How many gallons of gas does Prius v hold?
Discussion in 'Prius v Fuel Economy' started by desmondlee, Mar 31, 2014.
  1. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    Just wondering just how many gallons of gas the Prius v is suppose to hold.
    On this tank of gas, it says I have driven 540 miles with 14 miles left in the range.
    Down to one notch on the gas thing, and it is still not blinking yet.
    I went to fill up with gas and I did top off more than usual, but I did stop at 12.7 gallons. IMG_1307.jpg
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Toyota claims 11.9 gallons In 111 fill-ups, I only have one over 11 gallons: 13.1 last December. It never blinks, when miles to empty gets to about 10, an orange gas pump illuminates.
  3. Diver Allen
    Diver Allen Member
    66
    27
    Cincinnati, OH
    2013 Prius v wagon
    Yeah, I think I put in 12.9 once and I hadn't run out. I tend to go more conservative now. Then there is some talk about a bladder that might be relevant but you'd have to get someone else to explain it.
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Bladders were a Gen II thing. Not on a Prius after 2009 model year.
    m.wynn likes this.
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I have to say that if your pump is telling you it put 12.7 gal in there, its lying. That or you just filled the entire evap system with gas. Once when I had a pump that didn't shut off on its own and ran over from the filler neck, it still didn't take more than about 1/4 gal over what it usually takes (including the cup on the ground).
  6. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    Mine blinks. I would prefer that the orange gas pump would glow!
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You do not have a Prius v station wagon (this forum is for the v) you have a liftback.
  8. Jibrail Khan
    Jibrail Khan New Member
    Australia
    this is a nice forum , i am getting more information for cars.
    Thanks
  9. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    I've barely ever put more than ten gallons in my V. That was about 25 miles after the orange light went on.
  10. lester williams
    227
    68
    mississippi
    Doesn't the gas in the bottom of the tank help cool the fuel pump??? My thoughts are to never let mine get below 1/4 tank. Then again, ever since Katrina and the severe gas shortage-- I never hardly ever let mine get below 1/2 tank.
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I think you will find that on the v, 'empty' as shown on the gauge IS 1/4 tank.
    Mike James likes this.
  12. Mike James
    Mike James Camaros and Prii go figure
    142
    35
    Lincoln, NE
    we have run the distance to empty down to zero a few times. At 0 miles available I still only put 10.4 gallons in
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Sounds like an overfill to me too.
  14. sean v4
    sean v4 Junior Member
    Corona, CA
    2015 Prius v wagon
    My manual say 11.9 on the 2015 model.. and the Toyota mechanic strong urge to not over fill, bad for the car.
  15. Sony
    Sony New Member
    Us
    2014 Prius v wagon
    Well i see pretty good mpg on your v. I have 2014 v 5 and getting about 31mpg, yellow light lit up at 345 miles range left 17 miles. I drove her to come 0 mile range left and then filled her. Auto shut off on 10.4 gallons. I tried to refill slowly and i was able to fill 13.5 gallon. I looked inside the tank i it was not still end to the gas cap. I think i could fill more half gallon but i stoped at 13.5 but when range is showing 0 is not meaning your tank is out of gas, you still have over a gallon in tank. So bottom line i believe it can hold 15 gallon to full fill to gas cap.
  16. mikefocke
    3,988
    1,801
    Sanford, NC
    Running a tank to true empty can burn out a fuel pump.
  17. SZR
    SZR New Member
    Missouri
    2017 Prius v wagon
    I ran mine down to where it said I only had 9 miles to go. When I filled up it only took 9.7 gallons. Last week in Western Kansas I had 3 bars and stopped for fuel it took 10.4 gallons! I questioned the honesty of the pump, he said the state proofs it.
    Silas,,
  18. bisco
    51,846
    pump oddities?
  19. SZR
    SZR New Member
    Missouri
    2017 Prius v wagon
    Next two fill ups were normal volumes.
  20. Thunder Road
    Thunder Road New Member
    Jacksonville, FL
    I put in 13.54 gallons in my 2012 Prius v today. I drove on zero for 15 miles and was sweating it. I filled it up to the point just before the gas started overflowing.
