Help figure out harsh ride problem after replacing shocks/tires
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HeinzCatSoup, Oct 12, 2014.
  1. HeinzCatSoup
    HeinzCatSoup Junior Member
    Southern California
    So heres a little background story..
    The car was purchased used with 18" wheels already on. After driving for about 6 months, I started noticing the road noise getting very loud. I took the car to a tire shop and they told me that there was some uneven cupping in the middle of the wheels, which is usually caused by worn out shocks making the wheel bounce up and down.
    I replaced all 4 shocks, then replaced all 4 tires. Now its much more smooth than before, and is very silent on nicely paved roads. however I notice when theres roads which any imperfections (like fixed streets with tar.. or uneven pavements, or when your tire hits the freeway markers to keep you in the lane) its heard very loud from inside the car and creates an almost *thud* sound when it does.
    I assumed that the problem was that the car had 18" wheels. So recently I swapped the wheels out with stock 15" from toyota, but somehow the road noise is still very apparent. I sat in a friend's prius, same year, and I could tell that it was handling the uneven pavements much softer.
    What could be the problem now? Is there anything else that needs to be replaced?
    solrunner likes this.
  2. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    Putting 18" wheel assemblies on a 2010 Prius I-IV designed to run 15" would cause more suspension/steering wear with equal use. In fact the 2010 Prius V, which came with 17", had a different-stronger steering rack installed and "I think" beefier suspension components as well. I would suggest you go to to your Toyota Dealership and request a ride along with one of their mechanics familiar with the Prius suspension. That way you can point out specific symptoms as they occur and reduce time trouble shooting. This also saves time by eliminating a Service Adviser's "best guess" when directed back to the shop.
    #2 frodoz737, Oct 12, 2014
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Yeah... either worn out or mismatched parts.
    Anything else the first owner exchanged along with the 18" wheels ?
  4. Mendel Leisk
    41,640
    Frodoz, you may be on to something, with your speculation re different steering components on models with 17" rims. Or it could be they've just reduced turn limit due to wider tire. Though the latter seems a bit much.
    When buying, we first had a test drive in a 15" model. That was at night. Next drive was daytime with a 17" model. We bought that one.
    I felt a night-and-day improvement in steering/handling with the 17" model. It MAY just have been the day-vs-night test drive experience, getting used to the car, and so on, but I sure liked the car we bought.
    #4 Mendel Leisk, Oct 12, 2014
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
  6. JC91006
    JC91006 Senior Member
    16,780
    8,575
    I don't have a 2nd gen3 to compare. However my 2010 v has very tight steering compared to my gen2 cars
  7. fatdawg
    fatdawg Member
    131
    55
    Bay Area, CA
    2014 Prius Plug-in
    Are you still getting a thud sound after replacing your shocks? If so, you could possibly have a bad engine mount. Or possibly some metal to metal due bad bushing on the shock assembly.
    If your car is riding loud while moving, you could possibly have a bad hub. I had these issues with my Gen2, its a bit surprising those have failed already on the Gen3 unless you've been in an accident or have tons of miles.
    iPhone ?
  8. HeinzCatSoup
    Southern California
    125k miles. its not loud, but its like i feel the road alot more than 15" wheels should be able to feel. I want to figure it out, but its not bad enough that I want to take it to the dealer for an expensive diagnostic i guess
  9. fatdawg
    fatdawg Member
    131
    55
    Bay Area, CA
    2014 Prius Plug-in
    Yeah, check your hubs, it's easy to do, there's YouTube videos on how to do it. You just need a jack and check for movement. I had the same issue on the 2nd gen with 190k.
    iPhone ?
  10. HeinzCatSoup
    Southern California
    one thing I just noticed is that if I bounce the car up and down, I hear creaking pretty loud. do the springs need to be placed?
  11. hermit375
    hermit375 Junior Member
    Lancaster Co. Pa.
    the wife's 2010 gen III had a noise in the car and narrowed down to both rear hubs. The l/s was so crunchy when you hold it and try to turn it. And the r/s wasn't much better. she has 115,000 on it. About a month ago was in dealer to have converter and engine coolant changed along with the gear box. It went through a "50 point safety " check and missed the wheel bearings in the rear while the car was on the rack must have been the 51 & 52 items-- just off the list.... That took care of the noise in the rear.
  12. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    The 2010 17" had a completely different and quicker steering assembly from the 15". IIRC it was a different steering motor technology. (There was quite a bit of Priuschat discussion about it at the time)
    I'm not sure if that has changed in later models or not.
