CA Green HOV Sticker Limit 55,000 Effective Immediately
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilofsky, Jun 20, 2014.
  1. greenleaf
    greenleaf Member
    153
    35
    Silicon Valley, CA
    I suspect the exponential growth are not from buyers submitting in the applications. Rather, it is due to the dealers grabbing all the stickers they can, as soon as a VIN number is available, even if the cars are still on a cargo ship.
  2. Mike-GS400
    Mike-GS400 Junior Member
    Southern California
    2014 Prius Plug-in
    Woohoo! I got my HOV "Green" stickers today, #528XX. For those still waiting, or are curious about DMV processing times, here's my timeline:
    8/15 - Purchased Prius Plug-In
    8/18 - License Plate # issued
    8/19 - Mailed HOV application
    8/26 - DMV cashed $8 check
    8/30 - Received HOV "Green" stickers
  3. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    I think the growth is due to (1) processing all the applications that were held until the limit was raised, and (2) yes, the dealers.
    I've said it before, but it's a shame that DMV distorted the process by letting the dealers back into the program.
    AB 2013, raising the limit to 70,000, was enacted and will probably be signed shortly, but it won't take effect until January 1, 2015. So the stickers will run out temporarily early this fall and the dealers will have another few months to reap a windfall markup from the stickers on their inventory.
    And then when the limit goes up to 70,000 it will happen for a third time.
  4. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Gov. Brown signed AB 2013 the other day as expected, so the limit will go to 70,000 effective Jan. 1.
    Meanwhile, back at the DMV, the 55,000 ceiling will be reached around Oct. 17 at the current rate. The rate seems to be slowing slightly - maybe the dealers are all stocked up now - so it might be a little later. OTOH back in March the dealers woke up and hoovered up a ton of stickers; see graph below.
    Then we get to do it all over again next year. The 70,000 will probably run out around March or April.
    Again, DMV should turn off the dealer program and let the stickers go to those buyers who actually want them.
    lensovet and wjtracy like this.
  5. mudman
    mudman Junior Member
    CA
    I updated my calculation of when we will run out of the new 70,000 green decal sticker limit. Check it out ...
    Interestingly there was a significant up-tick of issued stickers as we got close to previous limit of 55,000 and the limit was reached a good month and a half before my linear prediction graph told us it would ... learning from that, we can expect another significant up-tick neat 70,000 which means we will likely hit 70,000 1.5 months before the new straight line prediction of June 10th 2015. That means we will likely hit 70,000 near early April 2015! (ie. night about now!!!)
  6. electrode
    electrode Junior Member
    42
    United States
    Not much many green stickers issued in March, the count as of April 8th is 63,255 . Does anybody who recently applied for the stickers share the timeline, how long from the time you applied for the stickers did you get it?
  7. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Here's my latest graph. Based on the last month only, they should run out around the middle of July.
    The last two times, there was a bulge, probably from dealers pre-ordering, starting about 2 1/2 months before they actually ran out. The 40,000 date was pretty close to the projection prior to the bulge. 55,000 was reached on 10/3/14, faster than the historical rate would have predicted, but looking at the curve over time, it appears that that bulge pre-supplied dealers with stickers to smooth out the months between then and the resumption of issuance on January 1, 2015, because the line is pretty straight if that second bulge is ignored.
    Will the dealers soon start pre-ordering ahead, creating a bulge that will bring Doomsday closer? Or do they routinely pre-order now, in which case it'll be pretty much a straight line to mid-July? Stay tuned.
    And let's hope for an update sooner than the 6 weeks the last one took.
  8. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    My guess is that they will not pre-order as much as in the past, simply because gas prices remain low for now. As a dealership, I would pre-order more CUV's because of their high turnover and profitability.
  9. CharlesH
    2,798
    1,166
    Roseville, CA
    How much say do the dealers have with respect to what they get? I thought that the factory told them what their allocation of various models was based on factors such as prior sales by that dealership. :confused:
