Adding an additional fan to the Traction Hybrid Battery?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Prius_Boriqua, Aug 25, 2014.
  1. Prius_Boriqua
    Prius_Boriqua Junior Member
    17
    Phoenix, Arizona
    Hello guys!
    I've spent the last month reading up on recommendations to help your traction battery last longer and operate more efficiently. Heat is battery's enemy. I already took the battery cover and fan off to clean it as the car had dog hair from the previous owner. I wanted to make sure the fans and battery were clean. I used my air compressor to clean out the battery and took a brush to the fan. There was hair but not much. More dust than anything.
    Anyways I was thinking of adding another fan to the hybrid cooling air duct for summer use (Phoenix AZ temps are usually 105-110F). Something like this:
    The idea is that this fan would sit in the duct with the cable routed under the back seat connected to a usb->lighter 12v inside the middle console. This fan would aid in cooling the traction battery especially when you turn on the car for the first time. It takes the AC a while to cool off the car in the summer so this could help.
    Has anyone here tried this? Any drawbacks?
    I have also thought of routing the floor A/C vent to the Hybrid vent.
    Let me know what you guys think!
    Fernando Gil, GG707 and AzusaPrius like this.
  2. gliderman
    gliderman Active Member
    751
    225
    You need to first check the air flow volume and make sure that the modifications you are making do not actually cut down on the air flow. Running a duct from the A/C to the inlet is a non starter. You dont always run the A/C and the A/C is not always running when you have it on. Yes it could help on very hot days, but hopefully you are running the A/C anyway to keep the cabin cool and the battery will utilize whatever cool air it can find. So nothing different is required.
    But there may be ways to better redistribute the airflow around the battery and possibly add additional intakes and fans. All will be consuming power and my not be of any added benefit in the long run.
    But let us know what you do and how it works out.
  3. Prius_Boriqua
    17
    Phoenix, Arizona
    I installed the additional fan about 2 weeks ago. First let me show you the tools.
    Total: Estimated $50.00
    Goal: Lower the traction battery heat by providing additional cooling. This will also aid the traction battery cooling by not having to run the air conditioner colder to keep the traction battery cooler. I like to feel comfortable in the car not frigid. This alone will boost MPG's. The fan will also aid in pulling cooler air into the air vent so more cooler air reaches the battery faster. One of the most important features is when you turn your car off you can leave this fan on for a few minutes so that it continues to cool your battery down. The cars traction battery fan doesn't do this as it turns off right after you turn your car off. Heat is the hybrid batteries enemy so this is a plus.
    Details:I decided to buy a battery pack so I wouldn't use any of the cars power for this. The cables are tucked underneath the back seat, into the side rails, back out from underneath the passenger seat up to the middle center console. The fan is mounted externally. I can mount the fan internally which would make it completely clean but I want to make sure I can see the fan just in case it would happen to fail. Eventually it will mount inside the air vent. In the future I will route the cable underneath the rug and will make a small hole to route the cable through the center console just to make it cleaner.Fan noise is minimal. I can also adjust the fan speed. The battery has lasted the whole 2 weeks on 1 full charge. Im still at 50% power running the fan at full power.
    Test: Phoenix AZ to Flagstaff AZ. About 300 miles round trip. Elevation that was climbed was equally lost coming back. Estimated 1,100 ft Phoenix and 7,000 Flagstaff (about 6000 ft difference. Same gas. Speed 65 Miles per hour except down hills were I glide. First trip without the fan 50.2 Mpg's. With the fan 53.4 Mpg's. Any variables i could have controlled I did. 2011 Prius III Hatchback 40,000. Tires are shitty Primewell Valera at 44 PSI front and back (came with the vehicle).
    Outcome: Very happy with the results. I gained a bit over 3 Mpg's on this trip. As you can see in the pictures and videos the air flow is strong. I tested this with both the car off and also with the car on. The airflow which is passing through the inlet vent, battery and the the outlet is still strong enough to blow out a lighter. I really like that I can cool the battery faster when the car is off after using it for a while.
    Alright.....You guys can start the bashing now....
    P9080017.JPG P9080019.JPG P9080020.JPG P9080021.JPG P9080023.JPG P9080026.JPG P9080027.JPG
    By the way I have videos of this but I cant figure out how to load them.
    Thanks
    #3 Prius_Boriqua, Sep 8, 2014
  4. Mike500
    Mike500 Senior Member
    2,593
    767
    Simpler would be mounting a fan in the trunk floor panel right near the left front wheel well behind the passenger seat and plugging the fan into the cigarette lighter power outlet in the rear panel.
    This would pull the air coming from the current OEM fan across the HV battery compartment, where it does the most good.
    Just make sure to check the input of the OEM fan to make sure that it is clear.
  5. Prius_Boriqua
    17
    Phoenix, Arizona
    It wouldn't work nearly as well. You would have to somehow fit a fan in the outlet vent for the battery which is too narrow. Also putting a fan anywhere in the trunk is inefficient as there too much air to move. It would be pulling air from all directions instead of concentrating its power to only pull air from the battery. Its easier to push air in the battery than pull air out because of the battery vent designs. Using the 12V cigarette lighter outlet doesn't work as the outlets turn off when you turn the car off eliminating the benefit of cooling the battery when you turn off your car. You can probably modify the lighter outlet so it is always hot but then you run the risk of depleting power from you 12V battery if you leave it plugged in. The 2011 Prius III doesnt have a 12V in the rear panel.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I am impressed these guys have done airflow studies in their own wind tunnels, so know more than the emgineers that designed the car.
    Oh, wait...
