Rear Wiper Fix
Discussion in 'Prius c Accessories and Modifications' started by Flippityjane, Nov 11, 2014.
  1. Flippityjane
    Flippityjane New Member
    Atlanta, GA
    2014 Prius c
    Any suggestions on how to feel better about the miniscule rear wiper on my Prius C? Coming from a VW Golf with adequate wiper coverage, I just cringe every time I look at or use the rear wiper on my C. I'm guessing it's not possible to just buy a larger wiper and not use the dorky cover thing supplied by Toyota.
  2. GregP507
    GregP507 Senior Member
    3,002
    480
    I wish it were bigger too, but my only suggestion for how to deal with it is to "deal with it."
  3. Flippityjane
    Atlanta, GA
    2014 Prius c
    *Sigh* that's what I tell myself every time I use it. Or when I tell myself not to use it hahahaha. I mean, if this is my biggest complaint life is pretty good.
    mertechperformance likes this.
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    you really have no other option but to live with it since putting a larger one is not possible because of the height of the windshield.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    It seems you don't have an option as far as improving the wiper.
    The rear window wiper on a standard Prius is similarly poor in my opinion.
    Here is my anal retentive, somewhat obsessive "solution", or at least how I deal with my dissatisfaction with the rear wiper.- I make sure I need to use it less.
    I went to Bed, Bath and Beyond, although I imagine you can find this product in any bathroom accessory department. I bought a "Shower Squeegee". I keep in the back, it's small and compact. I use Rain-X wiper fluid in the washer reservoir. When I notice the rear window getting excessively dirty, I pull the squeegee out and wipe off the rear window.
    Using both products in combination I rarely have to use the wiper. This isn't actually fixing the problem, but at least when I look out the back, I'm not dissatisfied with the rather small oval of "clean" the rear wiper creates.
    Flippityjane likes this.
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Enter Mahout with his crazy wiper blade suction cup "solution".
  7. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    I don't think that's strictly true because there appears to be at least an inch and a half clearance at both ends of the wiper blade to the narrowest part of the window.
    I have wanted to research finding a longer replacement but have not tried that yet.
    It may very well be true that there is no suitable longer compatible blade.
    I would even consider one that it TOO long and trying to cut it down some.
  8. GregP507
    3,002
    480
    For the purpose of spotting traffic in your rear, I suppose it was considered adequate by the designers.
  9. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    It is more adequate for RHD cars...
  10. skayaks
    skayaks Active Member
    123
    107
    Massachusetts
    Tacky to quote myself here but from a similar prior thread:
    No joy here. I taped 1" extensions onto both ends of the stock blade to determine a 10" blade *might* work, so I got a cheap one from Amazon. The new blade required a slight mod to get it mounted to the wiper arm but it didn't clean worth a darn so I switched back to the stock blade. I'm still looking for a fix 'cause that's one of the few annoyances of my C.
  11. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    I don't know if my old eyes are deceiving me or not, but, it seems that the amount of water and dirt on my rear window has decreased significantly since I installed wind deflectors on my front and rear side windows. I drove tractor trailers for 50 years, so I'm kind of anal about watching what's going on behind my vehicle in addition to the front and sides. Anyway, I seem to be using my rear window wiper a lot less since I got the deflectors. Came as a big surprise to me.
    Okinawa likes this.
  12. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    sedans don't even have rear wipers... :D
    Okinawa and robertmaria like this.
  13. ufourya
    ufourya We the People
    1,258
    336
    42
    We don't need no stinkin' rear wiper.
    I have had the car over two and a half years and have wished I had the wiper once. I got over it.
    Aquapel on the windows and frequent cleaning take care of it.
    robertmaria, Matt H, kevtan and 2 others like this.
  14. w2kpugsly
    w2kpugsly Junior Member
    97
    san diego
    What did you use to cover the hole after taking out the wiper motor?
  15. ufourya
    1,258
    336
    42
    I used the original rubber grommet and a clip or retainer (like those used to hold panels, etc.) I had lying around. You can easily find one that fits at your local auto parts store.
  16. w2kpugsly
    97
    san diego
    Thanks!
  17. orenji
    orenji Senior Member
    5,884
    3,486
    Well if Toyota did not install a rear wiper, someone would complain that they did not include one, the one they did include is the best that they could do with the size restrictions. It is what it is, I personally never have used mine, its more for show!
  18. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    As ufourya has pointed out, the rear wiper is useless. I apply RainX on the rear window and clean it as required.
  19. koipond
    koipond Member
    198
    39
    With a different design they could have installed a larger wiper to cover more surface area (such as a blade mounted through the glass making a staight arch with no elbow). Even the current design could have been an inch or two longer and still cleared the spoiler.
  20. orenji
    5,884
    3,486
    An inch or two would help one see what?
