Hill Start Assist Activating at every stop
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by sfruski, Nov 10, 2014.
  1. bisco
    51,897
    that's interesting. i wonder if it's planned or defective. anything in the o/m?
  2. orenji
    orenji Senior Member
    5,887
    3,488
    My 2012 also will roll back a few inches and then stops, I have never engaged the hill assist, and have no issue pulling forward. So it sounds like a computer update on the newer models possibly?
    I had a Subaru which had hill assist and once engaged it was very hard for it to pull forward until it releases, it may just be the way they are designed to operate. Good Luck to you!
    #22 orenji, Nov 16, 2014
  3. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    So I stopped on the normal slight incline today as I do everyday.
    I came to a stop and then pressed the brake all the way to floor and nothing.
    No beep, no lights, no assist?
    I did roll back a bit though. hmm.
    I will have to check the manual, as I do believe the 2012 manual mentioned that is how to engage the hill assist,
    I just never had to use it.
  4. bisco
    51,897
    you have to hold the brake hard for 2 seconds.
    ztanos likes this.
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    And I think it has to be a bit more than a "slight incline".
    I haven't been able to make mine "take" most of the time I've tried and only had it work on what I consider a substantial incline.
  6. bisco
    51,897
    well, you are in florida after all.:cool:
  7. bisco
    51,897
    i wonder how o/p made out at the dealer.(n)
  8. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    personally i prefer it does NOT beep and i do NOT want the darn blinking lights,,, maybe itz just grabby brakes from too much rust on the calipers. but as long as it goes when i press the gas, we're good.
  9. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I usually get mine to set when I'm at the ATM... I am short and need leverage, so when I'm using the brake pedal for height it sets. Flat ground, no hills. I press the accelerator and it disengages. No problems. 2012.
