Won't start, "check hybrid system" on Gen III
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rogerv, Oct 2, 2014.
  1. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Thanks. She really needs to pursue this with Toyota Customer Care to get written proof of the 15 year warranty.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The question may be that now that Toyota has replaced the IPM transistors under warranty then what is the warranty of the new IPM. They may or may not warrant the replacement IPM for the extended 15 years.
    I would certainly ask so you will know for sure.
  3. miketee
    miketee Junior Member
    52
    Prince George's County, Maryland
    This happened to me a couple of months ago. My 2012 Prius IV with 64k miles on it suddenly lost power in the middle of a left turn on a busy road! Fortunately, the car was able to limp through the turn and make it to the side of the road. I got the "check hybrid system" indicator and the car would not move faster than about 5 mph. I knew it wasn't the battery because it would power up, it just wouldn't drive normally. I had it towed to the dealer who confirmed that it was the transistor kit within the IPM. Thankfully, the part was still under warranty! The downside was, my dealer didn't have the kit in stock and neither did any local dealer so the part had to be ordered. It was backordered and took about 2-1/2 weeks to come in!
    Fortunately, they gave me a free rental (a Corolla) which made me visit the gas station more often than I'm used to but I was thankful to have a car during the intrim. Siince I bought the Prius, I've only taken it to the dealer for service. I don't remember my car being recalled.
  4. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Here's the recall document. They did a software re-flash to lower current to the IPM under heavy throttle. With the original software spec, current under heavy load was such that it was cracking leads to the 3 capacitors within the transistor pack. When this happens, the car goes instant limp-mode, as you experienced. If you didn't do the re-flash prior to your IPM failure, they will have done it when they did the repair.
    • E0E.pdf
      File size:
      40.3 KB
    Raytheeagle likes this.
  5. miketee
    52
    Thanks...good to know.
  6. rogerv
    1,639
    317
    Update on my daughter's car- a few months ago her car was rear ended by a Ford F-350 towing a large boat. Result: total loss on her car with 125k on the clock, so the question of the 15 year warranty is moot. She had paid her car off early just a few months earlier. USAA would only give her about $8000.:oops: No settlement for her injuries yet....
  7. bisco
    52,284
    ouch! sorry to hear, how bad are her injuries?
  8. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Sorry about her injuries!
    rogerv likes this.
  9. rogerv
    1,639
    317
    Thank you, Gentlemen. Sorry for the delayed response; other stuff going on. She is getting chiropractic treatments a couple of times a week. As I understand it there is no permanent damage, but she still has muscular pain in her neck.
    m.wynn and bisco like this.
  10. bisco
    52,284
    bummer. all the best to you and her!(y)
    rogerv likes this.
  11. rogerv
    1,639
    317
    Thank you. She is hoping there will be enough of a settlement to pay off the difference she had to finance to get the replacement Prius, a 2013. Both she and the other driver are insured with USAA, and they have in no way pressured her to settle.
