MFD Blank and Unresponsive, Replaced 12v battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priuszzz, Sep 12, 2014.
  1. priuszzz
    priuszzz New Member
    New York, New York
    I have a 2008 Prius, MFD died one day, screen completely dark and all buttons on it are unresponsive. I used a voltmeter to check the 12v battery which had troubles last winter (had to jump it once) and it was at about 10.6v so I just replaced it with an Optima battery. Sadly the MFD is still blank.
    The MFD actually came on for a second a couple weeks ago which led me to believe it was still functional and just not getting enough power from a failing 12v.
    Does it take a while for a brand new battery to fully recharge and could that fix the problem or is something worse going on? Could it also be a blown fuse somewhere? I'll feel very dumb if I got a new battery for nothing but it needed to be replaced anyway I think.
    If it is a fuse, is there a simple guide I can follow to find the bad one? What I've read so far is pretty confusing regarding the fuses.
    I also noticed in the Common 2G Problems thread there is a mention of a strange noise on startup that can be fixed if the car is under powertrain warranty. I do hear a strange noise sometimes like a sucking squealing when I turn on the AC, is this the same thing?
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    No not really.
    But it appears that you HAVE a voltmeter.
    Use it.
    It is possible that your charging system (inverter) is failing.
    Your display problem likely is a bad connection, either inside the display itself or the wires feeding it.
  3. JC91006
    JC91006 Senior Member
    16,738
    8,550
    What's the reading on the new 12v you installed?
    The noise you are referring to at start up and shut down is the pump that fills coolant to the thermos. I don't think it's an AC related noise. If that pump is making noises, there was an extended warranty for that pump but not sure if that's still valid in your case.
  4. priuszzz
    priuszzz New Member
    New York, New York
    I haven't checked it yet, just installed it today. I'll check it and see if it's where it should be. Should I run it for a little bit to fully charge the 12v or should it be okay to check as it is? I only drove it about 5-10 minutes after it was installed.
  5. JC91006
    16,738
    8,550
    The new battery should be no lower than 12.5 volts, if it is, it might give you problems down the road. A fully charged battery is 12.9 volts.
    There have been many people complain about the initial charge on the new Optima batteries. Some are installing batteries that come under 11 volts when new. That's almost a guaranteed disaster waiting to happen.
    I don't think that will fix your MFD but strangely enough there was a member that complained about the MFD and a new battery fixed his problem.
  6. jdenenberg
    jdenenberg EE Professor
    3,938
    1,936
    Trumbull, CT
    2020 Prius
    LE AWD-e
  7. priuszzz
    priuszzz New Member
    New York, New York
    This is weird, I tried to check the battery using the jumpstart point under the hood and I'm not getting anything at all. Am I doing something wrong? I tried the voltmeter on another battery and the voltmeter is working. I put the red probe on the positive jump terminal (looks like a screw thread sticking out) and the negative on the flat terminal above it. Getting 0.0v.
    The car starts and the lights all go on.
  8. JC91006
    16,738
    8,550
    The negative should go on an unpainted part of the engine or body of the car
  9. priuszzz
    priuszzz New Member
    New York, New York
    Finally got it working, I'm getting 12.38v. Is that acceptable? Just got it shipped here and only drove 5 minutes after install. Just for fun, checked my old battery and it's 10.77v.
    Should I start checking fuses and do you have a guide or link on which fuses to check?
  10. JC91006
    16,738
    8,550
    It's below the threshold of 12.5 volts as a minimum. But it's pretty close at 12.38v. If you get a chance, charge it up to 12.9 volts. Keep the receipt, you might need the warranty later if it becomes a problem.
  11. Mendel Leisk
    41,012
    And positive on the flat copper post ( with red flip up cap), in the fuse box.
    Ok, you got it.
  12. priuszzz
    priuszzz New Member
    New York, New York
    I'll drive it around a bit and see if it just needs a little more charging. I'm still holding out hope that the MFD is still working and just needs more power to start.
  13. JC91006
    16,738
    8,550
    I believe you need a replacement MFD. The battery has sufficient power and shouldn't be the cause of the MFD not working. Out here in CA, I've seen them for about $100 used.
