Servo-like noise when opening door
Discussion in 'Gen 3 Prius Technical Discussion' started by webbkr, Sep 27, 2014.
  1. webbkr
    webbkr Junior Member
    Central Florida
    I've had my 2014 Prius II for about a month now and am really happy with the car. I do however have a question. Every time I go the garage and open the driver's door to get in the car, I hear a servo-like noise under the hood lasting for a few seconds. probably 5-6.
    Can anyone tell me what may be causing that?
    Thanks,
    Ken
  2. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    your brake system gets primed/
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Yes, the Prius has a hydraulic brake booster and it looses pressure in just a few hours of down time. It pressures up when the -drivers- door is opened, as the car gets ready for you to drive. It doesn't do that when the passenger or rear doors including the hatch are opened. Some cars hold the pressure longer, some shorter. Pearl held it overnight, Pearl S not so much. A few hours and it runs the pump when the drivers door is opened.
  4. Grren4ever
    Grren4ever Active Member
    347
    167
    It's your car's way of saying "hello." :). at least that is what the dealer told me
  5. bisco
    52,356
    i climb in from the passenger side to avoid that.
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    It's still going to do it when you power on the car though. :confused:
    SCH-I535
  7. bisco
    52,356
  8. Mendel Leisk
    41,871
    I was idly wondering the other day, if I snuck in the passenger side, climbed over the buttress (THAT'S why it's there) and powered up the car, would the brakes be messed up? Xliderider's ruined my fun.
  9. bisco
    52,356
    i thought i was getting away with something...
  10. David Beale
    5,963
    1,989
    Edmonton Alberta
    Repeat after me: "My car is smarter than I, my car is smarter than I".
  11. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Also realize your car will make a buzzing noise about 8-10 hours after driving it too. Something to do with the fuel evaporative system.
  12. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    It is the digital equivalent of a stretch and a yawn.
  13. Starship_Enterprius
    Starship_Enterprius Active Member
    331
    163
    Ottawa, Ontario
    2018 Prius Prime
    I thought it was just purring at me.
  14. David Beale
    5,963
    1,989
    Edmonton Alberta
    You will find an explanation in the owners manual, if you have the patience to hunt it down.
    In fact, I will say it again. And I "paraphrase".
    -Any sound the Prius makes at any time is normal.- Which is what you come away with after -fully- reading the manual. ;)
  15. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    My UK PiP also 'breaks wind' some minutes after turning the power off.
  16. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    ... and that's why incompetent is a generous evaluation of those that work at the stealership.
