please recommend a trahsmission fluid pump
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lester williams, Sep 19, 2014.
  1. lester williams
    227
    68
    mississippi
    I have decided to change the ATF in my own 2014 HB as well as in G/F's 2012 ''v'' myself, and I am not familiar with ''good'' pumps to re-install the new fluid. I am sure some of you guys have found some that work really well-- or better than some others. I did Google ''transmission fluid pumps'' and found several, but I do have enough smarts to know all are not equal. There is a small repair garage local that I can rent the lift on for 30 minutes to do this, a pump would be simpler to replace new fluid with, instead of funnel and hose, to me it seems---TIA.......
    52,460
    i don't recall anyone here using a pump, could be wrong though. 4 qts isn't that much to have to pour in.
    Fostel likes this.
  3. Mendel Leisk
    41,981
    Even on a hoist, you could just raise it modest amount, use funnel and hose. Main thing: it is very simple easy method.
    Fostel likes this.
  4. Mike500
    Mike500 Senior Member
    2,593
    767
    I have pumps, but I decided to use a funnel, which was better. A 30 inch clear vinyl extension tube from the plumbing department for under a dollar at Lowe's is all that you need. 1/2 inch OD is better than the 5/8 that some has used. The smaller tube allows air to vent in the fill hole.
    Fostel and robertmaria like this.
  5. lester williams
    227
    68
    mississippi
    Well, I guess pouring it in with a 3/8'' hose and funnel would be fine--- if I had it level on jack stands and a helper. I am having knee surgery Oct.9th for a torn meniscus tendon,,, and don't really want to get into that now. It would be much easier to drive it on a lift and pump the ATF back in, as shown on Toyota's TSB [ of which I have a copy ]. Besides,,, a pump would be less costly than buying jack stands....[ I do have a floor jack ] I was just hoping someone had used the pumps, and could steer me in the proper direction. I have $460 worth of ''points'' on my Lexus C.C to go to the local Lexus dealer and get the WS ATF with, so no cost out-of-pocket for ATF. I got 4 of the crush washers in Lakewood, Co last week when I had my 10,000 oil change, during our trip.
  6. lester williams
    227
    68
    mississippi
    OK,, maybe I will re-think this,, it appears that someone would need to hold the 3/8'' ID [ 1/2'' OD] hose in the fill hole while someone else poured the ATF into the funnel. The dealers around Jackson, Ms start at $169-- $250 for a change of ATF--- and swear they ''need to flush it''------BS! I really do not feel like doing this with a troublesome sore knee, but HEY!, a man gotta do, what a man gotta do--- especially 70 yo retired men that are not totally cripple.
  7. Mike500
    2,593
    767
    This funnel is available everywhere. WalMart, Advance, Pep Boys, O'Reilly or Auto Zone carries them.
    Cut off the tube a couple of inches from the tip of the funnel, lube it with transmission oil and insert the 1/2 OD tube.
  8. jjPrius
    jjPrius Junior Member
    68
    22
    Southern California
    I purchased a 1 gallon pressurized garden sprayer and cut off the mister tip. I then added the four quarts in the container and pumped the handle to pressurize the fluid. I slipped some clear tubing over the end of the rigid tube of the pump and secured it with some cable ties. It worked great.
    tweedle99 and DadofHedgehog like this.
  9. bisco
    52,460
    ingenius!(y)
  10. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Most auto parts stores sell a pump that goes right into the quart. I found this to work really good to fill the trans back up.
  11. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    That's what I bought. This oil isn't thick and heavy; anything that can pump water could pump this stuff.
    Fostel likes this.
  12. lester williams
    227
    68
    mississippi
    OK,, ended up getting a pump that sort of looks like a caulking gun, you draw the fluid in and push the t-handle to fill the transaxle. I got a case of WS ATF this morning and have the lift reserved for 7:30 Sat AM. Guess I will see how it goes. I will do G/F's first, then mine at the same time.
  13. lester williams
    227
    68
    mississippi
    Changed the ATF WS this morning--- the little pump worked fine. It doesn't hold but a pint, so it takes two passes at the quart bottle for the quart. However, it did work fairly well, not too messy, good for another 50,000 now.
    Fostel and Mendel Leisk like this.
  14. bisco
    52,460
    congrats!(y)
  15. Den49
    Den49 Member
    498
    272
    Maryland
    Next time you may want to consider this if it is in your budget:
    1740 POWER FILL PRO 1.5 gallon
    I find it very useful now that I have two cars with CVTs. It is much faster, easier and cleaner than a hose/funnel or the cheap hand pumps. I especially like the air valve that lets you pressurize it with an air compressor.
  16. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    In my experience, pump = one person job, funnel = two people job (one at top, one at bottom). I am impressed by the other ideas here.
    Fostel likes this.
  17. Mendel Leisk
    41,981
    You could do funnel and hose by yourself, by just sticking to 100 cc shots, once you've put the first 3 liters (or qts) in. You'll eventually overshoot a little, and it'll drain back out. But yeah, it's easier with two people.
    I like funnel/hose because:
    1. It's dead simple, no mechanical hassles.
    2. You might be tempted to use a pump for other applications, with other fluids. Best not to.
    Fostel likes this.
  18. Den49
    Den49 Member
    498
    272
    Maryland
    Mendel,
    You left out your third and entirely legitimate reason:
    3. It is cheap and I either don't have the money to spend or would rather spend it on something else.
    DadofHedgehog and Mendel Leisk like this.
  19. Prius_Boriqua
    Prius_Boriqua Junior Member
    17
    Phoenix, Arizona
    I used this one:
    Having a pump is not 100% necessary but it helps.
  20. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    What is the size of the fill plug hole or what outer size of the tube is needed to fit in?
    I've got the ATF and tools. Just tube size and washers are needed.
    Are there 2 washers needed (fill and drain)? Anyone knows the Toyota part number?
    Thanks!
