display max 99.9 mpg. does car know the real mileage?
Discussion in 'Gen 2 Prius Fuel Economy' started by derekderek, Oct 25, 2014.
  1. derekderek
    derekderek Junior Member
    27
    westville NJ
    so computing avg fuel mileage. there are a lot of times display shows max of 99.9. does the car use that number to compute avg? or is that just the display's max and the car knows it is 155 or infinite mpg? (rolling downhill gen charging HV batt using no fuel actually more than infinite mileage...)
  2. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    From my experience it uses the actual, not simply the 99.9 that may be displayed. You may test this by resetting the mpg display just before you begin a descent where your engine will be off and then judge by the amount of time it takes the reset mpg to drop below 99.9.
  3. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    when it shows 99.9mpg, the engine is off, thus the number is irrelevant...
    however, the distance u traveled at 99.9mpg will be spread out through the rest resulting in higher mpg...
    at least that's how i understand it...
  4. PA Prius
    762
    251
    SE Pennsylvania
    MJ50, correct except that the engine is not necessarily off when it is showing 99.9 mpg, but it is getting 99.9 or more mpg. The engine does not shut off at speeds over 41 mph.
    MJ50 likes this.
  5. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    At speeds above 42MPH or 67km/h engine has to spin.
    But it can be spinning by:
    -Force from wheels (engine braking). With no fuel consumption.
    -Electric motor spinning it. With no fuel consumption.
    -Running or idling. Using fuel. But (if) it's still getting more than 99.9MPG it just shows 99.9MPG. Unless you have Prius with L/100km display. It will show about 2L/100km in this situation (depending on speed and other stuff). And 0L/100km if engine isn’t using fuel at all.
    MJ50 likes this.
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    All the computer in the car "knows" is the distance travelled and the amount of fuel used.
    The 99.99 just indicates that, at the moment, the engine is using little or no fuel.
    The miles are still counting up and the gas usage is still counting up for the real average.
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    The others covered it well but I'll add that with a Scanguage hooked up or using the Torque app you can see exactly how much fuel is being used at any given time. The displayed iMPG is simply for your viewing pleasure and maxes at 99.9mpg. The actual calculations are going on behind the scenes. FWIW even the Scanguage maxes out at 9999mpg. lol
  8. Mendel Leisk
    41,905
    My metric set Scangauge shows best fuel economy as zero (gas consumed). Much better. ;)
    F8L likes this.
  9. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    I have a Dash Dyno SPD scanner hooked up to my 2004 Prius. It has AVG mpg, Instant mpg and RPM and other handy measurements. Not as good as a Scangage, but I already had this one.
    When I coast and the engine shuts down the mpg shows the calculated mpg. The MFD shows 99.9 mpg, if I press on the throttle to get into EVmode and I get numbers that flash wildly and the highest is over 7000 mpg! It is fun to watch.
  10. bisco
    52,393
    now that's crazy!:eek:
