Oil Change 2010 Prius - do it yourself
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mr. Bill, Aug 22, 2009.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
    A small 1/8" blade screwdriver works just fine for temoving the plastic rivets.
    Although I have 12 or more torque wrenches of all different sizes, my mehod of marking the position of the tightened filter cap on the engine works best and is a "no brainer." I've uploaded a photo.
    Also, I've replaced the easily pulled off rivets on the oil change door with "rivet nut" inserts and M6 stainless steel Phillips head screws.
    #481 Mike500, Oct 30, 2014
    WE0H likes this.
  2. Tbkilb01
    Tbkilb01 Active Member
    216
    187
    Louisiana
    I went to dealer yesterday to pick up 5 qts toyota oil and a filter. And they only had 3, so they included 2 mobile 1 full synthetic. (n).. Back of Toyota oil says it comes from Exxon-Mobile! :cautious:
  3. Tbkilb01
    216
    187
    Louisiana
    I left mine off. 165000 miles... No harm no foul
  4. Mendel Leisk
    41,381
    I take the whole cover off at each oil change (about eleven now), and then put it back on. The access flap spoke to me, said quite emphatically it does not like being bent back.
    Goes pretty quick. I always wash the grit out of the fasteners, I'm pretty sure they're all original still, I'm losing track though.
