Regular car (starting) battery - replacement timing recommendation?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by prominence, Oct 5, 2014.
  1. prominence
    prominence Junior Member
    57
    Columbus, OH
    Hey friends,
    Hoping I can garner some advice on when I should replace the regular engine car battery in my 2011 prius (the one that starts the car).
    I've had my 2011 prius since Fall 2011 and have 50k miles on the car. I live in Ohio so winters can dip in the 0-30 degree range.
    Is there a notification that pops up saying the battery is getting low? Or is there a general rule of thumb to replace every X amount of years or miles?
    Getting Michelin Energy Saver A/S put on the car this week at the dealer; wondering if I should also go ahead and replace the battery.
    Thanks!!
    51,840
    well, no need to replace it yet, if it isn't giving you any trouble. there is no notification, but one thing to think about is draining the battery. if you ever do this by leaving a light on or a door open, it can drastically reduce the life of the battery. also, if you run mostly short trips or drive it infrequently, that's another problem. otherwise, if you want to be proactive, change it after around 4-5 years.
  3. Den49
    Den49 Member
    498
    272
    Maryland
    If your battery is healthy now, Fall 2015 would be four years for your battery and about the right time to replace it to avoid the inconvenience of getting stranded because of a weak battery. My OEM battery failed at 4 years and 5 months.
  4. Mendel Leisk
    41,303
    You can get an idea of the 12 volt battery's health by hooking up a digital multimeter. If it's 12.6 volt or higher it's in good shape. Lower than 12.4 and you need to keep an eye on it, either use a smart charger (4 amp range, higher not recommended) or get it replaced.
  5. vskid3
    vskid3 Active Member
    773
    228
    This is after the car sitting overnight, not while its on or right after.
  6. Mike500
    Mike500 Senior Member
    2,593
    767
    I have a ScanGauge II that monitors the voltage continuously.
    Given the numerous users who have had problems with the Optima batteries, I was considering only OE replacement batteries from my Toyota dealer.
    However, I will now probably get this one from Batteries +p;us, since it has a FULL four year replacement warranty.
    SLI51PAGM Duracell Ultra Platinum AGM Battery
    - 2010 to 2014 L4 1.8L 325CCA Hybrid - Prius - Toyota - Car and Truck - Batteries Plus
    Even nicer is that there is a Batteries Plus store less than a quarter mile down the road from me.
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Interesting find. No mention of the AH rating. Being a Prius specific battery I'd assume that a vent port is included.
  8. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    I just replaced mine this weekend after 5 years. It was reading 11.2 volts on the diagnostic menu after sitting overnight and would drop to 10.9 with the headlights on. With the inverter charging it, it read at 14.0. After a twenty minute drive and a couple hours sitting, it read 11.6 with a voltmeter. Decided to just go to the dealer for the replacement - they're not all evil.
  9. bisco
    51,840
    true, just most of them.;) if you have a good one, you're fortunate.
  10. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    You should replace it when it fails. :)
    The 12 V battery in our hybrids does NOT actually start the car in the c0nventional sense; it just powers up the computers and the actual starting power comes from the HVB.
    As it gets weak, all sorts of strange things might begin to happen, electronically, even though the car still starts and runs.
    Most folks seem to get 4-5 years out of their OEM battery......but some much less due to abuse at the dealer or very light use by the owner.
  11. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    4 years is being very safe. Mine failed at about 5 years, and I was left stranded n a parking lot when it happened. I wish we got more life out of our 12volt batteries. I got 7 years out of a stock impala, and got 9 years out of a dodge battery.
  12. bisco
    51,840
    uh-oh, my dodge is an '05.(n)
  13. prominence
    57
    Columbus, OH
    Thanks for all the advice, everyone! (o: I'll hold off on replacing it until next Fall.
  14. Janstheman
    Janstheman Junior Member
    48
    Worthsville, IN
    My Gen 2 Prius made it 9 years 11 months on its original 12 volt. battery. I got an OE at Toyota, why not? If it makes it five years I got my money's worth.
  15. jds580s
    jds580s Junior Member
    Sorry to bring up an old thread, but I purchased the Duracell SLI51PAGM yesterday and wanted to answer these two questions.
    The rating on the top of the battery is 46Ah
    And it does have a vent port.
    My original 12v battery on my 2007 Prius gave out.
    When I tested it the voltages were
    9.8v ACC mode
    9.5v On
    14.0v in "ready" mode
    With those low voltages I am surprised it was working at all. I won't complain since the car got 7 and a half years out of the original Toyota battery.
  16. bisco
    51,840
    after 7 1/2 years, what made you decide against another one?
