Installed front strut tower bar, center power brace, rear sway bar - car rides rougher ...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Scott1258, Apr 8, 2012.
  1. Scott1258
    Scott1258 Junior Member
    43
    Huntington Beach, CA
    We just had the tanabe strut tower brace, cusco center power brace, and the trd rear sway bar installed in my wife's new 2012 - she's complaining that the car rides rougher after the install. After driving it today I have to admit it is a rougher ride.
    Anyone know which brace is causing most of the harshness? My guess would be the stut tower brace but it's only a guess. I couldn't see the center brace affecting the suspension / ride of the car, and I was under the impression that sway bars don't affect ride quality ... However this could be the culprit too. Any thoughts and opinions on which brace is contributing the most to the rougher ride would be appreciated. Also, anyone have just one or two of these braces without any change in ride quality?
    Currently I have the tire pressure at 42f and 40r but this was the same before the braces were installed. I'll lower it a bit tomorrow to see if this will soften it up.
  2. Socal Pete
    Socal Pete Junior Member
    69
    SoCal
    It's probably the Cusco center power brace. I didn't notice the ride being rougher until I had my coil-overs installed. I did lower my tire pressure back to 35f and 32r. That helped soften the ride.
  3. txl146
    txl146 Member
    301
    NY
    Anything that stiffens up the chassis will cause more NVH.
    People install braces for improved handling, not for improved ride quality. ;)
    I have tons of bushings/braces on my Subaru and it's not for everyone.
  4. Scott1258
    43
    Hey Pete,
    Did you have either the front strut tower brace or the rear sway installed before you did the coil overs? Let me know Which braces you have installed - the center brace would have been my last guess. By hey, that's why I'm asking as I don't know! Thanks for you input.
  5. Socal Pete
    69
    SoCal
    I had the front strut tower brace installed first. Center brace and rear sway bars were next. I've since had the other two brace installed (all three installed has eliminated all rattles in the car). With the strut + center brace the chassis is stiffer so you will feel all the imperfection on the road especially here in SoCal.
  6. Scott1258
    43
    Thanks for the info Pete. With just the front strut tower bar installed it sounds like you didn't notice a harsh ride. So you think from your experience if I take off the center brace it will soften the ride some? Let me know. Thanks.
  7. Socal Pete
    69
    SoCal
    I would take the center brace off first...then the rear sways. Have you lower the tire pressure to see if that helps?
  8. d2mini
    d2mini Active Member
    519
    106
    Houston
    Any lowering of suspension, any stiffening of the chassis, and larger wheels/lower profile tires will ALL give you a "rougher" ride to some degree. It's the trade off for greater handling performance. Cars like the prius are built for the general public who want to get from a to b in comfort, which is why these modifications don't come from the factory. If you are not familiar with the changes this makes to the vehicle, it's wise to do them one at a time.
  9. mmcdonal
    mmcdonal Active Member
    666
    98
    Columbia MD
    I currently only have the rear sway bar on my car, and it has not created any additional harshness, just a flatter ride in the corners. Since I have grippier Michelin Primacy MXV4 tires on now, I notice an instability in the front track that I am going to fix with a front strut tower brace (Tanabe).
    Having installed these two components on other cars, I can tell you they did not make the ride harsher. Lowering springs makes the suspension sharper, but with no additional harshness. I am thinking it is the underbody braces, myself, that are adding the harshness, since these act to get rid of the last bit of play in the chassis.
    Chassis are always under-welded to add some compliance. You only re-weld for race applications. I have a feeling the braces give you the same affect. In any event, those are the easiest to remove and replace, if you wanted to test any one component. How is that going?
  10. Mike500
    Mike500 Senior Member
    2,593
    767
    I would be very careful in choosing any stiffening or bracing element other than the cross brace and underbody stiffening components.
    All these kits, however well intended, "have not" gone through the extensive static, dynamic and crash test that Toyota and the IIHS has done. That would cost too much.
    I can see the efficacy of the two point cross body brace, since it has the same "loading points" as the OEM brace. While the center brace, like that of the discontinued BT Tech brace imparts some improvement ito the stiffness of the chasis, a much more effective design would be a "box beam." That would be much stronger and stiffer. A 1.5x3.0 inch box beem, with the height being 1.5 inch, will still have higher clearance than the bottom of the front suspension frame and the catalytic converter.