  7. Prius_Boriqua
    17
    Phoenix, Arizona
    Thank God there are not any recalls to date right..those engineers get everything right from the start.....even when you get the recall done a new problem arises... The fan on the car is made to fit a balance of efficiency and low noise. Seems to be it favors low noise over keeping the temps low.
    Panicos and Sezy like this.
  8. motoleon
    motoleon Junior Member
    48
    spain
    I control the hsd vent speed via ODBII command. It is a propietary program (mine), that monitors trac. battery temps and controls de vent speed.
    GG707, swapper and SFO like this.
  9. Mendel Leisk
    41,947
    ^ Why do you want to manually control the fan speed? I'd assume to run it a bit faster for a given battery temperature?
  10. motoleon
    48
    spain
    YES, now it blows at lower temperature, and maintain best thermal control over tracc. batt. I have a little windows pda that controls automaticaly that and other things...
    mrbigh likes this.
  11. motoleon
    48
    spain
  12. mrbigh
    3,686
    699
    Long Island, NY
    And you've waited more than a year and a half to let us know of your courage and achievements?..:whistle:
    Y has esperado mas de un año y medio para dejarnos saber de tu audacia y logros? :whistle:
  13. motoleon
    48
    spain
    I am one of the members of the forum mitoyotaprius.com more tests been done to the prius, some failed and others made successfully. Some rather complicated for a normal user. Everything is in Spanish on our forum. Even a company has been interested in my accomplishments, but had no luck. In Spain we are in economic crisis. If you are interested in any of my projects, you can email me.
  14. Prius_Boriqua
    17
    Phoenix, Arizona
    Quick update. Its been a month since I installed the fan. Before my avg was 50-51 mpg's. Now its 53-54 mpgs. The temps are still in the 100's here in Phoenix, AZ. I havent changed anything else on the car that would help boost the numbers. I really think that the extra cooling works.
    One thing to notice is that I leave this fan on running at least 30 minutes after I turn the car off to help cool off the battery faster. If Im doing short trips where Ill get back in the car in 15-20 minutes I just leave it on. Ive read threads in the Priuschat community where the excessive heat will prevent the battery from charging fast (even drain it a bar or 2). The normal fan stops cooling when you turn off the car which leaves the battery "cooking" in heat. When you get back to your car the battery is hotter than when it was on 15 minutes ago. I beleive that aiding the cooling post battery operation helps it cool faster keeping it in a better charging enviroment for the next time you turn on your car as well as when you use the car in EV mode. A cool battery (not cold) will operate and charge better.
    Ive been doing the same 50 mile route everyday. The only change is that I routed call the cables under the rug and made a small hole inside the center console to keep the portable battery in there. The fan is no longer at the exterior of the vent. I moved it inside the vent and removed the metal covers. I can charge the battery in about 8 hours with a 3.5 amp charger and it will last me about 2 weeks of everyday use. If you have questions let me know. I can provide pictures if necessary.
    Robert Holt likes this.
  15. KennyGS
    KennyGS Senior Member
    1,243
    1,045
    Keystone State
    So if you're driving 350 miles per week, this will save you $1.34 on gas - disregarding the cost to charge your portable battery.
  16. Prius_Boriqua
    17
    Phoenix, Arizona
    Hi Kenny
    Using your example would equal about 5 bucks a month granted I drive more or less (10 months to pay itself off). By the way wouldn't it be nice to save an extra 5 bucks of gas when you fill up :) ? This modification wouldn't make sense if your keeping your car for a short period like a lease. But what if your planning on keeping it for the next 8-10 years? Prius owners in this forum (those that are planning on owning their cars for a long time) change the transmission oil every 30,000 miles just to give them a piece of mind that their transmission wont give them issues in the LONG RUN. Isn't that a huge jump vs the 100,000 miles Toyota recommends? What about the benefits of keeping your hybrid battery in better conditions? Doesnt that matter? Doing what you can to keep your battery functioning beyond 250,000 miles. Fuel savings aren't the only things we are looking for. We are looking for anything that will make our vehicle run like new for longer. In this case keeping the battery in best shape possible to make it last longer. From this long term point of view it makes good sense.
    Threej likes this.
  17. BigBear2010
    BigBear2010 Member
    156
    65
    I'm very interested in your project. I drive 1500 miles a month :D. I wish I could read in Spanish b/c the link you give us above only in Spanish :/. Keep update
    Thanks,
  18. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    IMO the extra cooling and cooling after the ignition is off are key advantages.
    But would a small 12-volt rechargeable battery sufficient to run 30 minutes and rechargeable through the 12-volt port while driving also work?
    I was thinking 10 1.2 volt AAA NiMH batteries in series might power that fan for 30 minutes (or maybe AA size). I just don't like the hassle of taking out the battery to recharge it as I or DW may forget to do so.
    But I monitor HV battery temps with a Scanguage and can absolutely vouch for that post-shutdown "heat soak" that occurs in the summer--I have seen temps at restart as high as 50 degrees Celsius.
  19. Prius_Boriqua
    17
    Phoenix, Arizona
    Charging it isn't the bad part for me. The bad part is remembering to go back to the car and turn it off after 30 minutes. Sometimes I forget and its on for a few hours. Still the battery last me more than a week on a single charge. It all depends on the battery you decide to buy. I'm convinced its efficient so I'm keeping the fan installed.
  20. Mendel Leisk
    41,947
    I've noticed this, since adding battery temp XGauge to my ScanGauge. We'll drive somewhere on a hot day, battery temp slowly climbing. Park somewhere in full sun, come back twenty minutes later, start up, and battery temp is much higher. Maybe the solar roof helps with this.
    Seems to me too, the more open the ducts are, to and from the battery, the more simple convection currents could pull heat off the battery. I had a filter at the inlet, but have taken it off now, with that aim.
