A/S tires for winter
Discussion in 'Gen 3 Prius Accessories and Modifications' started by R1CH13, Sep 10, 2014.
  1. R1CH13
    R1CH13 Member
    Michigan
  2. Nelle
    Nelle Junior Member
    Rich, did anyone get back to you? I've moved to Utah with a 2011 Prius, and I need to buy winter tires too.
  3. KennewickMan
    KennewickMan Junior Member
    39
    I have the Continentel PureContact I use all year best tire and very quite...........
  4. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    How is the gas mileage with the pure contact? Did you drive with them on ice or snow?
  5. Kennewick Man
    Kennewick Man Junior Member
    42
    Kennewick,Wa.
    No lost in gas mileage...............this will be the 1'st winter on them............
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    Of those listed the PureContact is likely the best bet. Put the Micheline Premier A/S on your list too. Please keep in mind that all-season tires begin to lose pliability and this stopping traction once temps get below 45F regardless of any snow or moisture on the road surface. Winter tires are designed to remain pliable in low temperatures and so braking distance will be better with them. If you can afford to do so I would recommend two sets of wheels/tires. One for winter and one for the rest of the year.
    Expect to lose a couple of mpg with the PureContact and any other good performing tire.
  7. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    That's what i started doing 3 years ago and only use the winters from Nov - Feb, unless it snows later in the year as it did this year here. I take a 5-8 mpg hit with my GY ultragrips, but the traction is something else in the snow. I'm alot more confident than with my GY summer tyres.
    F8L likes this.
  8. Mendel Leisk
    41,859
    ^ Further on separate snow tires, likely on extra rims: they are an extra investment up-front, and need storage. OTOH, they extend the tread life of your regular tires, afford an opportunity to detail their rims thoroughly and just keep them outa winter's worst.
    F8L likes this.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    For the lurkers who might want more information on tire dynamics.
    (really like this one)
    R1CH13 likes this.
  10. Tony D
    469
    132
    Dublin, Ireland
    Yes, initial hit on rims (i bought a cheap (€40/50) set of 4 Avensis rims, same as Corolla I think and sprayed them myself with a rattle can) and also had the 4 tyres from my Golf. The winters seems to have a very deep thread so will last a long time anyway as I've ran them 3 winters now and cannot see much wear at all.
    My tyre guy said to avoid the A/S as they are neither summer or winters and somewhere in between and that suited me. I have decent LRR Goodyear summers for 9 months of the year & decent branded winters for the other 3 or so months. It's a win win for me in my situation
  11. R1CH13
    R1CH13 Member
    Michigan
    I decided to go with Continental True Contact (standard touring a/s). So far my mpg is around 52mpg rather than 60mpg compared with the Bridgestone Ecopias I had on my 17" wheels. Overall, the Continentals perform well in dry pavement, quieter than my Ecopias (56,000miles on these tires), and I'm sure they will perform well in the snow since they have a similar design to the Pure Contacts. I highly recommend getting these, especially when they're $75 on tirerack.com and comes with 90,000 miles warranty.
    F8L likes this.
  12. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Hey Rich I am getting the True Contacts from TireRack mounted on Friday on our Prius.
    R1CH13 likes this.
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    I'm eager to hear your thoughts on the TrueContact tires!
  14. Gasolean
    Gasolean Junior Member
    24
    I'm in the same boat. Looking to replace my Yokohamas. I am leaning towards Continental Pure Contact. Have read some reviews that they don't last and have road noise...but I think I am still leaning towards them. The Michelin Energy Saver A/S And Ecopias don't seem to have good wet, snow or ice performance. I had the Pirellis on my 2006 Prius and they were great in all conditions and lasted forever, but my MPG suffered. I wanted to look at the Nokian WR G2 as those were softer tire but doesn't look like those are available anymore.
    Although now after looking at that first video that F8L posted about temperature and tires I thinking about doing winter tires and summer tires!!! UGH! But I do some highway driving (holidays) in the winter and I do more "country" driving than city - so wont that just chew them up more?
    F8L likes this.
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    I'm not sure if we have enough data on the longevity of the PureContact. A lot of reviewers confuse them with the ProContact which did have longevity issues. You could also consider the Michelin Premier A/S. It's pretty much better than the PureContact all around or at least close enough to it.
    You can drive winter tires on the highway. As long as the temps are not very high the wear shouldn't be an issue. It's definitely the safest option. If you are not completely strapped for cash this is the route I recommend. Sure people get by with A/S tires in snowy regions but lots of folks also have accidents too. Why gamble?
    Tony D likes this.
  16. Slick26
    Slick26 Junior Member
    40
    Twin Cities, MN
    Don't have time to read everything, but I'm in the same boat. I've read here, and elsewhere, that Nokian Hakkapeliitta R2 tires are a great fuel efficient dedicated winter tire. No experience with them. But I'm seriously considering giving them a try.
    I can't go another winter with A/S tires. They just don't cut it in Minnesota. I do way too much driving, at all times of the day and night, and need to be at my destinations on time, so I'm going with dedicated winter tires this year.
    Windows Phone ?
    Tony D likes this.
  17. R1CH13
    R1CH13 Member
    Michigan
    Update on my continental tires. I have 2,000 miles on my tires right now. Feeling bittersweet right now, since I was rear ended :/ but these tires are phenomenal. I like these more than my Bridgestone Ecopia EP422 A/S. I had great stopping power and took off with a breeze although handling is a little different (maybe it's because I'm use to driving with 17" wheels rather than 15"?) Driving on dry payment I rate a 9/10, rain 8.5/10, snow 9/10, and I did drive it on ice and my car was sliding but it wasn't as bad as other peoples. I saw a Impala spin out in front of me while I was going downhill and luckily the traction on my tires were good enough for me to avoid it. :) By the way, my average mpg with 30 degree weather is about 45-48mpg (I warm up my Prius 10-15 minutes before I drive so yeah...)
    F8L and kenichols29 like this.
  18. R1CH13
    R1CH13 Member
    Michigan
  19. Slick26
    40
    Twin Cities, MN
    Update:
    I bought a set of these tires and went a full winter with them last winter AND kept them on all summer. Winter traction was great in almost all conditions, but not as good as previous non-LRR winter tires I've had in the past on different vehicles. But clearly more traction than an all season tire. The most impressive attribute to these particular winter tires in their incredible resistance to wear while driving the car in summer. Our temps in MN regularly reach into the 80s and 90s and we have stretches of 100 degrees here and there with oppressive humidity levels. These tires seem to be wearing as if they're all seasons. THAT sets them a part from all the other winter tires I've owned. Now, I realize you're probably thinking, "that's great, but I don't buy winter tires for use in the summer." True, but if the wear is this good while driving in the summer, they're going to wear even less while driving in the winter. That's my point. They're worth the money for that reason alone. Also, the fuel economy hasn't suffered as much as I expected. I still average 45 MPG, whether in the summer with the AC on, or the dead of winter in sub-freezing temperatures. The only thing that suffers MPG for me is running the car too long in the winter to warm it up before I get in.
    LG-H810 ?