    I see the four point stiffener imparting "some" additional stiffness, but, from my experience, I see very little due to the long length of its "lever arms."
  11. Scott1258
    43
    Thanks for all the tips everyone - I'm going to take the center brace off when I have a moment and see how the car feels. I'll let everyone know what effect this has.
    If anyone else just has the tanabe stut tower bar and the trd rear sway installed i would really like to know your thoughts on if these bars changed the comfort level of the car for you.
  12. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I have the TRD RSB, Tanabe FSB & 2-point chassis brace. I noticed a little more stiffer ride after the install of the 2-point chassis brace but nothing that bothered my wife since it's her car. I run 40/38 for my tire pressure. I had heard from others that the power brace really stiffens up the ride & chassis so I went with just the 2-point brace which did help tighten things up.
  13. Scott1258
    43
    Thanks for the info. Did you install the tanabe or cusco 2 point brace? And before you installed the 2 pointer did you notice a stiffer ride with just the trd rsb and the tanabe fsb?
  14. SuperchargedMR2
    673
    179
    Vancouver, WA
    I installed the 2-point Tanabe chassis brace. I di drive the car to test it out before the 2-point chassis brace. The car felt very much the same as far as ride before the chassis brace but the addition of it did stiffen up the car but not too much that my wife noticed. She doesn't even know I installed it. :lol:
  15. Scott1258
    43
    Glad to hear that with just the stb and rear sway all felt good. I'm taking it in on Friday to have them remove the center power brace and I'll let everyone know how the ride changes. The car feels very solid with it on, but the wifey is not happy with the added stiffness and as she says the bumpy ride.
  16. d2mini
    519
    106
    Houston
    How about having the wife removed on friday instead? :eek: :D
    I kid! I kid! ;)
  17. Scott1258
    43
    Had the center power brace removed and the oem brace reinstalled. Everyone here was right - it was this brace that was causing the firmness my wife wasn't happy with.
    With the cpb the car does feel more solid. It takes all the little bouncing around the car does and makes I one solid piece. The downside is due to the solidness it doesn't soak up all the little bumps as well, especially the expansion joints on the freeway here In So. Cal. My wife likes the light bouncy feeling the car has with the oem brace. The cpb gives the car a more sporty feeling. I didn't think it was a harsh feeling just not as buttery smooth as oem.
    So, anyone interested in buying the Cusco Center Power Brace off me? It's just like new! If so send me a PM and I'll get back to you.
    Scott
  18. Grren4ever
    Grren4ever Active Member
    347
    167
    I am totally going to agree with Scott1258...
    I had my cusco under chassis power brace installed last month (the 4-point bolt-on one). The ride went from awesome & fun.......... to stiff and spine numbing. It made me not want to drive the car anymore. I took it off and the car feels beautiful to ride in again...not too stiff and not too soft. Too bad I learned the hard way and should have listened to all of you in the first place...
    I will have a hard time selling it on craiglist unless I put it on for under 100$.
  19. nedear88
    nedear88 My 1st Prius.
    245
    141
    San Bruno, California
    I also had the CUSCO power brace installed before, my wife and kids complain so much about the stiff ride so I removed it and luckily I bought the OEM brace from a 2012 Plug in, now the my car run a lot better and no more complaining, I have the CUSCO strut tower bar installed and TRD rear sway bar installed also, plus I had the Lexus CT 17" rim and tires, it's all good with the updated version of the OEM rear center brace, see photo...the bar on top is the updated from Toyota and the one below is the 2010-2011 version.
    #19 nedear88, Oct 7, 2014
  20. Mike500
    2,593
    767
    That's why I designed the "box beam" braces without the trailing arms of the CUSCO.
    The right lateral side of the car is designed to allow twisting like a pair of scissors in comparison to the left side. If you examine both OEM braces, you'll see that the center section is like a torsion bar.
    My "box" beams allow the same twisting motion, while they have the ultimate stiffness to end to end bending, even more than the upgraded OEM brace.
    Instead of nearly three pounds of steel, five parts and ten welds, the "box beam" uses one piece of extruded and tempered aluminum. It is based on the "wing warping" concept patented by the Wright Brothers at the beginning of the Twentieth Century.
    #20 Mike500, Oct 7, 2014
