Half if Dashboard is Off. Help!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by unit333, Sep 15, 2014.
  1. unit333
    unit333 Junior Member
    77
    NYC
    Hey guys
    The right section if the dashboard which has all of the car related graphics and mileage won't turn on anymore. Nothing else is wrong with the car. Assuming this is a battery/fuse/wire issue? Hopefully not a dead display. Anyway for me to figure this out on my own before the painfull process if going to the dealer? Any recommendation will be greatly appreciated and photo is attached
    51,851
    your on the right track. start with the low hanging fruit. 1)fuses, 2) battery, 3) wiring, 4) display. maybe run it by your service advisor to see if there is a tsb on the display. all the best!(y)
  3. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    I looked at a 2010 used prius that had a blurry display. Not sure what was wrong with that one. I wouldn't think the display has more than one power supplied to it. So, if half is working then it probably has power. But you never know. Hopefully it is only a connector partly off or loose.
  4. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Nothing laying on the dash in front of the display ?
    When my 2010 was only a few weeks old, we drove to an advertised event, all seemed normal . afterwords, we started the Prius and drove away, noticed OH CRAP, the right half of the dash is out ? Was thinking a trip to the dealer when I noticed the little poster advertising the event,laying on the dash, slid right up to the display screen, where it was blocking the light from under the display. Lifted that poster off the dash and all was well again.
    Until that, I did not realize that the dash display was a bottom projection widget :)
  5. ramattos
    ramattos Junior Member
    57
    Bethlehem PA
    Not to be a smart a, bit did you try the disp button on the wheel? Someone might've just turned it off
  6. unit333
    77
    NYC
  7. anestis
    anestis Junior Member
    Oraiókastron, Thessaloniki, Greece
    My 2010 mfd off and dealer says 1931 euro, and before two months hybrid battery dead 2500 euro,Very good car!!!
  8. bisco
    51,851
    excellent!!!(y)
