Should there be something in the center of the rim?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sethp, Nov 10, 2014.
  1. Sethp
    Sethp New Member
    Sweden
    First off, i want to say that i know nothing about cars and my Current 2007 Prius is my first car.
    In sweden where I live we need to switch tyres during the winter months. The previous owner for some unknown reason decided to use the original aluminium rims during the winter and a pair of other aluminium rims during the rest of the year.
    So after i went to Toyota for them to switch tyres i got to se the original rims for a first time. (Toyota also stores the spare tyres during the seasons) They have a bit of corrosion and dirt so they aren't pretty. But I was thinking, Shouldn't there be like a disc or something in the middle covering the bolts? If so, what's this part called? When I search for hub caps i get pictures of these plastic things that would cover the entire rim, if that rim wasn't an aluminium rim.
    This is a picture of the rim as I remember it, i can go down to the car and take a better picture later if needed.''
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
  3. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
  4. JC91006
    JC91006 Senior Member
    16,800
    8,589
    $.77 wow. I see these on ebay as center caps and they charge much more for them :LOL:
  5. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Yep, when we got the v earlier this year I took off the wheel covers to see a hole in the center. I thought, "cheapskates".
    I believe someone else suggested these on this forum, so off to Home Depot.
    Way cheaper and does the job. :D
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    If you want to pay more for the center piece, Toyota makes one with the Toyota emblem in the center. I used those when I took off my wheel covers.
  7. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
  8. Sethp
    Sethp New Member
    Sweden
    Thanks for the tips everyone! Now I know what to search for on eBay :) Usually I prefer all original parts, but this is purely decorative and to be used between October and April. The caps that mentioned from home depot i've only seen caps like that in white plastic that cover holes where wires otherwise would pop up out. But a knock off with an emblem would be nice.
    grandpaD likes this.
