Hi Everyone
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CURLY, Nov 12, 2014.
  1. CURLY
    CURLY New Member
    Los Angeles
    2014 Prius Plug-in
    My 2015 Plug In Prius has been taken to the dealer for two consecutive days regarding "Check Hybrid System". The dealer tested the vehicle and my charge unit and could not find any errors. This morning My Prius indicated not only a "Check Hybrid System" but a new error "Charge Result: Charge Stopped Due to System Malfunction". Has anyone experience this particular issue?
  2. mrbigh
    3,686
    699
    Long Island, NY
    Lately it is a common failure in the 2014/15 PiP with the Toyota provided EVSE. Seems the they have a defective batch of this type of 120 VAC chargers
  3. GregP507
    GregP507 Senior Member
    3,002
    481
    I get that when I unplug the charger before it has completed its cycle.
  4. CURLY
    CURLY New Member
    Los Angeles
    2014 Prius Plug-in
    I left the Prius charging over night?
  5. GregP507
    3,002
    481
    Three hours charging time should be max. Something else is interrupting the charge cycle. Is the power supply reliable?
  6. CURLY
    CURLY New Member
    Los Angeles
    2014 Prius Plug-in
    Greg, thanks for the update. The power supply is very reliable.
  7. GregP507
    3,002
    481
    I'd still check for hot-spots.
  8. bisco
    52,274
    why don't you start a third thread and ask again? maybe you'll get the reply you're looking for.:cool:
    #8 bisco, Nov 12, 2014
  9. TrinaF.
    TrinaF. Junior Member
    74
    24
    Southern California
    Curly, take your car to the dealer. Have them replace the charger. I've been there, done that. I'm thinking a recall is in order.
  10. bisco
    52,274
    agreed. at the very least, a tsb and don't sell any until they have been tested.
