299,999+ Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Apr 16, 2010.
  1. kammssss
    kammssss Member
    287
    86
    SoCal
    Original engine? If not, that's too amazing.
  2. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    I heard his engine was replaced at + - 350K. But still it is a fascinating story. You can get a used engine with 60K for $650, plus $600 for installation by your own mechanics. I am considering to replace my oil burning engine on the 2004 with 226K miles now. $1300 out of pocket for that newer engine is really cheap!
  3. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    Replaced engine with a used one at 400k. cost around $500 and installed in my driveway. Best car ive ever owned.
    Robert Holt and Tony D like this.
  4. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    The "installed in my driveway" part is what amazes me! Did you by any chance take pics of that process? Post for those of us,who may get to,that same situation someday? (If I can avoid getting hit by people texting for the next 300k ! )
    Come to think of it, if you and 2fas4u have managed to avoid getting hit in 600k of Prius driving, maybe I should take lessons from you guys!
  5. longbow
    longbow Recovering SUV Owner
    62
    34
    Bayfield County, Wisconsin
    I got hit at about 50k by a bear....Passenger side was completely replaced, the last 260k has been less eventful!
    brownsnoutuk and Tony D like this.
  6. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Just dayum! Would love to hear the details of that story...sounds like something out of Field & Stream - "A Bear Tried To Eat My Prius...But I Survived!"
  7. longbow
    62
    34
    It was at night. The road was elevated between two corn fields. The bear was running from one to the other. I did not see him as my lights did not go below road level. It was a sudden WHAM then bump and rumble all down the passenger side. The next morning I discovered a perfect nose impringt in the front quarter panel. The bear was not there...He walked away....
  8. 200Volts
    200Volts Member
    435
    45
    Northern CA
    06 now has 398k miles. Still at 50mpg average (city/2 lane/freeway 33% each).
    Mobil 1 oil changed every 5k for first 100k, then 10k up to 300k, now at 15k intervals (since it burns 1 qt/1k miles I add a few new quarts/mo).
    Trans fluid changed about every 70k. 3rd windshield. Water pump replaced proactively under recall. K&N air filter since day 1.
    Original everything (except MFD, replaced under warranty), catalytic convert and tires. Yes, original hybrid battery, 12V, brakes, shocks(rides like a vet), water pump belt (spare is kept in vehicle). Commuter car, so inside looks almost new. 1 door dent on each side, plus 1 hood dent. 3M clear bra on most of front - still clear. I should have done the entire front, as without the 3M bra it is really pitted.
    Started burning oil about 300k, catalytic converter plugged up at 350k, replaced with used unit for $600, then plugged up again at 396k.
    BTW - this is my second Prius. My 04 had 90k miles on it, so I'm almost at 500k driver miles in Gen 2 cars. And I have Prius V I'll be picking up next week, to replace my 06 (on sales now for $3,750 obo on Craigslist with photos 2006 Prius, Pkg #6, commuter car, non-smoking, good condition ).
    #828 200Volts, Dec 23, 2014
    telmo744, Tony D and Aaron Vitolins like this.
  9. longbow
    62
    34
    My Catalytic converter is starting to complain. I keep resetting the sensor. 317K and counting....
  10. AllenZ
    640
    63
    Chicago
    That's not much, less than $100 for parts, plus labor.
  11. longbow
    62
    34
    Where would you get those parts? $2000 at Toyota
  12. 200Volts
    200Volts Member
    435
    45
    Northern CA
    Longbow,
    Search for salvage yards. Use Craigslist (Prius parting), or the internet (Toyota salvage). Then search for Prius exhaust, if you have the middle pipe number that helps sometimes (on my '06 it's p/n 17410 , and sometimes ends in 21500). Should be about 50% of the dealer price (so about $500-600). Anyone can install it in 30 minutes with a rack, so about $75 in labor. Should last about 40k miles, then it will plug up again. You can inspect yours visually, if you remove it (the blacker it is, the more it's plugged).
  13. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    I thought it was illegal to sell used Catalytic converter ? I ask around before when my Honda Accord 2001 had a bad Catalytic converter. Not sure regarding savage yard.
  14. longbow
    62
    34
    The Check Engine light went back off so I will continue to ignore it.
  15. 200Volts
    200Volts Member
    435
    45
    Northern CA
    Yes, in CA it is illegal to sell cats. That's why you search, and buy an exhaust pipe (that just happens to have 2 cats in the middle). And if you give a salvage yard your core replacement, I think of it more like a trade, rather than a sale.
    The check engine light means your miles are numbered. It is not a linear process, and when it gets bad, over just a few weeks it drops your mileage like a rock, limit your speed, limit your load carrying, etc.. The end is near (for your cat)!
  16. longbow
    62
    34
    Can you believe it only lasted 320K? What's up with that!!??
    Aaron Vitolins likes this.
  17. brownsnoutuk
    185
    119
    Shepherd, TX
    648,xxx. car will be 10 years old in april.
    Check engine light comes on once a fortnight, Replace hybrid battery.
  18. apt5020
    881
    1,294
    Prius City, CA
    WOW, that a lot of mileage. First time replacing the battery? How is the transmission? Did you replace that?
  19. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    What will it be -- new car or new battery ?
  20. brownsnoutuk
    185
    119
    Shepherd, TX
    most likely new car. cant see the point spending $2k on a car with this many miles.
