Are there any LED's that I can use in my fog lights?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ES44AC, Nov 5, 2014.
  1. ES44AC
    ES44AC C.A.U.S
    319
    77
    I may have asked a similar question a long time ago, but I see so many changes in LED technology that I thought I'd ask again.
    My Prius has the kit shown in the Prius store, they have 55w H11 Halogens in them. Is there a new style LED that I can plug in to replace the existing bulbs that would be visible in the daylight?
    I see the new Prii have LED DRL's too bad they won't retro fit my 2011...
    Thanks in advance! :D
  2. pauerbach
    pauerbach Member
    101
    34
  3. ES44AC
    ES44AC C.A.U.S
    319
    77
    Thanks a lot for the info, glad I asked about them. Are they just bright but really don't put any useable light on the road? Or can you actually use them to see the road? By accident I have only had my 55W fogs on thinking for a moment had my headlights on... that's why I ask.
    Regards
  4. Mendel Leisk
    41,826
    Reading the comments in pauerbach's link, I kinda like:
    "defiantly a good buy...". ;)
    I'd just echo ES44AC concerns: are they effective, an improvement on the OEM, throw more light on the ground? (Not that that would be much of a stretch.) The comments on the whole seem to regard appearance, not effectiveness.
  5. pauerbach
    pauerbach Member
    101
    34
  6. pansontw
    pansontw Member
    17
    Houston
    How about Valenti LED DRL integrated Projector Fog?
    DRL part is 3W/each side. Projector fog is 6W/each side
    http://www.valentijapan.com/products/jewel_fog_day_kit.html
    #6 pansontw, Nov 11, 2014
  7. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
  8. kenmce
    kenmce High Voltage Member
    1,549
    522
    NY
    Even with Xenon, I'm having trouble picturing an 18 watt incandescent bulb putting much light on the road. It should be fine for a running light.
