moving from prius gen3 to PIP. Regrets?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by wantaprius, Sep 20, 2014.
  1. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Me too. I went from a 2012 Prius Three to the PiP. Seems the same to me but the I'm not a "hot car" type driver :)
    51,814
    it probably is the same. usb is answering the question 'changes from gen II to pip'. although, i don't know if the extra weight makes a difference one way or the other.
  3. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    I went from an '11 Five with the 17" wheels to a '14 PiP Advanced. While the '11 arguably handled better, its ride was choppier and the road noise with the OEM tires was just below irritation levels. The '14, back down to the 15" wheels, rides much more "Lexus-like" (comparing to my fiance's ES350) and I don't find the cornering that significantly worse than the '11. My '04, by comparison, had more road noise and sloppier handling than the Gen IIIs ('11 and '14).
  4. Mendel Leisk
    41,258
    Yeah but that's the wheels. We have the same experience, going from OEM Michelin Pilot 215/45R17 to snows in 195/65R15.
  5. bisco
    51,814
    rx, what pressure's are you running?
  6. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    On the '04 42/40. On the '11 40/39, and the '14 40/39.
  7. bisco
    51,814
  8. Mendel Leisk
    41,258
    The 17" low profiles have lower suggested pressure on the door jamb decal. I've found you want to raise pressures comparably less. Still firmer, regardless.
  9. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    I think the sidewall limit on the 17" tires was 44psi. The Gen II also had a 2psi front-back differential recommended (and anyone remember the "squirrely handling" if that differential wasn't adhered to?), while the Gen III has a 1psi recommended difference front to back.
    When I get my car serviced, the dealer always deflates the tires to around 36/35. I ran on those pressures for a week before upping them to 41/40 recently. Surprisingly, very little difference in fuel/EV consumption. But, my experience with Toyotas and using recommended pressures has resulted in lots of tire replacements with uneven wear on several Camrys and one Avalon. Since my first Prius and using higher pressures, no uneven wear and I've gotten well past the warranted mileage out of each set. (For example, the '11 I traded in had OEM tires with 30K miles on them with plenty of treadlife left.)
  10. bisco
    51,814
    my door jamb says 35/33, are you getting the 1 psi differential from the o/m?
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Yup, I was pointing out the difference from gen2 to PiP. Not as crazy as his friends think.
    As already pointed out, his gen2 wouldn't get the rated 46 MPG with those short trips. PiP thrives on those.
    #51 usbseawolf2000, Sep 21, 2014
  12. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    Yup, I misspoke. 35/33 mfr recommendation. But I've always used a 1psi front/rear differential in my two Gen IIIs. (If anyone has an '11 Five, perhaps that's where I got my 1psi delta from.)
  13. bisco
    51,814
    honestly, i've never tried anything different, but i drive so slow, it probably wouldn't make any difference.
  14. bisco
    51,814
    what? with those what??? don't leave us in suspenders!:p
  15. wantaprius
    wantaprius Junior Member
    66
    Oregon
    2014 Prius Plug-in
    Well I can't keep my current Prius because once I started talking about selling it my daughter snatched it up. She paid far and square and would not give it back. Actually I measured today and I drove 5 miles one time, 2miles one time and 4 miles the third time. I do deliveries so can't go by bike much. I guess I am just deciding between a new Prius 3 or a PIP. It costs more but I get 2500 tax credit and interest is 0% for PiP. I would have to pay 2.9% for the Prius 3. If I got the 3 I would be tempted to get the solar roof but don't really need it. That would make the cost very close.
  16. bisco
    51,814
    i have to tell you, the ev is priceless. put your foot on the brake, hit the go button, put it in reverse, back out of the garage... where's the ice firing up? where's the noise? where's the high revving? where's the vibration? just priceless man.;)
    markabele likes this.
  17. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    There are certain things you just plain cannot put a price on either... like the change in attitude toward run a late-night errand. Normally, it would feel like a chore. But with a full battery-pack, the drive out to the local retail/grocery/hardware store is electric bliss.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Edited my post. Not sure what happened.
  19. Bill Norton
    Bill Norton Senior Member
    2,143
    734
    MONW, Ks.
    John, you said:
    That less than a minute is all it takes for the engine to reach warm-up anyway. Also, keep in mind that there is less to burn off in the first place, since the starting process is graceful due to the boost from the big battery-pack. It's not good to old-school use terms like "rough duty" on an advanced system like that in Prius either...
    Do you, in your toyota lovin heart, really believe this ordinary cast iron/aluminum engine in the Prius takes less than a minute to get up to a decent temp?
    It does have an interesting 'Exhaust Gas to Engine Coolant' heat exchanger that is there to mainly help with cabin heat. What about the engine oil? What about the entire exhaust system?
    I'm trying to point out the 'rough duty' a PiP would have with the OP's commuting needs. If the engine comes on briefly during his few hill climbs then turns off at the summit, that engine might never get to a decent temp to burn off moisture in the engine, in the oil and in the exhaust system.
    I believe he'd be better off with a proper BEV or an EREV. He could warm or cool the cabin from his phone, while plugged in or not. This would make his really short commute very comfortable.
    He would NOT have to deal with the very limited 3 season EV capabilities of a PiP.
    wantaprius, have you compared the final price differences between a PiP and a Volt?
    Or the performance, comfort and maintenance differences?
  20. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    He's baaack... It's not hard to imagen Mr. Norton working with GM on a commission basis to make converts - the above is one of his more aggressive attempts.
    The OP hasn't mentioned having the need to drive occasional long trips. If he does, the illustration below prepared by a mechanical engineer, who is a Volt owner himself, indicates the clear advantage of the PiP for EV trips less than 15-16 miles, and the superior gas mileage for longer trips over 70 miles.
