Performance differences between Prius's in different Country
Discussion in 'Gen 2 Prius Main Forum' started by davidbw, Jun 4, 2004.
  1. davidbw
    davidbw Member
    110
    29
    In front of my computer
    I have a friend visiting from Japan. He drives a Prius at his home as well.
    He subjectively tells me that he thinks his performance on freeways is better on his Prius, but mine goes up hills better. Are the Prius's designed differently for different countres?
  2. davidbw
    davidbw Member
    110
    29
    Judging by the other postings I have a feeling I am going to be asked to ask him about the EV button.
    He did not know that it existed until I showed him this web site.
  3. Ken Cooper
    Ken Cooper New Member
    339
    I would bet that the final drive gear ratio on Prius cars sold in Japan is taller. The gas mileage inputs from Japan, as posted on this forum, are virtually always higher than gas mileages posted here by the rest of us.
    The taller final drive gear ratio would explain both your points as well as the overall gain in gas mileage.
  4. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Do they have the same wheel diameter? That would be the same as changing the drive ratio.
  5. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Also remember that they don't have the sprawling interstates that we do, so I'm more inclined to believe that their mileage is more city-based.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    There is no drive gear to ratio. There may be variences in top RPM or how much the MG2 contributes in the programming, but no gears exist other than those in the planetary drive system and those are identical.
  7. Tempus
    1,690
    Washington DC
    Evan, I think there are gears that connect the planetary shaft to the drive shaft, but they are fixed ratio. 4.3? Not sure.
    So, as people always say, the prius is always in the same gear :)
    That's the one he's talking about changing.
  8. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Off the PSD there is a chain driving an intermediate gear that drives the differential carrier gear and these could be easily altered to change the final ratio.
  9. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    Is their engine size even the same?
    Anyways I get much better gas mileage on the highway than in the city. Traffic here in Toronto is stop-and-go, and I suspect the same in most Japanese cities.
  10. Ken Cooper
    339
    Hi Danny,
    Having driven the roads in Japan, I would not come to believe that the types of roads represents the difference in gas mileage.
    Tell you what, let's put this in the form of a bet. If it turns out that there is absolutely no difference between the final drive of the U.S. market Prius and that of the Japanese market Prius I'll stop bugging you to allow my little 100 x 53 20.8 KB picture to show up in my posts. On the other hand, if there is any difference at all between, say, the ratio of ring gear RPM to wheel RPM between the two markets, you allow those very slightly more dense 20.8 KB pictures. Okay?
    On the serious side, reducing my uncomplicated picture to 100 x 53 using standard settings on Adobe Photoshop results in that 20.8 KB pixel density. Now I suppose there are advanced techniques for maintaining diminsions while reducing density, but your forum for the common man shouldn't, IMHO, require those kinds of special efforts.
    Regards,
    Ken
  11. Frank Hudon
    4,147
    In the Classic the final drive ratio is 3.905 to 1 from the PSD to the wheels. Just found it in the 2K4 it's 4.113 to 1
  12. davidbw
    davidbw Member
    110
    29
    Another question:
    I don't know whether I should put this in an other thread.
    I spent three months in Japan, and of course was with my friend while he was driving my Prius. At night when he would stop at a traffic light he would turn off his headlights, and after someone would stop behind him, he would turn off the remainder of the lights. Of course he would turn them back on when he started driving again. I noticed drivers when I was in Japan would do the same. He said that it saved energy, and it was being polite to the driver who was ahead, by eliminating the glare. I have never seen anyone in the USA ever do anything like this barring when I visited Seattle and was told to turn off my headlights during the boarding of aferry even during night.
    Is there any significant energy saving. I of course would be afraid of not turning the headlights back on on a green light.
  13. Tempus
    1,690
    Washington DC
    I think if you did that in the US you'd be likely to get a ticket.
  14. siai
    siai Junior Member
    Florida Keys
    Of course there is an energy savings--It takes power to run the lighting system on the car. However, the HID headlamps do not like to be turned on and off (that's part of the reason the high beams are just the low beams with a shroud removed). Somewhere (possibly on this fourm) I read a report about how many millions of gallons of fuel would be wasted each year in this country if all vehicles had DRL's (daytime running lights) v.s. no vehicles with DRL's. The number was amazing! :eek: Personally, I dislike DRL's.
  15. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Hmm, so me using my high beams to flash cars that want to merge in is bad for my bulbs? I usually flash twice in succession as a signal.
    I also use them vs. the finger for those who discourteously change lanes unsafely in front fo me in an unsafe manner, or to make my presence visible in others mirrors if I feel they're going to possibly maneuver in front of me (defensive driving).
    That being the case, would be nice if I could flash the fogs instead :)
  16. victor
    victor New Member
    414
    Gilching Bavaria Germany, & Drapanos, Crete, G
    The problem here is you are using the same signal for opposite meanings.
    1st Flash to say "Please merge in front of me"
    2nd Flash to say "Warning - dont merge in front of me"
    So Flashing is not a good idea. Look at it another way. You flash to say "Im coming through" but the other guy thinks you mean "go ahead". Result Crash.
  17. Ken Cooper
    339
    Flash code:
    1 Flash .. Oncoming car's bright lights are on.
    1 Flash .. A truck is passing you, he needs to know when it's safe to pull in front of you. You tell him with a single flash after he's passed by a distance that's safe for pulling in. He'll typically thank you by flashing his rear lights.
    2 Flashes .. You're warning oncoming traffic that there's a cop laying in wait.
    3 Flashes .. You're telling oncoming traffic to slow immediately .. they're approaching an accident.
  18. victor
    victor New Member
    414
    Interesting. We dont have that in Europe, and the English Highway code specifically recommends against flashing.
  19. rdverb
    rdverb New Member
    49
    Monterey, California
    I think these are open road practices. City dwellers may completely misinterpret them. NY drivers use their horns instead of their lights to communicate.
  20. HTMLSpinnr
    5,341
    920
    251
    Hmm - I use the opposite. One flash is enough to let them know I'm disatisfied. Two is trying to get their attention to move on in. Most of the time it's interpreted correctly when I double-flash and people slide on in.
    Since there's no formal law, I'm not sure one way is more correct than the other.
