Can I just turn on the high beam on by itself?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Mikej, Nov 7, 2014.
  1. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    Without turning on the low beam headlight, is this possible?? Thanks
    Edit:
    To clear any confusions, I just want the high beam light on when I push down the headlight stick instead of high beam light and low beam light on together. Reasons I'm doing this is because I have HID as low beam, so when I need to use high beam in super dark or mountainous region, I don't need the HID to be on with high beam. Although HID light is bright enough lol.
    #1 Mikej, Nov 7, 2014
  2. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Anything is possible, but why would you want to do that? If it's for DRLs, then they should be run at reduced power to decrease glare, increase visibility, and use less power.
    SCH-I535
  3. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    The only way I know of is to pull the headlight switch arm toward you while the headlights are off. The high beams will be on for as long as you have feeling in your fingers.
    I wouldn't recommend it though, since you will get the drivers coming toward you highly agitated.
    Bill the Engineer
  4. xliderider
    8,140
    3,276
    Honolulu, HI
    It could be done easily using a relay. But if it is for DRLs, then you can get a DRL module like the one linked in my signature under highbeam DRLs.
    SCH-I535
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    My C came equipped with DRLs from the factory.
    I hope the OP comes back and tells us exactly what he is trying to accomplish.
    I think that pulling the high beam stalk when the headlights are off will activate the high beams (flash to pass).
  6. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    I just want the high beam light on by itself when I push down the headlight stick instead of high beam plus the low beam on(regular headlight), hope that clears any confusion.
  7. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    the only real way to do it will be by using a relay.
  8. Mendel Leisk
    41,406
    I may be wrong, but I think that's the way it works. When push headlight to go to high beams, low beams go off.
  9. xliderider
    8,140
    3,276
    Honolulu, HI
    +1, but you have some rewiring to do.
    You're wrong. ;) Lowbeams stay on, or go on when flash to pass is activated. That's why OP doesn't want the hids to be activated because it's bad for the ballasts.
  10. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    Thanks for infos guys, damn it toyota, why do they have to make things complicated...
  11. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Yeah.. why provide more light than necessary to help with safety while driving at night... darn you Toyota... :rolleyes: Why does it matter? Turning your HIDs on and off that often will just make them wear out quicker anyhow.
  12. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    Well it's really pointless to have a 50w-65w high beam on together with low beam light. It kills the low beam bulb shelve life and doesn't make a difference since high beam is already bright enough. It's even worse when I have HID as low beam.
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    High beams point higher up on the road than the low beams do. I, personally, wish that my fogs wouldn't turn off when I turned on my brights.
  14. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I am confused why anyone would want to see less of the road. The high beams are aimed out much farther than the low beams, so it will be dark just in front of your car without low beams. (I am very rural, and still use high beams less than 1/3 of the time, due to oncoming traffic)
    The v has low beams on when high beams are on, as well as running lights that illuminate the side of the road, good for spotting animals.
