Side view mirrors not working! Ideas!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by stlprius, Nov 2, 2014.
  1. stlprius
    stlprius Junior Member
    Missouri
    All of a sudden the Sideview mirrors on my prius aren't working. Which fuse controls the Sideview mirrors? Any other suggestions?
  2. LisaNC
    LisaNC Junior Member
    The same thing happened to me. I took it to the dealer for my oil change and asked them to change the fuse. They came back and said the two "channels" to move the mirrors were filled with leaf debris. They cleaned them out and they work great now. Sorry I can't tell you how to get to them to clean them out, someone else might be able to help.
  3. GardenWeasel
    GardenWeasel Member
    76
    53
    Columbia, SC
    Interesting. Mine quit working maybe 10 months or more ago.
  4. Former Member 68813
    3,524
    983
    US
    I see, the motorized adjustment failed?
    Initially I was concerned the mirrors failed to reflect.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Try turning on a porch light if dark out.
  6. Maj
    Maj Junior Member
    Orlando, FL
    One of my mirrors didn't work when I bought the car (forget which one). After flipping the left/right switch about 50 times it sprang to life. The contacts must be susceptible to corrosion. Still gets balky once in a while and I have to "polish" the contacts again.
    GardenWeasel likes this.
  7. GardenWeasel
    GardenWeasel Member
    76
    53
    Columbia, SC
    I'll try that. Certainly cheaper than a dealer repair. :)
    Edited to say...OMG!! It worked! I counted 25 flips of the switch and now both work again!
    #7 GardenWeasel, Nov 9, 2014
  8. Futureboy
    Futureboy Junior Member
    Chicago
    I had a similar problem. Left worked ok. Right was intermittent. I was able to easily replace the switch with one I purchased used off ebay for just $25. It's a very easy repair/replacement once you have the switch.
    #8 Futureboy, Jul 21, 2017
  9. charleslo
    charleslo Junior Member
    Santa Clara, CA
    anyone know the brand and part # for the replacement? i can't seem to find it. appreciate if someone can give a pointer to the site where I can buy the replacement part.
  10. xliderider
    xliderider Senior Member
    8,084
    3,237
    Honolulu, HI
  11. charleslo
    Santa Clara, CA
  12. xliderider
    8,084
    3,237
    Honolulu, HI
  13. Gary0
    Gary0 Junior Member
    Los Angeles
    Both of my 2010 Prius side mirrors stopped working. I spent a few hours searching for answers, then trying to figure out what fuse(s) might be involved... and happened to glance at your post. Gave it a try, flipped the L/R switch back and forth about 50 times and it worked!!! Amazing... thanks!!!
