Fog light wiring
Discussion in 'Gen 2 Prius Accessories & Modifications' started by burstaneurysm, Oct 6, 2014.
  1. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Does anyone have a definitive answer for how to wire up aftermarket fogs?
    I really need to know where to pull 12V under the hood and what to tap in the cabin for the switch.
    I've done it in my 2010, but AFAIK, second gen is different.
    Can I use a fuse tap in the location for the stock fog fuse?
  2. burstaneurysm
    469
    144
    Chicago, IL
    Anyone? Someone must have successfully installed fog lights in their 2nd gen.
  3. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    If it would be of any use to you I can post the wiring diagram for the lights.
    John (Britprius)
  4. burstaneurysm
    469
    144
    Chicago, IL
    I have the diagram, but the OEM fog stuff is different from the add on kits.
    I was just hoping someone had installed them and knew what they tapped.
    I need 12v under the hood and then switched hot under the dash.
  5. Britprius
    5,194
    1,921
    Pick permanent 12 volt up from under the hood from the jump point via a suitable inline fuse. Does the lighting stalk switch have a fog light switch as part of it's functions? If not I suggest you buy the one with this function possibly from a damaged vehicle.
    John (Britprius)
  6. burstaneurysm
    469
    144
    Chicago, IL
    I was thinking about using the jump terminal, but wasn't sure if there was something better to tie into in the fuse box.
    Came with a different switch, car doesn't have the fog stalk.
  7. wa-chiss
    wa-chiss Member
    127
    Brownwood, Texas
    Just use the wires from the headlight switch low beam or the relay for the low beam headlights to activate the relay for the fog lights. That way, you can hard wire the fog light power through the relay to the jump port in the fuse box under the hood. The fog lights will allways come on when the headlights are on low and go off when they are turned off or switched to high beam. Rudimentary I know, but it'll work. Law states here in Texas that no other foreward facing white light(s) can be on with the high beams.
  8. Beqa
    Beqa New Member
    Georgia
    can u please give me the diagram?and photos if u have :)
  9. Erik Owens
    Erik Owens Member
    162
    59
    I see that one our accesories use the fuse location right under the jump contact on that fuse block. I could send you the whole thing but that is for our accessory that are from TMS through our region down by Florida. The grounds we use is the ECM mounting spot where the bolt comes in to the frame by the brake fluid reservoir. Routing depends on the setup Im assuming.
  10. Beqa
    Beqa New Member
    Georgia
  11. Beqa
    Beqa New Member
    Georgia
    hello can u give me instructions for 2 gen prius (2008)
