Lips for winter. Too soon or just right?
Discussion in 'Gen 2 Prius Main Forum' started by kenoarto, Nov 9, 2014.
  1. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    OK temperatures are dipping below 32 degrees. And we are about to get snow in the upper midwest. It think this is the perfect time to install radiator "lips". Just sayin'
  2. Mendel Leisk
    41,334
    What the eff are "lips," lol. Grill blocking?
    Aaron Vitolins likes this.
  3. kenoarto
    398
    Chicago, IL
    Yes, the varied methods of blocking the Prius radiator grills from cold winter temperatures, are often referred to at as "lips".
  4. Mendel Leisk
    41,334
    Ok. It's supposed to get clear and colder over the next few days here, overnight lows below freezing: I blocked the lower opening 50% this morning, one pipe insulation tube (of two).
    kenoarto likes this.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Mornings are certainly cool enough -- high 20s,
    but afternoons can still reach 60F
    SW Colorado
  6. bisco
    51,851
    where are they often called lips?:cool:
  7. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    Great time of the year for "lips"!
    I fitted my winter wheels and tyres yesterday, as I think it's cold enough, i.e. Below 7 Celsius. We're supposed to be getting the worst winter in 100 years here this year
  8. bisco
    51,851
    we're having a warm spell, i hope it last's until i get my 'lips' on!:p
    Tony D likes this.
  9. Mendel Leisk
    41,334
    "Blow my lips off..." is at 4:20, but it's worthwhile to watch the whole thing. ;)
  10. vskid3
    vskid3 Active Member
    773
    228
    Never seen a grill block called lips, and I've been into hypermiling for a while.
    I put my lower grill block on a couple months ago, haven't had any issues with it. I might try blocking the top in a month or two.
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    Public service bulletin:
    The radiator is functionally split into two sections -- top and bottom
    In the Gen2 the bottom half cools the inverter.
    In the Gen3 the top half cools the inverter.
    In cold but not freezing weather, best not to block inverter cooling.
    I personally only block if I can monitor temperatures.
    #11 SageBrush, Nov 9, 2014
  12. Mendel Leisk
    41,334
    Huh? Pretty sure top is inverter on third gen... I always leave top open, for that reason. Hope I got it right.
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    Oh crap, did I reverse the orders ?
    Addendum: Corrected! Thanks Mendel
    #13 SageBrush, Nov 9, 2014
  14. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    The other day I blocked 90% of the grille (top grille fully blocked, bottom grille all blocked except for the top upmost slat). Monitoring with my generic scan tool, engine temps haven't risen above 189f.
    Ambient temps here now flirting with daily highs in the low 40's, mid-low 30's.
  15. bisco
    51,851
    Lower Inverter Protection System.
    PriusGuy32 likes this.
  16. Mendel Leisk
    41,334
    So, anyone done turn signals on their ears?
