Corroded AC wiring harness 2010 - anyone heard of this?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius-Alfa, Sep 15, 2014.
  1. Mendel Leisk
    41,909
    Got the bugger. Man those connectors are unfriendly. Ours looks pristine. Think I'll just leave it as is.
    kc410 likes this.
  2. Prius-Alfa
    Prius-Alfa Junior Member
    22
    Seattle
    I want one like that. Without having to buy an entire compressor.
  3. Prius-Alfa
    22
    Seattle
    So I just got back from talking with a Toyota specialist who works independently of any dealers. He used to be a mechanic at a Toyota dealership. He's never heard of this kind of problem before. He doesn't buy the low mileage allowing build up of moisture and corrosion theory, but doesn't know what would have caused it. He's going to see if he can do anything to repair the connection on the compressor so that the whole unit doesn't have to be replaced. Maybe he can remove the receptacle from the compressor housing and make a repair. He was surprised by the dealer's recommendation to change out the wire harness. Probably them just covering their butts against any future problems associated with their work. The car goes in tomorrow. More to come.
    mertechperformance likes this.
  4. bisco
    52,393
    all the best!(y)
  5. Den49
    Den49 Member
    498
    272
    Maryland
    The picture of your connector with the green corrosion inside the connector is quite different from the corrosion on the outside of my connector. The outside of your connector looks clean. It looks like your connector may have failed for some reason internal to the connector, like maybe a loose connection that created high resistance. That would be a good reason to replace the wire harness plug along with the connector base. Good luck and keep us posted.
    #45 Den49, Sep 16, 2014
  6. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Can you get a picture of the wire end connector? If you notice on the other picture of that connector there is an orange material visible inside it. That is the sealing material kinda like an o-ring. Is yours intact? When locked down that should be a waterproof connector as seen in the other pictures where the connector was pretty spotless inside. Yours may have been taken loose for some reason and not locked back down resealing it. The part looks like it is screwed on the compressor. One would thing it is replaceable then.
  7. Prius-Alfa
    22
    Seattle
    I did notice that orange ring in the connector on my car. I didn't examine it closely but it looked fine. You may be right that for some reason the plug wasn't seated all the way down until it was locked and the seal wasn't as tight as it needed to be. If that's the case, it almost certainly had to have had to come from the factory that way because the AC system has never been worked on before. Based on Mendel's experience described in posts above about getting that same plug to come off on his car, these things aren't likely to just come off on their own. I'll have the mechanic take a good look at the o-ring tomorrow when the car is in the shop.
  8. Prius-Alfa
    22
    Seattle
    Well, once the mechanics got a look at the inside of the connector on top of the compressor, it was on to a new compressor. They can't get inside the compressor to try to rewire the connector from within which is what it would take. Seems like a stupid design to me when a failure in a minor part like a connector can bring down a whole unit like an AC compressor. They can, however, splice a new pigtail onto the harness so at least a new harness at $722 isn't needed. Total bill: $2300.
    You guys may want to take a look at that connector on your cars and confirm that it is firmly seated and locked in place as a precaution against an expensive repair. It's easy enough to do. Remove three bolts holding the air intake box located on the front of the engine in the left front corner of the engine compartment as you stand facing the front of the car. The compressor is just below that with the connector right on top.
    Thanks to everyone here who gave their input and ideas. Much appreciated.
    johnpr likes this.
  9. Mendel Leisk
    41,909
    That's frustrating. I wonder still about it being non-repairable: the compressor side of the connection is on a plate with fasteners, albeit unusually shaped fasteners.
  10. Prius-Alfa
    22
    Seattle
    I don't know for certain, but I bet those fasteners are not intended to be taken apart. I think an effort to try to do something like drill those out and then figure out how to rewire and then close it back up would put the job into the realm of custom work with the costs and potential pitfalls that go with that. For someone who has a shop and the skills to DIY it, it might be worth a shot. If you trashed the compressor you would just be out your own time without having paid shop rates to get to that point.
  11. Den49
    Den49 Member
    498
    272
    Maryland
    Ask for your old compressor to be returned to you. If you can, drill out the rivets and take off the connector. If you can't do it, maybe another PriusChat member in the Seattle area would volunteer. If you were close to me, I would love to dissect it and see if it is repairable.
  12. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Can you get another compressor out of a salvage yard? Should be a lot less $$$. The heads look like screws to me. Special socket type that should be available. 10 to 1 there is a connector on the other side too and this part is just a sealed interface to the outside world. A socket like this one removes those types of bolts.
    #52 DaneH5, Sep 17, 2014
  13. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Some more special sockets, A female torx looks to fit the bill.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    #53 DaneH5, Sep 17, 2014
  14. Prius-Alfa
    22
    Seattle
    My history prowling wrecking yards for parts goes back to the early seventies, but I don't really feel like rolling the dice on a compressor from a salvage yard. That's just me.
    Thanks for the info on the sockets. There are two fasteners visible in the photo at the top of this page. The upper one of those fasteners is one of two on the plate that the connector is mounted on. The second one is behind the plug on the left in the photo. I think you would have a very hard time getting any grip on that one because it is dome shaped. It doesn't have good contact surfaces for the inside of a socket. I suspect its some kind of cap that's crimped onto whatever is under it, maybe a rivet. That's why I was thinking it would have to be drilled out.
  15. Mendel Leisk
    41,909
    The big question in my mind: even if you manage to remove those fasteners, how to replicate the damaged broken pins. Maybe you can get pins from an electronics supplier, do some soldering. Short of that: as long as there's no availability for the compressor side of the connection, you're still SOL. Which goes back to Toyota, poor design.
  16. Mendel Leisk
    41,909
    To argue with the above: to salvage the current compressor, you don't HAVE to repair the pin connection. You only need to repair the breaks in that circuit. If the wiring behind the connector can be accessed, extensions could be soldered on, and a new connector (or individual connectors for each line) could be put in, a bit away from the compressor. The entry of wires at the compressor would also need to be sealed.
    This assumes the extent of the problem IS the connector.
    Thinking more about the reason for the corroded connection pins: could (for example) someone have tried filling the windshield washer fluid reservoir without a funnel? Maybe sent fluid running down that conduit?
  17. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Most of the salvage yards give some sort of warranty. $50-$100 to try one out (price guess here) vs around $2k. I don't know where you are at financially, but $2300 for A/C is one hefty bill. And your part of the country doesn't get very hot or often does it? Of course it helps to defog windows which is a safety concern.
    I also would think it is some sort of screw or bolt for a positive retention seal rather than a rivet.
    I would also try contacting Toyota about it. Faulty seal or install! I would hate to think a car owner would be required to go through his/her vehicle to make sure all the connectors are connected properly. They watch postings on this site and you well as may not be the first with this kind of failure. I have read about some email and phone contacts available too within some of the Toyota employee posts. Consider filing a complaint with the appropriate agency so there is paper trail. Is this considered part of the hybrid system to afford the hybrid warranty?
  18. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Price from local yard $80 plus shipping.
  19. cipsaz187
    cipsaz187 Member
    150
    42
    I can't locate this connector. Where exactly is it?
  20. Mendel Leisk
    41,909
    ^ Standing at the front bumper, facing the engine, on the left side, down about a foot. A clue is the aluminum AC lines up higher. You need to take out the the air intake snorkel, upstream of the air filter. The air filter housing can be left in place. With the snorkel out of the way you can see the AC pump, it's about the size of a coconut. Has a 12 volt lead (black) connecting to the top, and high voltage lead (orange) connecting on the right side.
