2014 PIP vs 2015 PIP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by getinthecar, Sep 14, 2014.
  1. getinthecar
    getinthecar Junior Member
    Seattle, WA
    Is there a major difference between the 2014 and 2015 PIP?
    I notice some dealerships are providing 0% financing but I wasn't able to find the technical specs on the 2014 model now that their 2015 is out.
    Thanks,
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Lol, I need a new username, getinthecar
    getinthecar and Potorap like this.
  3. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Shouldn't be any differences. Go with the one you get the best price on.
  4. El Dobro
    El Dobro A Member
    7,090
    3,270
    Get the one you can, there's none to be had out here. ;)
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    2015 PiP is about 50 lbs heavier. Reportedly, they added reinforcement for the new crash test.
  6. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    And yet, the 2015 non PIP has the same weight as the 2014 non PIP.
  7. getinthecar
    Seattle, WA
  8. getinthecar
    Seattle, WA
    Sorry for this bump, but one last question. Basically 95% ready to buy the 2015 PIP, already had a credit check with the dealership but can someone confirm if it qualifies for the 2500 tax rebate or it will? I'm looking on the site here: fueleconomy.gov/feg/taxphevb.shtml and it doesnt mention the 2015 model, I'm guessing perhaps because it hasn't been updated yet?
    The dealership said they actually are not completely sure.
  9. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    There's no reason why it would not qualify, but as you guessed, the certification process may not be complete yet for the 2015. You should be good. There's a phase-out after Toyota sells 200,000 plug ins, but they would not be anywhere close to selling that many plug ins.
  10. 7-0-SAV
    7-0-SAV Junior Member
    2014 Prius Plug-in
  11. markabele
    5,084
    1,782
    Nebraska
    As long as you have enough income, you should get the 2500.
