I need Transmission help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rocket_Man, Oct 20, 2014.
  1. Rocket_Man
    Rocket_Man New Member
    Orange, CA
    2001 Prius
    I
    I dropped the trans pan on my 01 Prius today, the oil looked clean/clear but along with other debris in thepan I found some pieces of pink plastic.... Very small like bread crumbs and a couple larger ones about 1/8" by 3/16".
    Very concerned about this. Any guesses?
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    Coagulated tranny fluid???
  3. JC91006
    JC91006 Senior Member
    16,754
    8,557
    There's nothing to worry about. It's a 2001 model. If it's running fine, just continue driving it. If it has some mysterious damage, it's not like you can do anything about it. Just get on your day as usual.
  4. Mendel Leisk
    41,207
    I'd think the crumbs are fragments broken off from sealant/gasket, not a problem, but I'm not that knowledgeable.
  5. Rocket_Man
    Orange, CA
    2001 Prius
    I
    I hope you guys are right. It seems to work better than before the trans service but, it's hard to tell. Those particles were consistent all the way through the caked on sludge in the pan, mostly small bits but a few larger chunks.
  6. Patrick Wong
    18,200
    6,500
    I agree with this assessment.
  7. Mike500
    Mike500 Senior Member
    2,593
    767
    Might be congealed assembly lube.
    Again, nothing to worry about.
