Oil change (not) fun
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ilikethempgs, Nov 8, 2014.
  1. ilikethempgs
    ilikethempgs Junior Member
    42
    Northern, NY
    Went to do the first oil change on the 2011 Prius I bought this summer. I've changed the oil a couple times now on my girlfriend's 2007 Prius, a very easy and straightforward job.
    I was ready with the filter I bought at the dealer and the 5 quart jug of mobil 1 0W20. I read about the 3 pins that need to be removed to open the door to the oil pan. I used to remove an entire belly guard on my A4 to do an oil change, so this little door couldn't be too hard right?
    Well none of the 3 plastic pins had the center part that pulls out with a screwdriver before you pull the outside of the pin. The pins holding my service panel all had solid plastic tops. I was able to remove the two smaller ones with a screwdriver. The larger one that is pushed through some type of metal panel would not come out. I pried, I yanked. I didn't want to break it off because I didn't have any replacements on hand. The original pins must have been replaced awhile ago.
    I searched some for answers, but an words of wisdom on this 3rd "larger" plastic pin? Buy a replacement and then break the one that is in there now out?
    I might suck it up and let the dealer change the oil. What a pain in the nice person.
  2. Former Member 68813
    3,524
    983
    US
    Remove the whole plastic "shield." I did that when I replaced ATF in mine. It wasn't that hard and I could inspect the whole thing.
  3. Mendel Leisk
    41,937
    Sounds like someone previously replaced the pins with aftermarket??
    The stock pins retract jaws by prying up on the centre cap. Mine are a distinct grey colour, a bit bigger than the rest on that panel.
    Fwiw I pull off my entire panel at oil change, to preserve the hinge.
  4. ilikethempgs
    42
    Northern, NY
    Yeah I think these are definitely not the stock pins.
    Ok. Sounds like pulling off the entire panel is the way to go. I think I saw a bunch of 10ish mm grey nuts under there. Are these what I will be removing? (Car is no longer jacked up).
    Thanks in advance.
  5. Mendel Leisk
    41,937
    To just open the flap, I think it's just the two fasteners labelled "5" in this attachment. I believe there's actually 3 types holding the entire panel, but the differences among the rest are so subtle, I've given up, just mix and match them.
    Also, when you have the fasteners off, rinse them in warm sudsy water*, float the grit out of them. It's grit that really seizes them up, causes them to break. That and curbs...
    Be REAL careful you don't flush them down the drain!
    If you take the whole panel off you'll quickly discover there's 10 mm (socket size) bolts near the front bumper to be removed. Start at the back, work your way forward, remove front fasteners last, and then pull the panel backwords an inch or two to extract it from the panel ahead of it.
    Sorry, forgot to post attachement. Got it now
    #5 Mendel Leisk, Nov 8, 2014
  6. Mike500
    Mike500 Senior Member
    2,593
    767
    I replaced the large plastic rivets with M6x1.0 "nutserts" and M6x1.0 Phillips head stainless steel screws.
    Make Your Own RivNut Tool | Carolina Rover Owners Club
    The M6 "nutsert" fits the original 9mm hole perfectly.
    No problem at all in losing them on the road or taking them off when I need to service the oil door.
  7. ilikethempgs
    42
    Northern, NY
    Thanks Mendel and Mike
  8. Mendel Leisk
    41,937
    I think if you replace those 2 troublesome fasteners you'll smooth out in you're future attempts. I've had the panel off about 8 times now, it's 10~15 minutes each way. I believe I had to replace 1 or 2 fasteners (losing track), but for the most part they've held up. Washing the grit out before re-install helped I believe. Also, the Canadian schedule is every 6 mo (or 8000 km), so the more frequent interval means less build-up of crud.
    Besides a slim blade screw driver, one of these (paint can opener) is good with the fasteners. It hooks under the cap and then is easy to lever up. Just take your time, don't force it:
    kc410 likes this.
