have those wheels, or something similar on my Prius.
  7. OGGIE50
    OGGIE50 Member
    94
    42
    San Diego
    Have 8mm fronts / 15mm rears
    Installing 20mm and. Sending the 15mm to the front. Stay tuned.
    iPhone ?
    Justdidit likes this.
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Looks familiar! :)
  9. JC91006
    JC91006 Senior Member
    16,759
    8,562
    The bigger wheels look so cool on the Gen2. I need some wheels!!! Pronto!
  10. OGGIE50
    OGGIE50 Member
    94
    42
    San Diego
    Rears installed. My torque wrench decided to take a crap. Will get fronts on after I get another one.
    iPhone ?
  11. OGGIE50
    OGGIE50 Member
    94
    42
    San Diego
    Returned under warranty the harbor freight torque wrench now on to the spacers.
    Had 8mm fronts and just need a small push out.
    15mm front & 20mm rears.
    Now the front sits flush and the rear needs another push out. Still torn as I might need 25mm.
    What you think???
    iPhone ?
  12. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    I think Toyota should have put touring wheels on all of em. they look way better than the 15"s.
    looks good as long as they don't rub.
    Daves09prius and OGGIE50 like this.
  13. OGGIE50
    OGGIE50 Member
    94
    42
    San Diego
    No rubbing at all. Although I may want to go with 25mm rear but that might rub.
    iPhone ?
  14. sidecar
    sidecar Member
    342
    45
    Australia
    In the world of vehicle modification 'rolling' the fender lip is common.
    It makes more room to push the wheels out further and offsets rubbing as a problem.
    There are tools you can buy to do this, but there are plenty of youtube vids on DIY methods without
  15. 69shovlhed
    2,170
    751
    Delaware
    yeah. rolled the chevelle with a comma dolly and body hammer, but that was before paint. I don't think its worth possibly damaging the paint for a wider spacer. now if you were gonna try and shoehorn some 235/35r18 tires in there...
  16. sidecar
    sidecar Member
    342
    45
    Australia
    people get away with it by warming the panel with a hair dryer
    without cooking the paint, just softening it so as not to crack it
    the rolling can be done with a round wooden handle
    the 'proper' tool to do this does a brilliant job
    and can roll the lip a little at a time, so that nothing unsightly happens'
    but they cost $120-$150 on ebay
    #56 sidecar, Sep 28, 2014
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Pretty sure rolling won't fix the rear rubbing. He would need his fender pulled or have the rear bumper screw moved as that is what rubbed on my 30mm spacers over big bumps. The fender was never an issue on front or rear...just the bumper screws.
  18. willamuro
    willamuro Junior Member
    San Jose, CA
    Does anybody have a picture that they could post of a 2nd gen with 1 inch drop that has stock NON-touring 15 inch rims? I am seriously considering dropping my 2005 Prius, but I am afraid it'll look funky with the smaller 15 inch wheels. Thanks!
  19. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    How about lowered more than 1 inch.... ?
    Fr3do likes this.
  20. OGGIE50
    OGGIE50 Member
    94
    42
    San Diego
    Tanabe USA R&D Blog | All posts tagged 'toyota-prius'
