Speed at which the Prius and Prius C have the same gas efficiency
Discussion in 'Prius c Technical Discussion' started by kalsifur, Sep 17, 2014.
  1. kalsifur
    kalsifur Junior Member
    New York City, New York
    2014 Prius c
    The Prius has EPA MPG of 51/48 and the Prius C is at 53/46. At what speed (where the speed is higher than typical city speeds but lower than typical highway speeds) would both the Prius and Prius C have the same MPG? In other words, at what speed would their speed-to-MPG curves intersect?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I think the question that really needs answered is what is the speed at which they would be the same for an African and European unladen Prius.
  3. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    But in all seriousness, I would imagine it's somewhere between 65-70.
  4. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Totally depends on how you drive them. I would think that the same driver who drives both cars hard would have much different results than another driver who hypermiles both cars. I don't think the cross-over point is fixed, since there are other considerations like vehicle weight (inertia) and available horsepower to factor in.
    Bill the Engineer
  5. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I think what he is asking is as what speed... using cruise control on a level terrain on the highway... would the two cars intersect for MPGs. It shouldn't totally depend on how you drive them. At 70 the Prius gets better gas mileage... but at 55 the PC gets better gas mileage.
  6. kalsifur
    2014 Prius c
    Yes ztanos that is what I'm trying to determine. For now, I'll approximate the speed at which both cars have the same MPG as the halfway point between 55 and 70, or 62.5 MPH.
    Since I maintain 60 MPH on highways, the Prius would offer me no additional highway fuel savings at that speed, and may even be very slightly less efficient. Also, as a data point, I find that driving at a constant 60 MPH for 45 minutes or more yields 60 MPG, which I think of as "60 for 60."
    #6 kalsifur, Sep 18, 2014
    Brad K likes this.
  7. bisco
    52,395
    try 65 and see what happens, you might be surprised.
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    It won't be 65 mpgs, lol. It won't be 60 either. Ha ha ha.
  9. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Steady state speed for both cars. 2014_Toyota_Prius_5_-_Speed_vs_FE.jpg 2014_Toyota_Prius_c_Speed_vs_FE.jpg
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    So this is saying that the PC is more efficient at 70 mph?
  11. priusCpilot
    663
    210
    LA
    Yes but the 3rd Gen tested was with the factory 17" wheels.
    ztanos likes this.
  12. smackdownC
    smackdownC Junior Member
    56
    17
    2014 Prius c
    The liftback is def more fuel efficient on the hwy for obv reasons. I've driven both a day apart. The C tends to get into the PWR way more than the C, so at 70 mph, the liftback is a few mpg better. The C is more fuel efficient if you keep it under 65 mph, but that's tough on hwy's when the speed of traffic is 70+.
  13. Mark323
    Mark323 Junior Member
    69
    Potato Puh-tato
  14. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    it's a big if.. no info on which tires? pressures?
    FuelMax is not the best LRR, our hatchback gets considerably better MPG then PC even at low speeds. Blame low temps and tires.
  15. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Not to tell you can not recreate the same traffic condition when you tested the 2nd car.
  16. cyclopathic
    3,292
    547
    2014 Prius c
    IMHO it isn't as much about speed as it is about temperature. "C" may get upper hand when temperatures over 60F, but drop it below low-40s and Gen3 will have it for breakfast.
  17. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    You are all way overthinking this.
    The obvious answer: 0.
  18. Motov8r
    Motov8r Member
    102
    This can be overcome by grill blocking.
    iPhone ?
  19. cyclopathic
    3,292
    547
    2014 Prius c
    unfortunately no. And not for lack of trying
  20. ursle
    ursle Gas miser
    1,049
    192
    NH
    Tony is correct, amazingly
