Most recent tank
Discussion in 'Gen 3 Prius Fuel Economy' started by wesayso, Jun 2, 2011.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    I don't remember right off hand but when it shows empty I think there is about 1.9 gallons or so left in your tank. So if you want to you can go about another 80+ miles.
    I just fill up when it starts to flash.
    Enjoy your car!:D
  2. John Bergendahl
    102
    17
    gulfport,ms
    Hmmm may carry that full gas can with me and see how far it gets me.Gotta learn my car incase a real emergency comes on day right?
  3. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    It's accurate in that there are always around 2 gallons left in the 11.9 gallon tank. :) I've never had a gas gauge yet that was accurate to 0 gas in the tank. Every one had a fudge factor to try to keep you from running out of gas. The Prius does seem to have the largest fudge factor though.
  4. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    I have put 11+ gallons in a couple of times when Ive squeezed 600 miles from a tank.
  5. Mendel Leisk
    41,326
    One way to avoid that day: fill sooner. Life is full of pointless pursuits. Seeing how far you can go on a tank is one of them.
  6. John Bergendahl
    102
    17
    gulfport,ms
    To each his own,i can be curious cant i ? Not going to hurt anybody.Since its stated i have 1.9 more gallons i should be fine.
    wesayso and kenichols29 like this.
  7. Gabriel Maestu
    Gabriel Maestu New Member
    Tampa
    Light blinks with 2.2 gallons left. Once you reach the zero miles on the miles left trip screen, you can go 75 - 100 miles more easy (atleast the way I drive.....I rarely go over 53 mph)
  8. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  9. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  10. dulcimoo
    dulcimoo Junior Member
    34
    Vista, CA
    2nd fill up.
    Total Miles Driven 609.9.
    Miles to drive 579.
    Running total per the car: MPG: 48.1.
    Running total MPG (computed): 46.0.
    Computed last tank full:55.9
    Gas used "Costco Regular" @ 2.399/gal
  11. dulcimoo
    34
    Vista, CA
    3rd fill up: Miles to drive reads 571. Total MPG reads: 49.8 Total Computed MPG reads 47.18. Last tank computed MPG is 48.8
    Makes no sense.
  12. John Bergendahl
    102
    17
    gulfport,ms
    hate this cold weather
  13. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    40K service done at 41,368.
    All OK. Did not rotate tires because they were replaced last month.
    Toyota filter & Mobile 1 0-20W.
  14. dulcimoo
    34
    Vista, CA
    4th fill up: Miles to drive reads 561. Total MPG reads: 50.2 Total Computed MPG is 47.3. Last tank computed MPG is 47.9
    Miles to drive is a bit low, maybe I didn't get as much in. Looks like my "real" milage is about 47.somthing
    Also I had the dealer change the oil and new filter … even if the oil was very clear. It probably didn't need to be done. I have done this [change oil after 1st 1000 miles] with all my cars and they all have lasted at least 250,000 miles. Price with tax was $65.08, which was cheaper than the special.
    Read more: Most recent tank | Page 16 | PriusChat
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
    #314 dulcimoo, Jan 18, 2015
  15. John Bergendahl
    102
    17
    gulfport,ms
    what had to be done at 40k
  16. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    Basically checking brakes, fluids, etc.
  17. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  18. GregP507
    GregP507 Senior Member
    3,002
    481
    The secret to stress-free driving is not to torture yourself, worrying about how to squeeze out an extra mpg.
  19. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    I don't stress over it, but I do keep track.
    Blizzard_Persona likes this.
  20. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    My last 2 tanks (roughly 2 weeks of commuting on each tank) have been 37.xx and 39.3mpg calculated, indicated had been 6-8% high!!!!!!!
    This blows especially as I have my tires pumped up to 44/42, and religiously set my cc to 55 mph on my 18.5 mile commute (half highway), but granted it has been colder n all hell this last month....
    I can't imagine mpg in this cold if I drove like some here who insist on rolling along at 75-80 mph!!!
    On another note I did block my grill last week, lower grill is 90-95% blocked, only part not is about a half inch by a foot under my front license plate, should I block the top grill too???
    Edit: in case it's not obvious, I have a Persona with stock 17's...
