Sub 205/50R17 for 215/45R17?
Discussion in 'Gen 3 Prius Main Forum' started by Mendel Leisk, Oct 18, 2014.
  1. Mendel Leisk
    41,898
    Anyone done the above, and stuck with it? I know it's been mentioned, just wondering the current situation. If you've done this, how did it work out for you?
  2. JC91006
    JC91006 Senior Member
    16,827
    8,600
    People regularly sub 215/45 for 215/50. Just a higher side wall. Fits good either way
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    I sold the car so I didn't have the 205/50/17s on there for long but I prefer that over the 215/45/17s. Just watch which tires you buy. A lot in that alternative size are XL rated which may increase ride harshness. XL tires should be safer and resist blowouts more though.
    If ground clearance is an issue then go with the 205/50/17. It's not much but every 1/2" counts right? ;)
  4. Mendel Leisk
    41,898
    One big hurdle, if you use Costco or someone with similar culture, could be convincing them to mount alternative size. Actually I'm so fed up with them after their last cock up (sold me 3 right and one left X-Ice) I may just shop elsewhere.
    It'll be a while, but I love to window shop. ;)
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    Get a price from them then take it to your local equivalent to Discount Tire. Most places will match or come close. :)
  6. Mendel Leisk
    41,898
    Funny: Kal Tire was close or even lower, when I checked AFTER buying those X-Ice at Costco (for another vehicle). Except rebates are mail-in at KT. They're a couple/three blocks from us, strong contender.
    Yeah we drive around winters on 195/65R15 snows. 205/50R17 are virtually same OD. Think they'll easier ride, better fuel economy.
  7. situationalawareness
    83
    43
    San Tan Valley, AZ
    Will that size be a temporary fix for the odometer issues?
  8. Mendel Leisk
    41,898
    Do you mean the speedo issue? That it reads about 4% fast? That's legislated, I don' mind it.
    Regarding odo, it's a bit of mystery if toyota adjusted for 215/45R17, which does 1~2% more revs per given distance, comparing to stock 195/65R15. 205/50R17 is virtually the same revs as stock, VERY slightly less.
  9. situationalawareness
    83
    43
    San Tan Valley, AZ
    What do you mean it's legislated?
    Yes, I meant the speedometer, to compensate for the appoximate 1.5-2 mph discrepancy.
  10. Mendel Leisk
    41,898
    Legislated as in legislated.
    And yes, if I put a 1.5% larger OD tire on a car with speedo reading 4% high, it'll read a little closer to accurate. It'll be 2.5% high.
  11. situationalawareness
    83
    43
    San Tan Valley, AZ
    Yes, I understand you typed legislated, I wasn't sure what you meant. The governments made laws legislating the need for an inaccurate speedometer?
    Thanks for the tire info.
  12. Mendel Leisk
    41,898
    Yes, to err on the side of caution.
  13. Tideland Prius
    16,615
    Yes, a car can read higher than actual (but must fall within a certain %) but can never read below actual. Different manufacturers have varying degrees of speedometer discrepancy with German cars typically having the highest "errors" (apparently because their clientele is more likely to swap out the stock tires for larger rims)
    situationalawareness likes this.
  14. Mendel Leisk
    41,898
    Anyway, anybody using 205/50R17?
  15. situationalawareness
    83
    43
    San Tan Valley, AZ
    Thank you for explaining it, unlike other people :)
  16. Kiwi7910
    Kiwi7910 Junior Member
    New Zealand
    I went with 215/50R17 when it was time to replace the 215/45R17. The results have been all positive. Road noise is reduced and the speedometer is more accurate.
    Here is the car with the 45% profile on the front and 50% profile on the rear. The speedometer was only affected when I replaced the fronts with 50% profile to match the rears.
    #16 Kiwi7910, Aug 13, 2025
