The tree of blinking lights and error codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ystasino, Sep 19, 2014.
  1. ystasino
    ystasino Active Member
    793
    Tucson, Arizona
    P0000
    P002B
    P003A
    P001f
    P0023
    P0034
    P0043
    P0050
    First time I see an error code 7.5 years into the car. Scanguage read them and I cleared them (successfully for now)
    What should I worry about? A/C lost power a couple of minutes before the errors started blinking. No other weird behavior noticed, no recent services other than an oil change.
    Thanks a lot!
  2. Patrick Wong
    18,210
    6,514
    Exactly what warning lights appeared?
    That list does not show valid Prius codes. You need something better, Mini VCI for example.
    Check the inverter coolant reservoir for fluid turbulence when the Prius is READY. If you don't see this, the inverter coolant pump has failed and that is the root cause of your car's problems.
  3. ystasino
    793
    Tucson, Arizona
    I recall that the check engine light and the red triangle light appeared, that the lcd screen was showing a red triangle at the top, and that the cabin lights and headlights dimmed. All that happened in ready mode.
    thanks again!
    #3 ystasino, Sep 19, 2014
  4. bisco
    52,397
    how many miles on her?
  5. ystasino
    793
    Tucson, Arizona
    ~69,000. This morning there were no lights, but this liquid had minimal flow/disturbance when I looked at it. I think there was a recall on this pump?
    Can I drive her 5 miles a day for a week or so before I fix it?
  6. FazilHussein
    FazilHussein Member
    71
    36
    Perth, Ontario, Canada
    Pump's shot; should look like a bubbling stream in there.
    Yes, there is a TSB for the coolant pump...read here:
    Luscious Garage | Blog | Prius Code P0A93: Inverter Water Pump Failure
    Any miles a day like this is a bad idea....overheat the inverter = $xxx repair bill if you DIY, or $xxxx bill at the shop.
    Faz
  7. ystasino
    793
    Tucson, Arizona
    Says until 2013, sounds like I have to pay for this...
    They quoted me $150 parts and $450-500 labor!
    #7 ystasino, Sep 19, 2014
  8. FazilHussein
    FazilHussein Member
    71
    36
    Call your local Toyota dealership and confirm; push come to shove, DIY:
    Part's about $100...
    Toyota Factory Genuine Prius Hybrid System Water Pump 04 05 06 07 08 09 NEW | eBay
    You'll also need 1 gallon of SLLC; $40ish at the dealer....or reuse the old stuff....
    I do believe you have to bleed the system before a drive....
    Bleeding inverter coolant system. | PriusChat
    Also, order yourself a Mini VCI:
    V8 10 021 16 PIN Mini VCI TIS Techstream Diagnostic Scanner FOR Toyota Cable | eBay
    Best $30 you'll spend if you intend to keep your Prius.
    Faz
    #8 FazilHussein, Sep 19, 2014
  9. FazilHussein
    FazilHussein Member
    71
    36
    Sounds right....$100 diagnosis, 2hrs shop time, 1/2 bleed x $120/hr = $400 + part
  10. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    The Youtube video is entertaining & scary:
    0:34 - begins to describe the two cooling systems (ICE & Inverter)
    0:46 - says Inverter cooling loop cools Inverter and Hybrid battery in the back.
    YES, Inverter loop must be bleed. Author doesn't state this or show this being performed, just drives off.
    He did a good job swapping out the inverter pump with minimal removal of stuff.
  11. Patrick Wong
    18,210
    6,514
  12. ystasino
    793
    Tucson, Arizona
    I need to drive it 11 miles to the nearest shop, is there any way to make that drive less dangerous for the inverter?
  13. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    I went to a Toyota dealership 27 miles from my home when the inverter coolant pump failed on mine. Luckily the LSC was still active and it didn't cost me anything to get it replaced except my time.
    My pump failed in Sept 2012. I drove to the dealership no faster than 45 mph in the early morning to make sure I didn't overheat the inverter. The temperature was about 55°F that morning if I remember correctly. Since you're in Hawaii, it doesn't get that chilly, does it? In that case, you might want to have your Prius towed to the dealer on a flat bed if you don't want to DIY.
    The next time the inverter coolant pump fails on mine, I will DIM.
  14. Patrick Wong
    18,210
    6,514
    You could try putting a bag of ice on top of the inverter and drive early in the morning when the ambient temp is lower. The ice might do nothing for the inverter but would make you feel like you tried.
    I assume that you won't be driving at a very fast speed.
  15. ystasino
    793
    Tucson, Arizona
    hmm, no not fast speeds, 35 mph but there's elevation.
  16. jadziasman
    1,355
    488
    District 6
    Elevation might be a problem since the HV battery might have to assist the ICE.
  17. ystasino
    793
    Tucson, Arizona
    Towed it 12 miles ($90) and fixed it (with new liquid, $380). Many thanks for the good advice. It's the second replacement (first was under warranty).
