Canadian fuel economy ratings changed, more realistic?
Discussion in 'Gen 3 Prius Fuel Economy' started by Mendel Leisk, Nov 5, 2014.
  1. Mendel Leisk
    41,940
    It doesn't? Groan, I better go make coffee, brain is full. ;(
    SageBrush likes this.
  2. Mendel Leisk
    41,940
    Dealerships still LOVE those hwy no's. The Malibu city rating is 9 point something, not so good. See one model at least has start-stop.
  3. Tideland Prius
    16,623
    Well done! Still haven't hit that 1,000km mark :( (955km is the closest but that got wiped out with that inverter TSB update).
    HaroldW likes this.
  4. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    The update had no effect on my 2014 gen 3. H
  5. Mendel Leisk
    41,940
    Tidelands, do you mean update reduced your fuel economy, or it just reset your trip meter?
  6. Tideland Prius
    16,623
    Oh, reset. My "Best" in the Past Record screen now displays something else other than the 4.0L/100km (950km) (cause my 955km had an average of 4.1L/100km so it didn't register). I'll wait til next summer before wiping the "Best" number and then trying again for a record :)
  7. Mendel Leisk
    41,940
    I use the car's tripmeters for reference only. Like to gauge how I'm doing for the current tank. For a couple of reasons. First, it's just not bullet-proof: an inadvertent button push and there goes your record. Secondly, it's not accurate, intentially rosy. I do use it for feedback though. For tracking mileage I just record the odometer, at each fillup. Regardless of what you have displayed, it shows when you shut the car down, for about 30 seconds. And I find if I mutter it to myself, it's branded in short term memory, at least for duration of tanking up and getting the receipt to jot it down.
  8. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    Hmmm.... not that cold around here yet, but so far on a tank from Superstore I am seeing 4.2-4.4, on my Nokian WR3G's.
    I tend to buy the cheapest gas around in the belief that there is not much difference. the tankers that supply Superstore around here seem to make deliveries to Esso and I sometimes see the same vehicles in front of the local Shell.
    Roland
    HaroldW likes this.
  9. Tideland Prius
    16,623
    It shouldn't since Shell and Esso are Top-Tier certified but Superstore/Loblaws isn't. Technically, there should be a difference in the fuel composition between the supermarket brand and others.
  10. Mendel Leisk
    41,940
    Here's a current local chevy ad, methinks they're up to their usual tricks, stretching the limits of credulity:
    Here's the Canadian government's offial rating for the Cruze. There's ONE Cruze , the diesel model,rated at 4.2, under the OLD rating system:
  11. GregP507
    GregP507 Senior Member
    3,002
    481
    Perhaps that highway mileage figure was obtained by following closely behind a semi from the summit of the Great Divide to the coast.
    You never know.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    ^^ The new ratings combined city + highway is close to 7 L/100km for the diesel.
    Sounds like a Prius killer ;)
  13. Mendel Leisk
    41,940
    I think the ad has crossed the line: it shows a "Cruze LT Automatic", doesn't sound much like a diesel. Then down below: 4.2 liter/100 km. No asterisk, no fine print.
    It's an "ex parrot"....
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    Is it typical for terms to be quoted bi-weekly ?
  15. Mendel Leisk
    41,940
    No idea, we always buy, just cut a check for the full amount.
  16. SageBrush
    11,627
    2,533
    Southwest Colorado
    There are entire scam industries centered around people's tendency to equate one month and four weeks.
  17. Tideland Prius
    16,623
    Technically it's not wrong since it's for a 2014 Cruze, not the 2015.
  18. Mendel Leisk
    41,940
    Well, the only Cruze mentioned in the ad is not the diesel, the one with the miraculous 4.2 hwy number.
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    That sums up the GM approach to advertising quite nicely
  20. Mendel Leisk
    41,940
    So right now, Toyota Canada is saying on their website the hwy mileage for a Prius is 4.6 (liters/100km), but I could have got a Cruze LT Automatic that get's 4.2..., what was I thinking getting a Prius!
