Red Triangle, drives well, but battery at 9.6V - am I on the right track?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chickenboy, Oct 27, 2014.
  1. chickenboy
    chickenboy Junior Member
    Chelmsford, Essex
    I have a UK 2006 Prius, 120K on the clock. Yesterday had slightly odd thing where car was not locking, just "clicked" once, but doors didn't lock. Think I started the car, stopped, then it was all fine - and promptly forgot about it...
    Today, got in, big red triangle/exclaimation mark, yellow engine, VSC warning, but it drove normally - not in limp mode (yet!). Have done a bit of reading, tried the Display Check > Vehicle Signal Check menu, and the Battery reads as 9.6V - see picture.
    (Instructions from Weird stuff happening? MPGs dropping? Test The Battery | PriusChat)
    Is that definitely the problem? That battery has never been changed to my knowledge (I've had the car 3 years) - so it it just a simple swap out for a new one? Do I need to reset the red triangle warning somehow?
  2. JC91006
    JC91006 Senior Member
    16,872
    8,619
    Yes you definitely need a new 12v. Just swap out the old with new. Hopefully that'll resolve your red triangle.
    GrumpyCabbie likes this.
  3. bisco
    52,537
    check with brit prius, he's got the rundown on uk 12volts.
  4. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    At 9.6 volts I am surprised your running at all. Low voltage 12 volt batteries in the Prius can give all sorts of problems.
    After fitting the new battery you will loose the drivers window auto close setup, and the car will take a little while to relearn you driving so will use more fuel.
    Also after fitting you will need to go through two start procedures before it will start.
    John (Britprius)
    Robert Holt and GrumpyCabbie like this.
  5. chickenboy
    Chelmsford, Essex
    Thanks John - I could fit it myself i'm sure, but I think I'll see how much Toyota want first.
    If Toyota decide to have a laugh tomorrow - what spec of 12V battery do I need?? - just been looking on halfrauds and there seem to be so many 12V batteries that don't look right!
  6. Britprius
    5,194
    1,922
    If you take my advice do not buy from Halfrauds. There are many batteries in the UK for the Prius. Varta and Bosch make replacements starting at around £40 depending on the length of guarantee (up to 5 Years) The battery has to be a very specific size to fit and should have JIS posts (Japanese Industrial Standard) these are smaller than normal imperial posts. The positive post must be on the left with the terminals (posts) closest to you.
    Buy the battery from any motorist spares shop If you need battery model numbers let me know.
    Expect to pay about £100 for the battery at the dealers plus fitting.
    John (Britprius)
  7. chickenboy
    Chelmsford, Essex
    Sounds like I need to sort this pronto - I'll report back with my bill from Toyota :-(
  8. Britprius
    5,194
    1,922
    I would ring the dealer and check the price first you could easily save £50.
    John (Britprius)
  9. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    [/QUOTE]I would ring the dealer and check the price first you could easily save £50.
    John (Britprius)[/QUOTE]
    John are you still recommending the Mobility Batteries or have the price options increased significantly in the UK?
  10. Britprius
    5,194
    1,922
    John are you still recommending the Mobility Batteries or have the price options increased significantly in the UK?[/QUOTE]
    I would still recommend the mobility batteries over OEM type batteries. Both have risen in price due to the increase in the price of lead, but not substantially. Most people however understandably do not want to alter fuss with the terminals. I have now changed a number for friends.
    John (Britprius)
  11. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I thought the Toyota price was fixed at £95 including fitting. Considering the faff with the vent tube it might be worth just getting the dealer to fit it?
    Repairs & Parts - Toyota Owners | Toyota UK
    Scroll down to the Fixed Price Repair section and then update the car to the correct Prius and it displays the 12v cost.
    Maybe the op would consider the Hybrid Health Check for £39 as his car is close to warranty expiry or maybe out of it?
  12. chickenboy
    Chelmsford, Essex
    Exacty right - booked in for saturday morning 9.30am, £95 with fitting and vat.
    Just hoping it can last until saturday!
  13. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Fingers crossed we don't get a cold snap.
    Have you considered the Hybrid Health Check? It's only £39 and offers an additional 10k miles/12 months warranty on your HV battery. Might be a consideration as you're now out of manufacturers warranty.
  14. chickenboy
    Chelmsford, Essex
    HHC interests me - so read on Toyota site, as you say...
    "With each Hybrid Health Check you will get up to 1 year or 10,000 miles extension (whichever comes soonest) on your hybrid battery cover which can be renewed up to the 10th anniversary of the car's registration with no limit on total mileage."
    So I've only got 2 years possible (its an 06), but that does sound like a good deal if it will cover me for hybrid battery failure for a year... (I've replaced a cell on the hybrid before, not sure I have the patience to try that again!)
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    And it's unlimited mileage, assuming your HV battery passes the first time. I haven't heard of one on the UK forms that hasn't.
    So whilst you only have 2 years left (it's 10 years inclusive or upto 11), the benefit depends on how many miles you do a year. They also provide the HHC free as part of a main dealer service so it could work out cheaper to go to the dealers overall. And you could always try and get the dealers to price match - though not all will. You don't ask, you don't get :)
  16. chickenboy
    Chelmsford, Essex
    Oh well, battery now completely stuffed - can't even unlock the doors. (also parked in our shared parking which is inaccessible to tow trucks, and it seems to be locked in gear so can't push it out). Having to get my sister in to jump start, then dump at Toyota until they get a battery in :-(
  17. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Be VERY careful when jump starting a Prius. Your sister must NOT rev her engine and you must ensure you don't short out the jump leads on the car as you'll fry the computers. Also, the Prius takes an age to charge a dud battery so once you are started you don't want to stop.
    Good luck
  18. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    It is actually best if the "donor" vehicle is left OFF......and the connection is removed immediately after the crippled car starts.
  19. Britprius
    5,194
    1,922
    The Toytota extended guarantee is free with any service so if you wait till then it would cost nothing.
    John (Britprius)
  20. Easy Rider 2
    1,584
    258
    Ocala, FL
    I read that 4 times and then stared at it for a while and then read it again.
    I still don't understand what you are trying to say.
