Portable Jump starter?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by exmetrodriver, Sep 24, 2014.
  1. exmetrodriver
    exmetrodriver Member
    124
    Puget sound, Wa.
    Does anyone own a Portable Jump starter that they carry in the Prius? Any recommendations? It sounds like a very small one will do. I have read that you can jump a Prius with 8 D cell battery. I would like to have one for long trips.
  2. wa-chiss
    wa-chiss Member
    127
    Brownwood, Texas
    Yep, they make very small jump starters nowadays that are 4"X6"X1" that have up to 400cca. They'll jump start a 5.7L Tundra no problem. You should have seen the look on the guys face when he asked for a jump box and I handed him this wallet sized box with cables in it. Worked like a charm. I have one that I leave in the wife's car unless we take a trip in the prius. Then it goes with us.
  3. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
  4. dandeman
    dandeman Junior Member
    61
    Chapel Hill, NC
    I carry the Jump N Carry at the link below on long trips.. This is based on experience in my Toyota 4Runner 4x4 that the 2 highest probability failures likely to strand you on today's vehicles are battery failure or tire puncture.. I've had both happen on long trips..
    The air compressor gives you the option on a leaking tire to be able to temporarily pump the tire back up and move to a safer or more convenient location for permanent repair..
    Jump Starters - 1700 Peak Amp Volt JNCAIR | Call us at 1-800-328-2921 |Clore Automotive
    The "space saver" spare tire and relatively small AH capacity of 12v battery in the Prius makes this "backup" power and air supply even more important.
  5. exmetrodriver
    124
    Puget sound, Wa.
    I looked at at same one last night. Looks like a good unit.
  6. ETC(SS)
    7,342
    You can jump start a Prius with the D-cells just fine, but storing and deploying them will probably be more trouble than it's worth.
    The pocket-sized charger is a very good alternative, and they're getting cheaper every day.
    Just make sure that you keep it topped off by charging it semi-occasionally.
    Same with the larger units that also have a compressor built in.
    Good Luck!
  7. Mendel Leisk
    41,880
  8. exmetrodriver
    124
    Puget sound, Wa.
    It's looks like the. Clore review very well, but I do like the idea if the pocket ones because you can also charge a phone with them too.
  9. Mendel Leisk
    41,880
    The clore charger has a cigarette lighter style socket, you can plug in any phone charger with that kind of plug.
    I got it before getting into hybrids, some years back, it seems durable, fwiw. It's pretty heavy though, almost 20 lbs.
    In the link, that list price in the $300's, discounted down, is shownmanship I think. I ordered mine through the manufacturer, and it was around $160 at the time.
    (Dandeman's link is to the proper site. His model is same amperage, but also a compressor, hmm)
  10. Hawkizrok
    Hawkizrok Junior Member
    Marion
  11. Mendel Leisk
    41,880
    I still "have" it, but haven't used it in a couple of years. It's recommended to recharge it every 3 months. It houses a good sized AGM battery, which could be swapped out if need be, for maybe 1/2 the price of a new one. I'm not that up on these new ones, perhaps they're ok, for light usage? Especially if they're significantly cheaper. I'm really not that knowledgable, just latched onto something that worked for me, but my usage has really dropped off.
    If you're just thinking about preemptive tools to get, I'd be more inclined to start with a good smart charger.
    Raytheeagle likes this.
