Plugging in ,compared to not
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by coolcarguy, Oct 11, 2014.
  1. coolcarguy
    coolcarguy New Member
    27
    2013 Prius Plug-in
    I did some tests the last time i filled up with gas i never plugged in and i got about 430 miles. the tank before that i plugged in every time i was home atleast once a day and i got 510 miles does that seem right to you guys ?
    i did some tests
    52,277
    spot on. i plug in everyday, sometimes more than once. check out the sticky spreadsheet, you can go thousands of miles on a tank.
  3. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    430 miles is quite impressive for the non-plug-in experiment. Sounds like that slightly smaller PiP gas tank is not too much of a negative.
    Only 100% highway driving do I see >400 miles with our Gen2 flexible "guess" tank.
  4. bisco
    52,277
    interesting. my city driving brings great mpg's than highway. i can get 70mpg around town without plugging in, X 8 gallons at the beep is around 560 on the mfd. but on the highway, not even at 55 would i get that.
    #4 bisco, Oct 11, 2014
  5. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    well, bisco you must try retirement....all your non-highway miles are short trips, in our case we are active grandparents so the soccer thing and all that.
  6. bisco
    52,277
    not looking forward to it, i didn't like the soccer thing when my kids were doing it.:cool: and hockey was even worse, travel wise!:eek:
  7. coolcarguy
    27
    2013 Prius Plug-in
    the spreadsheet is kind of confusing ,lol.
  8. bisco
    52,277
    it's a sticky at the top of the forum, the title is 'pip and mpg spreadsheet'. yesterday, i had a trip to the doctor, 15 miles one way. just got there on ev with .1 ev mile left. the return trip in hv produced 69 mpg. half highway @55 mph and half back roads 30-40 mph.
    coolcarguy likes this.
  9. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    My recent trip up north didn't provide any opportunity for charging. So, I used the battery sparingly the entire time I was there.
    46 mpg up and 49 mpg back... which is mighty impressive considering the Prius was fully loaded inside and carrying 2 bikes on back.
  10. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    When I go long distances, after running out of battery, I get 52-56 mpg. Great ICE.
  11. bisco
    52,277
    thursday, i did my usual 75 mile trip to my fathers, but i forgot to plug in. :mad: 24 miles of highway at 57mph, balance between 30 and 45 mph, middle of a nor'easter, high winds and driving rain, temp 54 degrees, heat set at 75 manual, 61 mpg on the mfd.
