HELP! My car won't start!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ariel1194, Oct 9, 2014.
  1. ariel1194
    ariel1194 New Member
    Hey guys, I've got a 2005 Prius. It's my baby, i'm the original owner and it's got 250,000 miles on it and its never let me down.
    I recently replaced my shocks and springs. I took everything apart in order to remove the old suspension, I checked to see what I needed and ordered parts accordingly.
    Well here is where everything starts to fall to pieces, I mistakingly left the rear hatch open and when I came back the battery was dead. Being as how the battery was original from 9 years ago I decided to replace it instead of trying to charge it. Today I installed my new Optima Yellowtop battery and now my car won't start and I can't figure out why. The only thing on the car that seems to work are the hazard lights and the horn. There is no power anywhere else. When I press the start button, the check engine light as well as the small green light on the park button flash and then quickly disappear and the power button flashes red for a few minutes then turns off.
    WHAT DID I DO WRONG?!?!?!
    Where do I go from here?
    I have checked the fuses in the fuse box under the hood and underneath the dash and they all seem fine. I also check the 5a fuse on top
    Thanks for the help.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    are you sure the yellow top is charged?
  3. ariel1194
    Yup. Battery is new and I threw it on my charger before install
  4. bisco
    52,286
    i would check the voltage and check the battery connections.
  5. ariel1194
    Ok. Update. Originally I checked my fuses for continuity. Today I checked the fuses under the hood and there is no power going to them. However I checked the fuses on top of the battery and those do have power. Any thoughts?
  6. bisco
    52,286
    on top of the 12 volt battery?
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    My guess: something remains disconnected, either near the 12v or near the relays
  8. ariel1194
    Yes, on top of the 12v battery
  9. Stevewoods
    Stevewoods Senior Member
    663
    1,194
    Seattle, WA
    I would do two things....one:
    Check the voltage of the battery at the battery.
    If you have correct voltage at the battery:
    Re-install battery....Oh...not really, but as poster BISCO said, go back into the battery compartment and make sure all connections are tight, both on the postive clamp to the battery post as well as the cable connections to the postive clamp itself. Then, double-check the negative connection.
    Does'nt seem like leaving the hatch open would kill a good battery, unless it was for an ultra-extended period of time.
  10. 69shovlhed
    2,170
    752
    Delaware
  11. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    You must have some power going up front since horn and hazards work.
    I would be curious what voltage your yellow top is reading with hazards flashing.
    I've never owned a Gen II, are these symptoms possible from a traction battery safety disconnect not completely latched?
  12. bisco
    52,286
    check the 12v voltage in the morning before starting the car. yellow tops are notorious.
