Steering wheel leather/rubber falling apart
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by scotty321, Apr 2, 2012.
  1. scotty321
    scotty321 Apple Mac Expert
    59
    Austin, TX
    Hi there,
    I have a 2010 Prius, which I normally drive by putting my hands on the sides or the bottom of the steering wheel.
    But then yesterday, I was resting my hands on the top of my steering wheel, and it felt weird. I removed my hands, and little pieces of black leather (rubber?) were covering my hand. I looked closer at the steering wheel, and the entire leather (rubber?) covering of the steering wheel appears to be falling apart... practically disintegrating before my eyes.
    I've attached 2 photos below. I took these at nighttime, so let me know if you need to see better photos during the daytime.
    Is this normal for a steering wheel to be doing this? Is this covered under warranty? Can I get this replaced by Toyota? Any advice or guidance or experience with this?
    Thanks! :)
    Scott
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I have the same deterioration but in a much smaller area at the top. It's most certainly a manufacturing defect and you should get it replaced under warranty.
    Doesn't matter to me as I plan to swap it out for the much nicer JDM piano black steering wheel with the enlarged thumb rests.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I also have a 2010 and my steering wheel looks pretty much brand new, so I'd say that's not normal and should be replaced under warranty. My guess is it's caused by exposure to the sun, since you don't drive with your hands on that area.
  4. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Maybe from direct heat at the top but it can't be from UV exposure as the factory windshield has a 100% UV cut rate.
  5. stream
    2,977
    452
    Long Island, NY
    I don't remember saying it was from UV exposure... ;)
  6. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Just clarifying so people here don't freak out and stink up their interior with 303 Protectant or something :)
  7. scotty321
    59
    Austin, TX
    Thanks so much, you guys! :)
    I really appreciate your feedback... this forum is the best. :)
    Many thanks,
    Scott
  8. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    Ewwww...that looks awful! Few questions. Do you park outside for extended periods of time? Have you used something to clean/treat the leather previously, which might be affected by sun and is "shedding"?
    I've had mine for almost 3 years now and the leather looks brand new. It spends more time in the garage than out in the sun.
  9. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I put one of those leather wraps on mine in September, and can already see spots where a very thin top layer is wearing off. I would absolutely take it in to get it replaced under warranty. I hear that oils from the skin can be harmful to leather and thought it was recommended to clean and protect it periodically. Then again, I didn't really read the info sheet all that closely on my wrap :)
  10. scotty321
    59
    Austin, TX
    Yes, my Prius has always been out in the sun from day one! I do not have a garage, and the sun just beats down on it all day long. :(
  11. scotty321
    59
    Austin, TX
    Thanks for the info.
  12. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I'm parked in an underground garage at work most of the week and it's out in the sun only on weekends. The location of the deterioration on my steering wheel happens to be aligned with the path of the sun and I'm sure mine would have ended up like yours had it been out in the sun all the time.
    True, but even oil won't cause the type of damage shown in the OP. If anything, oil would cause leather to lose its texture, giving it a smoother appearance over time.
  13. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Some people have more corrosive skin oils/sweat. I have a brother-in-law that goes through eyeglass frames because his skin oils are eating the metal. Have you noticed issues with handling other items, like cell phones or keyboards?
    My steering wheel looks & feels like new, but I use leather cleaner/protectant on a regular basis (same for the seats).
  14. scotty321
    59
    Austin, TX
    Nope, and I owned my previous car for 8 years without the slightest bit of problem on the leather steering wheel. I'm pretty disappointed with this turn of events. I have an appointment with my Toyota Dealer next week... let's hope they do the right thing and replace this under warranty.
  15. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    If that were true, the deterioration would be found all over, not just the top part where it gets the most sun/heat exposure, as in my case.
  16. harrybet
    harrybet Junior Member
    Kamuela,Hi.
    '08 prius ...40k mi. Hawaii ...Hi. Distributor doesn't want to know about it...local Dealer doesn't want to know about it...have sent a 'Hail Mary' to corporate...am awaiting a response... 30 yr + exclusive Toyota family...Toyoto people don't give a s@#t ...they claim ignorance of the issue and 40 k miles in ,too bad!
  17. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Put a Wheelskins leather cover over it. ;)
    SCH-I535
  18. harrybet
    Kamuela,Hi.
    Just heard from a paddling buddy...w/ an '08 Prius/160k mi....Hers' (Steering Wheel) is in worse condition than mine . Her plastic spoiler is fine though .
  19. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Mine started doing this at from 11 to 1 oclock I bought a leather cover and installed it.