  9. Mike500
    2,593
    767
    I have M5 "nutserts" and screws that fit perfectly into the 7mm holes made for the 7mm smaller plastic rivets but found that they wee not necessary for the time being.
  10. ilikethempgs
    42
    Northern, NY
    Mendel,
    I tried the paint can opener, and just couldn't get the larger fastener to move out. The one I'm talking about is at the top of the flap, farthest away from the crease where the service hatch bends. Next time I get under there I'll take a picture if I can't get it.
  11. Tande
    Tande Active Member
    550
    337
    Mich.
    FWIW......In a perfect world, the "Pull" on the center pin needs to come equally from two points, 180* apart (so as not to induce a "Bind").....there is a special tool for this......if interested, check with your friendly neighborhood auto parts store......
  12. Okinawa
    Okinawa Senior Member
    1,333
    320
    Whatever you like. I always changed the oil on conventional cars. When I bought a Prius I quit. That is a job for someone else. About a $50.00 job at my dealer. I now have a new Avalon hybrid. The dealer will have that job as well. Only has to be done every 10,000 miles. Just too much screwing around with that splash cover and cartridge oil filter.
  13. Mendel Leisk
    41,937
    Get slim blade screw driver under cap edge, and paint can opener 180 deg away, per Tande? When they're stuck like that is when leverage at a single point is most prone to break the thing.
    Okinawa's right: it's not the easiest DIY, with the underpanel, and the oil filter is unorthodox. OTOH, the complexities are by no means insurmountable..., I'm not a hardcore wrenched, but get through it. Gets easier. But yeah, it can work just leaving it to the pros.
    #13 Mendel Leisk, Nov 9, 2014
  14. GreenClipper
    GreenClipper Senior Member
    116
    Tulsa, Ok.
    I have a 2010 Prius which I've had for right at 5 years. I replaced the HINGE on the oil filter door YEARS ago. I used a piano hinge and it worked fine.......Until I have now had the oil filter door TORN OFF, by something that the low slung car hit in the road. I don't remember the specific incident or I would have been watching for the door sliding down the road behind me... So I've no door now, found out at last oil change. I have a lot of miles on this car, and it is the original panel. Can I get the under engine cover replaced? Or the part? It probably had become warped, and I didn't know it, but it ripped the door off along with the hinge...... I had used pop rivets to attach the door and it worked fine for many years. Even the forum members had nothing good to say about what I wanted to do to cure the original problem, the door broke at it's hinge point while we were away, and the door was taken off till we got home & I could fix it. But door is gone now! Haven't been able to find the part, door or whole panel anywhere yet. Can anyone help? Would I qualify for the Warrantee Part at least, I am years out of warrantee, by both miles, & time, as you can tell, but need to know before I go to the dealer & they "show me the door", telling me that I've waited too long...... Thanks for any help. Greenclipper
  15. Okinawa
    1,333
    320
    No doubt your warranty has expired and if you had a warranty I doubt if the warranty would cover that. I had a 2011 Prius Two. I had to have that cover replaced. For the cover, $262.00 at a Toyota dealer.
  16. Mendel Leisk
    41,937
    If and when you replace the undercover, don't use the "flap" anymore, just remove the whole thing at oil changes. It'll last forever.
  17. ilikethempgs
    42
    Northern, NY
    Lot's of good stuff here. As its getting cold and snowy where I live I returned my oil to the store. I'm going to bite the bullet and have the dealer do this oil change. $45 for a synthetic change and they do them on Saturdays, so I'll kill a Saturday morning reading the newspaper. Maybe in the spring I'll tackle removing the whole cover and changing the oil. Thanks!
  18. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    Glad my dealer offered $ 9.99 synthetic oil changes , with purchase ,,,,
  19. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,739
    1,772
    Bay Area
    Oil change shouldn't be that hard, if its not the stock clips on the oil panel door, just break it and replace it OEM clips. So much easier to deal with.
