Car Louder After Air Filter Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Blue Lightening, Oct 26, 2014.
  1. Blue Lightening
    Blue Lightening New Member
    San Jose
    I replaced the air filter a couple of weeks ago, and noticed immediately afterwards the car is much louder at high RPMs. It's not really noticeable unless you're using 50%-100% of the throttle, and the RPMs spike up. The best way to describe it is that it is both louder and lower pitched than usual. I've checked the airbox and everything is installed and latched correctly. Any ideas? I'm a little stumped...
  2. Patrick Wong
    18,200
    6,500
    1. What brand of engine air filter did you install?
    2. How dirty was the previous filter?
    3. Is it possible that the old filter had so much dirt on its surface, restricting airflow, that now that you have a new filter and the engine can breathe, you can now hear some engine intake noises?
  3. Blue Lightening
    San Jose
    1. I can't remember the brand, it was some generic filter I bought on eBay bought it was the right size, etc. for a '09 Prius.
    2. The filter was grey, but it didn't look filthy.
    3. That was my first thought, but it's a pretty significant change. Again, it's much more low pitched, a much deeper sound. It seems to be more than just the volume that's changed...
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    You sure you put the air box back on correctly?
    HaroldW likes this.
  5. Blue Lightening
    San Jose
    Edit: I found the link to the filter but can't post it because I'm a new member. Below is the title of the listing on eBay:
    "AF5698 C35516 CA10159 CF9846 2004-2009 TOYOTA PRIUS ENGINE AND CABIN AIR FILTER"
  6. JC91006
    JC91006 Senior Member
    16,761
    8,562
    Is it installed the right way up? The rubber gasket is fitted properly?
  7. Blue Lightening
    San Jose
    Yes, I've checked this multiple times. It just closes and latches.
  8. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Have you checked everything? Including the air pipe and whether it's come off further along or if some of the other pipes have come loose too.
  9. JC91006
    16,761
    8,562
    Normally if the airflow is increased, then you'll hear a louder sound. So you just might have a filter that's thinner than the one replaced
  10. Okinawa
    Okinawa Senior Member
    1,333
    320
    I would buy a Toyota brand filter and see how it works. I only use Toyota filters.
    #10 Okinawa, Oct 26, 2014
    Stevie likes this.
  11. JC91006
    16,761
    8,562
    Make sure the airbox is tightly connected to the throttle body
  12. Patrick Wong
    18,200
    6,500
    AF5698 C35516 CA10159 CF9846 2004 2009 Toyota Prius Engine and Cabin Air Filter | eBay
    There is no manufacturer brand name provided on this listing, so who knows how good this filter is. It might use toilet paper or worse for the filtering element. Given your report of so much additional intake noise, it seems that the filter element is thinner than normal.
    For fun, remove the filter, replace the air cleaner housing with no filter inside, and see how the engine noise changes.
    I personally would not install such a filter in any of my vehicles.
    MJ50 and Stevie like this.
  13. Blue Lightening
    San Jose
    This is sort of my leading thought as well. I may look at ordering a different one and see if it's better. Anybody have a recommendation on where to buy a OEM one?
  14. Mendel Leisk
    41,307
    Toyota dealership parts department??
    Stevie likes this.
  15. Okinawa
    1,333
    320
    At the Parts Department at any Toyota Dealer.
  16. Blue Lightening
    San Jose
    I was hoping I could find them somewhere online..
  17. JC91006
    16,761
    8,562
    You can buy a fairly decent fram air filter for about $10 - $15 on amazon or local retailer
  18. Blue Lightening
    San Jose
  19. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    There's your answer.
    It is a DIFFERENT filter construction than the OEM filters.
    If you still have the old one, put it back in to confirm the difference.
  20. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    I buy oil and air filters from Auto Nation Toyota. Here is an OEM air filter for $13.50 plus shipping.
