*MODIFICATION JOURNAL* I got my hands on the girlfriend's Prius ...here is what I did.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ucsbwsr, Sep 23, 2014.
  1. ucsbwsr
    ucsbwsr Active Member
    105
    145
    This is my first thread in this forum, hopefully it is a good one.
    Simply put: I love to modify cars most of my efforts have been put towards my past (E39 M5) and current (535xi Wagon) BMWs.
    Now that I am living with my girlfriend, her Prius is within striking distance. Although a Prius is a far departure from a car I would own personally, and also not a car that typically goes under the knife for cosmetic and performance mods, I believe every car can be made better: more comfortable, more functional, exciting, and more aesthetically pleasing. It is all about understanding the purpose and character of the car and enhancing that. Below are some of the changes which, in my eyes, make the Prius a better car.
    The best thing about modifying this car is the price! Everything is so cheap! The mods completed thus far only total a couple hundred dollars, a fraction of what things "typically" cost. In addition, the maintenance, repairs, and difficulty of wrenching is super low....awesome. This car really is a peach to work on coming from my overengineered BMW.
    For those of you who may be shaking your heads at my gas guzzlers, you might be interested in knowing that my wagon, came from the factory with an EPA 16/23mpg. After my modifications it gets about 21/30mpg and this is with power around 450hp and 510lb/ft which for those who don't understand what that means; it is like having the power of 6 Prii.
    I have some more mods in the works and will update the thread once they are completed and documented, in the meantime I hope you enjoy modding journals as much as I do! All of this has happened in the past 14 days!
    Evan
    My previous M5
    My current weapon
    Rear when I started
    Debadged and license plate frame blacked out
    Dipped emblem
    Side emblems would be removed if there wasn't 2 holes in the fender! I learned this the hard way.
    Reconditioning the rear diffuser. The right side is how it was originally, the left side is after some elbow grease.
    Now left side is after elbow grease and right side is with some Mothers Back to Black
    After restore
    OEM Antenna
    Stubby
    Cree XB-D signal and reverse bulbs. I got them through a seller on AliExpress, quality is fine and performance is great, they arrived from China in a week. A relay was also installed to eliminate "hyperflashing."
    I hate yellow/amber/orange on cars, I CAN'T STAND IT!
    Installed
    Comparison: My previous bulbs were painted chrome so light output is below eom luminosity, regardless the LED bulbs are significantly better.
    Reverse lights in the morning
    At night
    For this photo I adjusted the exposure to most accurately capture the light output.
    Up next was Phase 1 of fitment. As you can see from my cars, this is a big deal to me.
    Before 1
    Before 2 So UGLY! LOL
    Hubcentric 15mmF 25mmR
    Before Install
    After Install
    After Spacers 1
    After Spacers 2
    After Spacers 3
    Wheel reconditioning. The passenger side covers were in poor shape to I sanded down what I could prior to Plasti Dip.
    Fun with options: OEM touring wheel, Black cover, White cover.
    I later took the black and applied 2 coats of Copper Metalizer Dip.
    I liked it, but didn't love it.
    White got the nod, girlfriend agrees.
    Plasti Dip is a great product, it pays to familiarize yourself with the application dos and don'ts prior to use.
    I love how the white pops, the oem touring wheel covers are tasteful in design so it works well. I also think the white compliments the paint color (don't know the name) Minty Fresh!
    I have seen a couple GenIIs with this lower-bumper-blackout that I believe is modeled after GenIIIs, and I really like it. I used plasti dip and it is a tedious process with taping the boarder and also removing the tape at the right time in the right way to hopefully leave a clean line, which can be difficult when you are using a material with the properties such as Plasti Dip.
    It turned out ok, not perfect but good enough.
    I also dipped the side view mirrors.
    Front how it began
    Dipped grill and emblem, license plate removed.
    + Dipped side mirrors and lower bumper. License plate screws did a number on the bumper the dealership realy torqued them down and created a raised surface around the hole itself (like mini volcanoes), I made the best of it by reinstalling the screws to cover the whole and painted them with oem paint to hide the eyesore as much as possible.
    Much more to come!
  2. JC91006
    JC91006 Senior Member
    16,796
    8,589
    Car looks great! When you are done with that one, I can drop off mine so you don't get bored.
    scotrinaf and Daves09prius like this.
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    Great transformation.
    Daves09prius likes this.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I like some of it, some not so much. And I do my fair share of mods.
    Biggest thing is you better hope your GF likes those mods because it will be a PITA to put it back. Also by extending the wheels out, you will lose some MPG. Going from 20mpg to 19mpg is hardly noticeable. Going from 50mpg to 47.5mpg is noticeable and in your face in the Prius.
    You did a great job finishing the rear diffuser, looks new again.
    With all those scrapes on the hubcaps, you may need to teach some parking techniques before you let her travel about with newly dipped caps. Or you will be redoing them again shortly lol!
  5. krmcg
    2,592
    2,392
    Whittier, CA
    Great Job!
  6. Fifine
    Fifine Member
    114
    22
    So Cal
    Me too!!!!!
  7. Fifine
    Fifine Member
    114
    22
    So Cal
    Maybe she bought the car from with wheels already marred by some male driver, no?!!? :rolleyes:
  8. ucsbwsr
    105
    145
    Is the drop in mpg confirmed? That seems odd since the first thing I think about is aerodynamics a tidier fitment would cause less disruption around the wheel wells. I understand if the wheels were poking out in an extreme manner but simply flush puzzles me.
    Maybe it would have to do with the extra load put onto the wheel bearing? If so, to create that much extra load and friction the bearings would probably be fried in a short period of time, real short.
    My girlfriend came home yesterday saying, "I parked so carefully." *high-five* A mini victory for the car enthusiast. If they do get chewed up, I can simply rip them off and apply a fresh coat of Dip.
    Thanks for the compliments and comments,
    Evan
    Daves09prius and lar.smith42 like this.
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    nice job on the gf's ride. I like the blacked out look. but lose the hubcaps once she gets used to parking correctly.
    any oil leaking from that wagon yet? seems like most bmw's leak something sooner or later. usually sooner.
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Whoa! Nicely done!!
  11. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    Glove Has been thrown down. I'm so jealous! This weekend its time I get on with a few I've been holding off on for the last 300,000 miles
  12. ETC(SS)
    7,269
    Very Well Done!!!
    Clean ride.
    Original mods are refreshing in a sea of the same old smoked lights, blackened rims and coffee can muffler tips.
  13. Toddsmells
    Toddsmells New Member
    AZ
    I dig the MODS evan. Thanks for the post. Excited to see what happens in the next 14 days
  14. Jeromy
    Jeromy Junior Member
    36
    Apopka, FL
    Mind sharing info on the spacers? Where did you get them? Did it lower the mpg? Looks good!
  15. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Nice job! …especially those wheels! In reply to the question re. Bimmers leaking fluids, I'm reminded of a friend (who restores WW-II vintage aircraft) who reckons that when his old war-birds leak fluids, they're just marking their territory! :D
  16. OGGIE50
    OGGIE50 Member
    94
    42
    San Diego
  17. ucsbwsr
    105
    145
    Personally I prefer to look of the covers over the actual wheels. Since the touring wheels bow inward in a convex manner it makes the wheel appear smaller than it is, and since these wheels small to begin with I think the the flat and prominent spokes on the covers do well for the car.
    My wagon does have some oil leaking but internally. Although not confirmed I believe my valve sleeves seem to be showing signs of age, and one of my turbo seals may be in the same boat. Experts say that turbos on the N54 engine have loose tolerances on the turbo seals but I think it is excessive.
    Thanks for the kind words, "clean" is my goal when changing the aesthetics of a car. Funny you mention smoked lights, I have some light smoke vinyl waiting to be installed on the tails. I put light smoke on all my cars as it transforms the bright red into a dark cherry color while maintaining functionality. But as we know since the Japanese love their JDM style, the Prius has no red, and although some people have added red vinyl, it is red and not dark red. I have contemplated ways to achieve a dark red tint but all the feasible options would either not be reversible, not have a gloss finish, or be extremely difficult (applying 2 layers of vinyl).
    Ideally the tail lights would come apart after heating like the headlights but another member tried with no success, painting the chrome trim and reflectors black and matte silver would do wonders for the looks but it is a little too much work at this point.
    My plan is to wrap the whole tail and cut out the sections for the turn signal and reverse light. The trick is cutting in the right spot to make it look proper, since there is a gap between the reflector bowls and lens you must compensate for this and possible viewing angles. I have some red LED bulbs on the way for the rear running lights to help offset the tint (and make the pink light red.
    I bought them from eBay member chaching8899 quality is fine, no vibration. I have not had a chance in monitoring mpg.
    I have my eyes out for a good deal on H&R springs. From the info gathered on this site they seem like the best spring option for ride quality. I also prefer their raked stance. This is definitely on the To Do List.
    Daves09prius and OGGIE50 like this.
  18. 69shovlhed
    2,170
    752
    Delaware
    they didn't have silicone sealants in the good old days; but even old Harleys can be sealed up leak free (except for the case vent which will spit a little) with some of the products available now. I swear by Mercedes sealant. they don't even use oil pan or timing cover gaskets anymore, just black sealant.
  19. 69shovlhed
    2,170
    752
    Delaware
    I don't care for hubcaps-- even a steel wheel looks better to me. but everyone's different.
    I have seen a few BMWs through the shop with bad valve seals; and they will smoke like a diesel intermittently.
    your gf is very lucky to have someone to trick her car out for her. keep the pix coming.
  20. ucsbwsr
    105
    145
